It is currently Sat Jun 20, 2026 1:00 am
Reply to topic  [ 46 posts ]  Go to page 1, 2  Next
 SOB!!!
MMT Moderator
Post SOB!!!
I'm driving home about 1/2 mi from the house and come to crossover to get into my neighborhood, now just blocks from the house. Stop and let a lady cross with a dog. Apply the gas & KABOOOM!!!!
I come to instant stop, rear end is locked up!
AAA just took my truck to the dealer. To add insult to injury a guy trying to follow me across unaware that I was trying to get the disabled truck out of the road hits me as I find out I can only go 3' forward until instant stop... He rear ends me backs up flips me off then takes off.
I only got the first 3 of his license plate but have seen his truck in the neighborhood. Man I'm heated. Right before duck season and no truck! Did you know rentals come without a hitch so you can't pull anything?!
My buddy who I'm taking tomorrow luckily has a truck so we are good for tomorrow but DAMN! :evil: :evil: :evil:
GTB 1860 w/ 2019 GTR40XD-HO
Fri Nov 04, 2011 4:50 pm
Post Re: SOB!!!
Go rent a pick up from u haul!
Fri Nov 04, 2011 4:55 pm
MMT Moderator
Post Re: SOB!!!
Fri Nov 04, 2011 4:58 pm
Post Re: SOB!!!
unless its under warranty DO NOT put the factory unit in it!!!!
go with a detroit tru trac.
http://www.eaton.com/Eaton/ProductsServ ... PCT_221471
I gave up mud motors
Fri Nov 04, 2011 5:09 pm
Post Re: SOB!!!
Enterprise rents trucks you can tow with,
I think they are all 3/4 ton diesels
Fri Nov 04, 2011 5:19 pm
Post SOB!!!
Damn the luck..
Brothers stealing rims and tires, and transmissions going out.. Damn the bad luck.
Just remember... Jesus doesn't through anything in your path which you can't handle.
Rev. Uncle J
Fri Nov 04, 2011 5:23 pm
MMT Moderator
Post SOB!!!
Fri Nov 04, 2011 5:26 pm
Post Re: SOB!!!
the stock differential in GM half tons is garbage. It is made by eaton and it has clutches... they are known to blow up at any givin time.
Fri Nov 04, 2011 5:30 pm
MMT Moderator
Post Re: SOB!!!
Fri Nov 04, 2011 5:32 pm
Post Re: SOB!!!
Put a set of Dana 60's in it and be done.
Put yer face in the myrtles.
MMT Moderator
Post Re: SOB!!!
Fri Nov 04, 2011 5:33 pm
Post Re: SOB!!!
dont let the stealership fix it... bring it to your buddies shop and have him put in a true trac.. you wont break it
this is what you need... with new carrier bearings
http://www.performanceoffroadcenter.com ... cts_id=908
Fri Nov 04, 2011 5:52 pm
MMT Moderator
Post Re: SOB!!!
Had a tow truck pick up the Tahoe today from the dealer. He took it out to the Katy area to Lonestar Ring & Pinion. Actually an old higher class guy that I knew way back 13 years ago.
He already inspected the locker, ordered me new parts & said I can come pick it up Friday!
Mon Nov 07, 2011 1:02 pm
Post Re: SOB!!!
GM half ton Locker/ posi units are GARBAGE. They all will eventually fail. Towing makes them fail faster or abuse.
Mon Nov 07, 2011 1:05 pm
Post Re: SOB!!!
Mon Nov 07, 2011 1:11 pm
Post Re: SOB!!!
Mon Nov 07, 2011 2:05 pm
Post Re: SOB!!!
WC 1848 Bateau w/ 36 PD FPR
Mon Nov 07, 2011 2:15 pm
MMT Moderator
Post Re: SOB!!!
Well I tow a 22' Robalo with my truck & my 1860 all over the place... I bet my Tranny is next :lol:
Mon Nov 07, 2011 2:25 pm
Post Re: SOB!!!
