Winch rating http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=7&t=23140 |
Author: | med [ Sun Oct 16, 2011 1:51 am ] |
Post subject: | Winch rating |
Is a 2k lb enough? 1644gd with 27. Saw HFright had the badland atv winches on sale thru december for $50 with the coupon. Didn't see anything bad about them online. |
Author: | robertb4wd [ Sun Oct 16, 2011 2:30 pm ] |
Post subject: | Re: Winch rating |
2k should be enough. A 2.5k or 3k is better but for $50 I'd try one. |
Author: | bbb [ Sun Oct 16, 2011 2:46 pm ] |
Anybody know anything about the Champion 3000 that Tractor Supply sells. eBay has them for $86 shipped. |
Author: | willett [ Sun Oct 16, 2011 3:22 pm ] |
Biggest difference between the cheaper winches and more expensive is the amount of current they draw. Cheaper ones will drain your battery QUICK. Also most cheaper ones aren't waterproof I've had good luck with pro mark winches. (used to be gorilla winches) They are a warn knock off and 100% waterproof and come with more in the box for half price of warn winch. But still better quality then the cheaper ones |
Author: | POKER1 [ Sun Oct 16, 2011 4:51 pm ] |
Author: | med [ Sun Oct 16, 2011 5:43 pm ] |
Thanks. Think ill keep looking. I'm thinking I want a higher lb rating anyway. |
Author: | da go get'er [ Mon Oct 17, 2011 8:38 am ] |
Author: | THE TANK [ Mon Oct 17, 2011 9:51 am ] |
I got a Gorilla 3,000 thats been on my boat for 5 years and I didnt have any trouble with it yet... but I might use it 3 to 5 time a year.... |
Author: | CLICKSTER [ Mon Oct 17, 2011 10:26 am ] |
Got a 2500# waren on my boat. its been on there for 3 years and i use it all the time hunting. heck i have pulled my boat over the intercostal canal levey with it. |
Author: | Chadb1010 [ Mon Oct 17, 2011 11:41 am ] |
i have the promark 4500 and it pulled my rig over a dirt road leve with no pvc rollers just bare dirt... had to re hook 2 times and she never missed a lick... well worth overrating because you never know what you might be faced against. the promarks are all the same measurements, just different gearing so they are small and mine is mounted in my storage on under my casting deck and comes out the front of the right above my trailer hook. In there it keeps my synthetic rope out of the sun and last longer. |
Author: | bbb [ Mon Oct 17, 2011 12:20 pm ] |
Well I just bought the Promark 3000 with synthetic rope for $148 off eBay. Figured it would pay for itself pretty quick if I get myself high and dry. Last year I just had to wait 2 hours for the tide to come. Would have been a 4-6 hour wait if it occurred on the outgoing tide. Hopefully my dansforth anchor has enough bite to act as my pull point. Gonna have to do some experimenting when it comes in. |
Author: | willett [ Mon Oct 17, 2011 3:29 pm ] |
Yea forgot to mention the promark are cheaper on eBay for some reason. |
Author: | POKER1 [ Mon Oct 17, 2011 4:37 pm ] |
Author: | da go get'er [ Mon Oct 17, 2011 6:44 pm ] |
Author: | POKER1 [ Mon Oct 17, 2011 7:01 pm ] |
If you gonna be using it all the time like that then invest in the best winch you can get. |
Author: | kibb [ Mon Oct 17, 2011 7:33 pm ] |
Phuck it. If you will be using all the time, buy a phuckin airboat! |
Author: | Woodiebuster [ Mon Oct 17, 2011 7:40 pm ] |
some of us would have the cage bent into the blades after one good day. ![]() |
Author: | kibb [ Mon Oct 17, 2011 7:46 pm ] |
Build a better cage. ![]() |
Author: | da go get'er [ Tue Oct 18, 2011 5:10 pm ] |
Author: | Woodiebuster [ Tue Oct 18, 2011 5:12 pm ] |
I run down trails so thick I have to get all the wieght to the back to get the motor under fallen trees at times. |
Author: | da go get'er [ Tue Oct 18, 2011 5:18 pm ] |
