It is currently Mon Jun 30, 2025 12:28 pm
Reply to topic  [ 12 posts ]
 Septic tanks
Post Septic tanks
Does anyone know how much one is and how much is it to get it put down?
Sat Apr 19, 2014 7:16 pm
Post Re: Septic tanks
Actually got one installed this morning. 2100$ for asphalt coated steel, with aerator pump and 65' of discharge pipe installed
Sat Apr 19, 2014 7:24 pm
That the price for it all?
Sat Apr 19, 2014 7:31 pm
M.
' m.
Lackrp
Sat Apr 19, 2014 7:32 pm
Sat Apr 19, 2014 7:33 pm
Sat Apr 19, 2014 7:34 pm
Roughly same experience here. Got a quote a year ago, with sprinkler heads (just the water after the system treats it) instead of discharge pipe was going to add a bit to the cost, but it wasnt too much. Total was 2400 with aerator (included a pump, line and heads for the sprinklers) Required where I live, though.
Sat Apr 19, 2014 7:35 pm
Sat Apr 19, 2014 7:38 pm
There are two electric gates to go through before you reach my house, with a pitbull in the yard. i think ill be ok. lol
Sat Apr 19, 2014 7:43 pm
Sat Apr 19, 2014 7:44 pm
FYI,,
Make sure you maintain it...its kinda out of sight out of mind. But when its not working,,,it cost a shit load of money.
I recently discovered my pump wasn't pumping. I would go put my hand on it about every month or so,,,it was running...but wasn't pumping. Now my drain field is plugged up...
The pump was 400 dollars locally and about 250 online. It was the weekend so I took it apart and found the pump itself was fine. There were two small hoses and grommets that were shot causing it not to pump any more.
Fyi,,make sure you get it pumped about every 3-5yrs.
Sat Apr 19, 2014 7:52 pm
Mine was 2600 installed with 200' of drain field
20' homemade skiff with a stage 2 gtr
Mon Apr 21, 2014 10:14 pm
Users browsing this forum: No registered users and 78 guests
