WAD SHOOTER
Joined: Sun May 16, 2010 4:30 pm Posts: 667 Location: Clinton, MS
 Shotgun Luricant/Rust Prevention
What are you all using and having success with as far as taking care of your shotguns when hunting around saltwater or water in general? I've always given mine a WD40 wipe down after hunts but am thinking about giving corrosion x a try. Who's using it on their shotgun and how has it done? Looking for something to prevent rust and lubricate if they make a do all what is it?
_________________ 1542 War Eagle with 25hp GDLT
Wed Dec 23, 2015 10:38 pm |
Russ
 Re: Shotgun Luricant/Rust Prevention
CLP (break free is the most common name brand). Hangs on pretty well, and will get rid of rust as good as wd40. Does a better job of lubricating though. It's the best do it all I've found in the many attempts at finding something better.
Rem oil works pretty good too at prevention, just not as well at removing it once it forms.
I clean really well every year or two with acetone, then give my shotgun a couple doses of miltec for lubrication (requires some heat cycling to bond properly with the metal, so I use a heat gun, then a reapplication using a heat gun again). After that, I've been using a bit of Rem oil lately for corrosion protection on the parts that don't have cerakote, but the miltec is on all the moving parts. It (the miltec) just doesn't do alot for rust prevention, in spite of the excellent job at keeping the moving parts moving really well.
Wed Dec 23, 2015 10:53 pm |
med
Joined: Wed Jan 14, 2009 8:25 am Posts: 6432 Location: the dark side of the moon
I've been using m-pro7 as a lubricant and really like it
_________________ 1850 & 36pd
Wed Dec 23, 2015 11:08 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
G96 best stuff ever
Wed Dec 23, 2015 11:17 pm |
duck_watcher12
Hornady one shot is pretty good, it's a cleaner with a dry lubricant so you don't have to worry about it gumming up in cold weather like the heavier oils Wil do
Wed Dec 23, 2015 11:32 pm |
Russ
Dfou, best is quite subjective, but its definitely great stuff. g96 is another clp, and probably better than break free and most others in that category. I haven't found a clp that isn't prone to needing refreshing every couple hunts, but it's not as prone to gumming with powder in the cold after extended use. I don't always like having to fool with my shotgun after a nasty weather hunt, and other than blowing the worst of the water out, I don't do anything but some rem oil on a couple spots every week or two until season is over.
Wed Dec 23, 2015 11:45 pm |
FRANKtheTAU
Thu Dec 24, 2015 2:48 am |
slingshot
We hunt saltwater 99% of the time, We have used everthing you can think of lol are Guns are on there last leg. Next season we WILL need new guns. This is what we have done. Spray gun down very well,after hunt come home put a big pot of water on the stove bring to a rolling boil , pour all over your guns , fire up the compresser blow all the water out till there dry then respray them down and put them up. Also wash out your gun case and let dry before you put your guns in them. If you do this your guns Will last a life time. I just want a new gun lol.
_________________ 1542 stuck to a 27mini. She gone. 1746 with a modded 35 gdsd Capt Team total asalt
Thu Dec 24, 2015 5:44 am |
Bug
Joined: Sat Oct 29, 2011 10:28 am Posts: 1068 Location: Tallahassee, Fl
CORROSION-X, plain and simple, dry it and clean it inside and out and apply light coat to all surfaces then a dab on moving parts and your golden. The rest is just hokey!
_________________ PRODRIVE 1860 CC "Let the good times roll" Luck??? The bassards don't stand a chance!
Thu Dec 24, 2015 6:57 am |
Will
Corrosion X It's so damn good that if you apply it to metal, you can't paint it or cerakote it or anything for a year, nothing will stick to it...  The Corrosion X, Aviation & Gun is all the same thing, just a different package http://www.corrosionx.com/specification ... n-data.pdfhttp://www.corrosionx.com/msds/corrosionx-data.pdfhttp://www.corrosionx.com/msds/corrosionx-data.pdf
Thu Dec 24, 2015 7:24 am |
dfou
Did I mention G96? It's the best
Thu Dec 24, 2015 8:07 am |
Will
Thu Dec 24, 2015 8:18 am |
dfou
Thu Dec 24, 2015 11:02 am |
duckhunter888
Joined: Wed Jan 14, 2009 10:44 pm Posts: 828 Location: North Texas
FP-10
_________________ Crisis defines character
Thu Dec 24, 2015 12:07 pm |
jc
It's a lot to read but there is some very good information and some surprising results on test done with many popular brands on this thread. You can skim thru and there are some charts and pictures of all the different test. Hornady one shot and Frog lube are 2 of the best.
Thu Dec 24, 2015 2:11 pm |
ibfishin
Joined: Sun Dec 05, 2010 8:20 pm Posts: 1127 Location: Okeechobee, FL
I use Q-Maxx... seems to be good stuff.
_________________ 35 GTR pushing an 18' Alumitech Custom
Fri Dec 25, 2015 9:25 am |
SETx Longtail
Military issue CLP.... Get it at GI surplus stores. Works great.
I do keep a can of brake clean and a can of Aero-Kroil in the boat as well as WD40 for the engine for its bath after running.
_________________ #CFFITR
Fri Dec 25, 2015 9:36 am |
geraldrn
Joined: Tue Jan 15, 2013 5:00 pm Posts: 77 Location: Southern Arkansas
CLP.. never had any problems,
_________________ GD 1644-23 GDSD
Fri Dec 25, 2015 12:32 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
Will and bug turned me on to corrosion x. Glad they did. It's some bad ass stuff.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
Sat Dec 26, 2015 3:33 pm |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
Hornady one shot. Hoppes 9 and powder blaster for the solvents.
Sun Dec 27, 2015 4:12 am |
Andy
Joined: Tue Oct 27, 2015 9:44 pm Posts: 278 Location: Coral Springs, FL
Frog lube
_________________ Gator Trax 1750HD powered by a Mud Buddy 5500 BAMF -Unbaffled VooDoo -Gator Glide G2 with base -Wet Sounds Stealth 10 Ultra V2 -Green LED Courtesy Lights -15" Combo LED Light Bar
Sun Dec 27, 2015 5:12 am |
Hernaja1
Joined: Tue Feb 19, 2013 11:29 am Posts: 2465 Location: Sulphur , La
_________________ Dual 37 EFI GTR's pushing a 20/72 , CC, point bow , Old school drake Camo Willet custom.
Sun Dec 27, 2015 9:17 am |
WAD SHOOTER
You guys using the red can corrosion x or the green HD can? Also where you finding it for the best price? Only place I can find it is academy and it's high as giraffe pussy but I guess it's worth it
Sun Dec 27, 2015 10:11 am |
Bug
Red label is the one you want, the green is more akin to light grease. Academy is the only readily available source, but more and more industrial/marine supply shops are starting to carry it in the full sized cans. I think I saw it available online also. It's been a pricey product since I first remember seeing it (maybe 15-20 years ago) but a little goes a long way!
Sun Dec 27, 2015 11:02 am |
