It is currently Mon Sep 08, 2025 2:55 am
[ 4 posts ] |
Bigred333
New Member
 Need some suggestions
Im a new surface drive owner. I have a 16 44 alumacraft with a 37efi GTR. My problem is the amount of tourque the motor has at full throttle. It takes almost everything I have to keep it from going to the right. Any help would be appreciated. Thanks
Sat Apr 08, 2017 5:09 pm |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
 Re: Need some suggestions
#1 play with the trim and hole settings. If you are trimmed out of water too much, the torque goes thru the roof. On my boat there's a sweet spot.
#2 You can bend the back of the skeg (on my 2014, there's a distinct tab) more
#3 you can mount the motor slightly off-center (like 1" or less) to the starboard (if that's the way it's pulling)
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
Mon Apr 10, 2017 6:21 pm |
Quack N Stack
Joined: Sat Dec 15, 2012 9:43 pm Posts: 2225 Location: Baytown, Tejas
Dont bend the skeg if its a cast lower unit...it wont bend, it'll just break. Move weight around or move off center
Fri Apr 14, 2017 2:26 pm |
BERNIE255
Joined: Sun Jun 16, 2013 4:43 pm Posts: 1381 Location: Avoyelles Parish/ Marksville LA
Or jb weld a wedge to the skeg. Or bolt a tab to the skeg to bend
Fri Apr 14, 2017 3:36 pm |
[ 4 posts ] |
