Trousertrout
Joined: Tue Oct 18, 2011 3:18 pm Posts: 1060 Location: Ohio-The land of few ducks
 anyone with 3.31 gears?
Just ordered a 2015 f350. The only one I found with what I wanted has the 3.31 gears. I have always went with the 3.55. I don't think there will be that much difference. The most I tow is 12,000 lbs. Plus this 6.7 has 40 more hp and 60 more pounds of torque than my 2012. Any opinions? Thanks
_________________ 23 swomp/ 1542 tracker
Fri Mar 27, 2015 6:04 pm |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
 Re: anyone with 3.31 gears?
That's a tall gear... You a flatlander? I ran an old Chevy with 307's a long time ago, rascal would stroll but was hell on u-joints! U shouldn't have any trouble unless you're running in the mountains I wouldn't think.
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Fri Mar 27, 2015 6:18 pm |
msm8281
I know it's totally different but. My personal f_150 has 3:55 gears with the ecoboost engine. My work truck is the same with 3:15 gears. I couldn't find any difference pulling my airboat. I know it's not that heavy but it's like pulling a parachute.
Fri Mar 27, 2015 6:24 pm |
Trousertrout
It is all flat by me except once a year I take the boat to the Atlantic
Howdy
I would say the ratios in the transmission will be geared to accommodate the higher ratio
_________________ ''It's just 90 foot you're gonna die if you fall 20 foot so whats another 70 foot'' Jason Humble climbing school 12'
Sat Mar 28, 2015 9:33 am |
MaXXis85
I'm sure it all has to do with unloaded fuel economy set by the EPA. I know the 6.7L in a f250 with 3.55's really hauls the mail. The transmission ratios take some of that into account as well. Typically I seen the 350's have deeper ratios such as 3.73. You may want to look into it. Is it a DRW F-350?
Tue Mar 31, 2015 7:35 am |
Trousertrout
Just picked it up yesterday. I think my calculating is correct with 3.31 gears and 18" rims that brings it up to about 3.45 ratio. I was worrying about nothing. The fukn thing flies
Tue Mar 31, 2015 2:58 pm |
139sst
I have the 3:31 gears and have never wanted anything higher numerically. Mine has the 20" rims and I average 18 mpg. That is normal driving not babying it. The heaviest thing I pull is about 12,000 lbs and that is on flat ground. If you don't tow in the mountains you should be fine.
Tue Mar 31, 2015 7:06 pm |
50fps
Rim size has no effect, tire size does and a 3.31 gear set still is a 3.31 gear set.
Wed Apr 01, 2015 7:14 am |
MaXXis85
Wed Apr 01, 2015 9:18 am |
Trousertrout
Yea. Sorry I didn't specify. The larger rim has a bigger tire. Sits 3/4".higher
Wed Apr 01, 2015 1:11 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
You math is going wrong way. if you go from a say a 31" tire with 3:73 to a 35" tire you are going to want around a 4:10 to get you back to "stock"
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
Wed Apr 01, 2015 2:53 pm |
Trousertrout
Stop making me have buyer's remorse you assholes. Let my math be wrong and tell me that I am right
Wed Apr 01, 2015 3:50 pm |
Gameover
Wed Apr 01, 2015 6:16 pm |
MaXXis85
Thu Apr 02, 2015 7:03 am |
Gameover
Thu Apr 02, 2015 10:13 am |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
Y'all are just splitting hairs now lol
_________________ 35 GTR - 1754 Extreme
Thu Apr 02, 2015 12:25 pm |
msm8281
If the truck is rated for 12,000# pull 12,000# and don't worry about it.
I pull approximately 10,000# with 3:55 gears and a gas engine. Although I don't pull it that far or that often. Never had a problem. I just pull it in a lower gear to be safe.
Thu Apr 02, 2015 1:13 pm |
MaXXis85
Thu Apr 02, 2015 3:16 pm |
Gameover
Yep mine looked like someone took buckshot to mine
Thu Apr 02, 2015 3:36 pm |
139sst
34" tires ( factory), 20" rims , 3:31 gears. Truck is rated for 15,000 lbs so the the final drive in the new six speed must be pretty low.(higher numerically).truck is fast for a big truck but I did get beat by a 6.2 raptor the other day.
Thu Apr 02, 2015 5:47 pm |
