Exbellicus
 Who's got a trick for straightening a spud pole?
Got two aluminum spud poles that are bent. One from being wenched agaist, the other from big waves pushing the boat when it was anchored down.
I wouldn't mind except now they're a pain to get in my holders and into the spud hole.
_________________ 2016 Prodrive X 1848 37efi
| Tue Jan 23, 2018 5:09 pm |
4Cody4
Joined: Thu Mar 31, 2011 11:21 am Posts: 2530 Location: Land of 10,000 Lakes
 Re: Who's got a trick for straightening a spud pole?
I’m gonna switch to schedule 80 PVC
_________________ "Two people in this world wear helmets, and that's dare devils and pussies." - Willie Braun
| Tue Jan 23, 2018 8:38 pm |
BlueShamu
Joined: Mon Feb 06, 2012 6:13 pm Posts: 5605 Location: D'town, LA
1" Gray PVC electrical conduit....$4 each.....just saying.
As for fixing your bent spuds, put them into the spud holes and straighten them out....or find a 1" pipe bender.
| Tue Jan 23, 2018 9:24 pm |
BlueShamu
| Tue Jan 23, 2018 9:29 pm |
4Cody4
I’m going to run some of those. Just plan to make a T handle for the top.
Do you fill them with foam so they float and don’t fill with crud?
| Wed Jan 24, 2018 8:07 am |
3rd Coast Killer
Joined: Thu Aug 27, 2009 3:17 pm Posts: 2624 Location: League City, Texas. It's where I play.
Once they bend, even if you straighten them, they will always bend again very easily in that same spot.
I have one that will bend now when you use to actually push pole with. Worthless.
Kool-Aid Brigade
www.southernfowler.com
| Wed Jan 24, 2018 8:20 am |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
PVC, cap both ends or "t" capped at one end. Drill a hole in cap in each end, fill with spray in foam. Makes them a little stiffer and won't sink.
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Wed Jan 24, 2018 9:42 am |
4Cody4
They don’t make a pointed end cap do they? I don’t want to cap it flat, I’d never be able to push it in.
| Wed Jan 24, 2018 10:01 am |
CypressCritter
I don't think so, but I really never issues with it not going into mud or soft bottoms.
| Wed Jan 24, 2018 10:15 am |
4Cody4
We have clay and some rock. I’ll probably just cut it off at an angle and fill it with foam.
| Wed Jan 24, 2018 10:27 am |
BlueShamu
I do cut an angle into one end to help stab it into whatever. Yeah, I just let crud get in it. It always ends up cleaning itself out. Sometimes takes a little beating on the side of the boat or dropping it onto solid ground. It's worth the difference in price.
| Wed Jan 24, 2018 7:47 pm |
Exbellicus
I'm up for trying out the pvc...any suggestion on what to keep on hand to wench against? Think a t post would get me there?
| Wed Jan 24, 2018 9:34 pm |
BlueShamu
Anchor.
| Thu Jan 25, 2018 7:17 pm |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
I have to put mine in a vice to straighten. There is a company out of atl that makes fiberglass spud poles with pointed ends and "T" handles on the other. A friend of mine has some and they are the best spud poles I have seen. I'll try and get a name of the company so you can check them out. I will be getting some this spring.
| Fri Jan 26, 2018 4:46 am |
Roostertail3
| Fri Jan 26, 2018 4:49 am |
4Cody4
1” OD is the same size as the aluminum poles that come from GT? Anybody know for sure? I’m not where I can measure mine.
| Fri Jan 26, 2018 9:14 am |
yammerschooner
I picked up schedule 40 after I bent my original aluminum spud poles at the beginning of last summer. With wind and waves over a hard bottom they had a few times when they would bind in the thru-hull- hole due to the sideways pressure, rise with the wave, straighten out when riding up with the wave (not stuck in the bottom), and then not push back into the bottom when the boat hit the next trough because they were no longer bound. In heavier, open conditions holding in place required resetting from time to time. I also didn't like how the schedule 40 bound in the thru-hull hole when deployed under heavy current.
I ended up going to my local steel distributor and picking up two 1 1/4 aluminum round, 12 feet long. I ground one end to a point, cut to fit comfortably in my interior (a little over 9 feet), and put a stainless bolt crossways through the other end. I have since found that the solid pole is easier to pull back through the hull when in current or wind.
It was more work, more expensive, and each pole now weighs a little under 16 lbs; however, the poles are less likely to bind, bend, or pull out of the bottom under adverse conditions.
If I drop one it is going to sink. That said, I normally don't set up in water deep enough where retrieval will be impossible. If I do, I consider the $40-$45 replacement cost to be peanuts compared to what I have in the rest of the rig.
I will also eventually coat the solid poles with Gator Glide when I do the bottom of my boat. This will probably eliminate the rest of the friction I encounter when my boat is stuck to the bottom in heavy current or wind.
| Fri Jan 26, 2018 5:35 pm |
KJH
Joined: Tue Jun 09, 2009 9:09 pm Posts: 520 Location: Nebraska
I tried the PVC route... didn't work at all for me. Absolute junk. Never worked for shit.
_________________ 1854 Brother Breaux and Boss 40XP and 90hp outboard.
| Mon Feb 19, 2018 12:11 pm |
4Cody4
I ended up buying some assemble at home 1” fiberglass spud poles. 8’ one piece with handles and stainless pointed ends. $55 each.
| Mon Feb 19, 2018 4:53 pm |
Exbellicus
| Mon Feb 19, 2018 6:55 pm |
yammerschooner
| Wed Feb 21, 2018 11:50 pm |
4Cody4
| Thu Feb 22, 2018 7:44 am |
