Russ
 Re: Anyone know ballistics?
Fri Oct 02, 2015 5:25 pm |
tyler_johnson
Joined: Mon Jan 21, 2013 6:22 pm Posts: 1094 Location: El Dorado-ish, AR
Haha yeah yeah, will do
_________________ '13 GTR35 Stage 2 w/ EVT Exhaust, 1750 Voodoo Custom by DFOU!!
Fri Oct 02, 2015 7:00 pm |
Russ
Mine's a thurs-sun on the 15th....at least yours is just a 4 or 5
Fri Oct 02, 2015 7:49 pm |
netman
Joined: Wed Jan 14, 2009 3:48 pm Posts: 2363 Location: Chandler,Indiana
If I was going to buy a rifle for long range deer I would buy a 7 STW.
_________________ I got a shotgun,rifle and a Go Devil Surface Drive a country boy can survive. 35+hp GDSD engine mods by George Merta 18x48 GDSD boat
Fri Oct 02, 2015 11:10 pm |
Russ
Ugh. Nice round, not the most pleasant to shoot without a brake.
Fri Oct 02, 2015 11:14 pm |
BayouBuster
Joined: Sat Jun 25, 2011 8:33 am Posts: 1352 Location: Genoa AR
I've shot a .308 all my life, I have had other calibers but this is what I prefer. I load 150 gr nosler accubond and they do well. There's nothing like short action satisfaction from a .308.
I finally found the right recipe for my factory model 700 tactical.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Sat Oct 03, 2015 12:51 pm |
JIMMY W
Rookies
Sat Oct 03, 2015 7:25 pm |
Russ
He is a rookie, jimmy. That's why he's asking for help. Got advertise some gator tail shit on someone else's post.
Sat Oct 03, 2015 8:57 pm |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
Sat Oct 03, 2015 9:23 pm |
Swamp Wader
Tue Oct 06, 2015 4:18 pm |
Quack N Stack
Mon Nov 02, 2015 11:58 pm |
brstanle
Joined: Sun Oct 05, 2014 12:27 am Posts: 659 Location: SETX/Houston
6.5 Creed is also a short action round chambering, not sure why that's an issue anyways.
Most of the issues with the 6.5 CM has to do with availability. There is limited factory ammo availability in 6.5 CM, but seeing as how it was spearheaded by Hornady, their loadings are very good options. There's also a real lacking of large-scale factory rifles chambered for it.
.308 Win is a really overrated cartridge IMO. The BC's of .30 Cal don't get all that whippy until ~200grains and the .308 doesn't have the ass to get those big bullets moving more than 2500 fps.
In my opinion, the 6.5 Creedmoor is a great chambering. It is going to give you excellent BC's in a 140 gr bullet, muzzle velocities up near the 2900 fps mark, and has excellent barrel life.
They're good paper killing calibers, but not great for hunting. Pigs, sure, but not any elk or pronghorn that you may want to use the rifle for later. The 6.5x284 Norma will give you similar ballistics as the 6.5 CM but will give you the equivalent of a magnum loading. Also worth noting, the trusty 7mm Rem Mag is a great option with a 195 gr VLD. Lots of factory options in both ammo and rifles.You will have to give up the short action though.
The way I would do it if I were you would be to buy a good solid factory .308 (i would opt for M700, but that's my preference) and shoot the piss out of it while it's cheap. I would either get one with a decent stock or buy one for it (Bell and Carlson, McMillan, etc), get your optics all squared away, get a decent trigger in it, and start getting a little reloading spread together. Once you've got that good, order yourself a nice barrel and have a gunsmith true up your action and bolt and install the new barrel chambered in 6.5 Creedmoor. You'll have a great gun and won't get too deep into it too fast if you change your mind.
_________________ 35 GTR w/ 1860 GoDevil "Ironsides"
Tue Nov 03, 2015 12:49 am |
Andy
Joined: Tue Oct 27, 2015 9:44 pm Posts: 278 Location: Coral Springs, FL
PM me
_________________ Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF -Unbaffled VooDoo -Gator Glide G2 with base -Wet Sounds Stealth 10 Ultra V2 -Green LED Courtesy Lights -15" Combo LED Light Bar
Tue Nov 03, 2015 2:59 am |