Thanks Marcus ..... That educated me somewhat !!! :D Prudy dawg-gone amazin' mechianical marval the rear end is. Mines 1/2 ton Chevy "clanks" in the rear end from time to time .... so far I just been turnin' up on the radio ......
Mon Nov 07, 2011 2:56 pm
MMT Moderator
Post Re: SOB!!!
Mon Nov 07, 2011 3:00 pm
Post Re: SOB!!!
Mon Nov 07, 2011 3:05 pm
Post Re: SOB!!!
The clanking is the locker doing it's thang. When it goes Kaboom, its One HELL of a clank!!!!! That is when you slap a Truetrac and rock on. My 1/2 ton I installed a trutrac and loved the damn thing. It works well!
Mon Nov 07, 2011 3:07 pm
MMT Moderator
Post Re: SOB!!!
Mon Nov 07, 2011 3:16 pm
MMT Moderator
Post Re: SOB!!!
Marcus, my 10bolt had a GovLoc lock in there.
Mon Nov 07, 2011 3:22 pm
Post Re: SOB!!!
WHen they become like a Full detroit, Usually something brke and is causing it to Remain locked. then eventually boom. Run them till they break, and replace them with a better unit. Most likely the Ring and pinion will need replacing too. Heck when Bubba blew his it took out his tranny too from the shock load!
Mon Nov 07, 2011 3:26 pm
MMT Moderator
Post Re: SOB!!!
Mon Nov 07, 2011 3:32 pm
Post Re: SOB!!!
WHat unit are they using? Not a factory replacement?
Mon Nov 07, 2011 3:33 pm
MMT Moderator
Post Re: SOB!!!
Mon Nov 07, 2011 3:35 pm
Post Re: SOB!!!
THe zip locker is an Air locker, The yukon Duragrip is their clutch based LSD. You will need an air compressor for the Zip locker or it will be one Expensive ass Open carrier.
Mon Nov 07, 2011 3:47 pm
MMT Moderator
Post SOB!!!
Ok maybe I heard him wrong I caught Yukon dura grip sounds right.
Mon Nov 07, 2011 4:13 pm
Post Re: SOB!!!
Gottdang raggledy-azz Bowties. Ya'll get a real truck to tow w/ if'n you gonna pull a trailer. :mrgreen:
Mon Nov 07, 2011 6:39 pm
Post Re: SOB!!!
the yukon dura grip is basically just like the stock unit... DONT DO IT
Mon Nov 07, 2011 7:11 pm
Post Re: SOB!!!
Wed Nov 09, 2011 11:32 am
MMT Moderator
Post Re: SOB!!!
Marcus, what type of break in am I talking here?
I have heard from a few people to either do A or B.
A. 15 mi driving to heat it up. Let completely cool. Do this 3x and then change the oil.
B. Drive 500 miles normal driving, avoiding excessive acceleration etc. then change the oil.
During the break in, can I pull a trailer?
Saturday & Sunday can I haul the GTR down to the coast 60 miles and go hunt?
Wed Nov 09, 2011 11:37 am
Post Re: SOB!!!
Wed Nov 09, 2011 11:42 am
MMT Moderator
Post Re: SOB!!!
So I should probably drive to Dallas & back Friday before towing my vehicle... :lol:
Looks like I'll have to borrow a car again from someone
Wed Nov 09, 2011 11:44 am
Post Re: SOB!!!
WHen you tow you flex the teeth and will start to breakin a new portion of the ring and pinion so Its best to tow lightly after you do the intial breakin. Honestly I dont see an problem latching onto the boat as it dosent weigh much. Just stop say halfway and let the diff cool for a bit then finish your journey. Vary speeds and keep them under 60 MPH during breakin.
Wed Nov 09, 2011 11:50 am
Post Re: SOB!!!
Ya'lls fo real ??? Why don't you have to break in a factory one ???
Post Re: SOB!!!
Most normal people baby a new truck anyway for a few hundred miles.. THe first 15 -20 mile are the most inportant then take it easy..
Wed Nov 09, 2011 11:55 am
Post SOB!!!
I thought everyone put them through hell during the first 30 min while test driving. Lol.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Wed Nov 09, 2011 12:00 pm
