It is currently Mon Dec 22, 2025 10:00 am
Reply to topic  [ 8 posts ]
 How engage 4x4 in old gmc
Post How engage 4x4 in old gmc
I bought a old 1983 gmc as a work/play truck and my 95 z71 wasant like this this one you gota move it down and over and then down again do t wanna mess it up know it makes me look like a dumbass but I already put some money into this truck don't wanna drop more because I don't wanna look stupid and ask a question and end up messing it up so which is 4 high
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Tue Feb 18, 2014 4:07 pm
Post Re: How engage 4x4 in old gmc
Put truck in neutral and pull 4x4 shifter back until shifter stops that should be 4 high, pull over to the right and back all the way and that should be 4 low. The N is for neutral on the transfer case and it doesn't matter what gear your transmission is in if you put the transfer case in neutral it will not pull at all
''It's just 90 foot you're gonna die if you fall 20 foot so whats another 70 foot'' Jason Humble climbing school 12'
Tue Feb 18, 2014 4:12 pm
I knew what the N was for and the 4L but by the 4 high it has a dot on both sides so I wasant sure and you gota get out and lock the hubs and thanx it'll be hard to test it cause it has some 37 boggers on it only place ima spin thoes to test it is in some serious mud
Tue Feb 18, 2014 4:17 pm
the other dash (right side ) is shift gate
Tue Feb 18, 2014 4:19 pm
Tue Feb 18, 2014 4:23 pm
movement of shifter that allows you to select gears - thru shift gate. do you have manual hubs, they seemed to work best in these
Tue Feb 18, 2014 4:29 pm
And you gota back up and go forward for it to engage it ??
my old 95 was like that so I'm Sure this one is like that but this one don't have a light or anything to show you it's in 4x4 so it's all just a guess i know you don't wanna be in it when it goes to kick in
Tue Feb 18, 2014 4:31 pm
Yea I gota get out and lock the hubs
