It is currently Thu Feb 19, 2026 1:46 pm
Reply to topic  [ 23 posts ]
 who uses the following and comments
Post who uses the following and comments
stabil-
seafoam-
starbrite product (old timers, cant remember the name)-
any others-
justt got the big boat out. put it on the hose and it ran like crap. figured carb kits so i made an apointment with the dealer. in the mean time i drained the gas (14 gal. will be cuttin the grass on that) put in fresh gas with seafoam and oil ( pre mix mine, figure it it blows due to oiil its my fault not the injection) well its a johnson wiith plastic carbs. had a friend from back home, outboard tech, tell me to do the above and run it. the plastic carbs dont funk up like aluminum. guess what ? the phucker run like new. no sputter sneese no miss nothing.
now ive been using the marine stabil fotr the last 2 years due to the ethonal. seems to be ok but never had any problems with out it. the dealer tells mme thhat seafoam doesnt do much for the gas its a cleaner and that iit does very well. he tells me abbout the starbrite stuff and that iit binds to the alcohol/ethonal and makes it heaveier. no vapor lock problems.
what do ya think ?
Wed May 12, 2010 8:41 pm
Post Re: who uses the following and comments
wtf with the double letters. now it works. wtf?
Wed May 12, 2010 8:44 pm
i use seafoam religiously. never had any problems with it in my boat or truck. once a yr i pull my carb and pour it directly inline and let it circulate to clear my hoses out. white smoke pours out my exhaust.
message capt jon on here, hes kinda the seafoam and bayboat expert!!
Profile YIM WWW
I also use seafoam... it will work wonders on clearing crap out and making it run good again.
WC 1848 Bateau w/ 36 PD FPR
Wed May 12, 2010 9:01 pm
Instead of puttin in additives, I used Prestone Marine Fogging Oil every once in a while or when I knew I wasn't gonna be able to go out for a while. With the motor runnin, spray it directly into the carb from the side (should have a hole in the set screw about the same size as the spray straw) until the motor starts to die out. Do this to each carb a few times. Repeat a few times a year and she'll stay clean. ;)
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Seafoam is awesome. You can put it in every tank of gas if you want, plus gag the motor with it to clear the carb. I think they should put that sht in the pump in place of gasoline.
Sta-bil helps, but there's no replacement for starting your motor up and running it for a few minutes til warm every now and then. See above paragraph about Seafoam :mrgreen:
I dunno about the other stuff.
Put yer face in the myrtles.
Wed May 12, 2010 9:19 pm
how you like that big scavenger ? i had a 5.5 hp. tough little bastard ugly and slow but tough.
Wed May 12, 2010 9:23 pm
I use seafoam in every tank. Stuff is gettin higher in price, but it has seemed to work for me.
1854 Brotha Breaux Bateau pullin' a 35 GT arrrrahhh!
Willett Welding custom boat trailer
Wed May 12, 2010 9:25 pm
Wed May 12, 2010 9:26 pm
Thu May 13, 2010 12:50 am
MMT Moderator
Y'all putting these products through your MM?
To be honest I haven't put anything in her. No sea foam, no stabil nothing.
GTB 1860 w/ 2019 GTR40XD-HO
Thu May 13, 2010 6:31 am
I used the fogging oil in my suki. Only thing i give my mb is 93 octane with some 104 Octane booster.
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Thu May 13, 2010 12:05 pm
i usually find a store without the ethanol and still use a little seafoam ever now and them. they advertise no ethanol but who really knows???
Thu May 13, 2010 12:16 pm
well got back from a week on the river with no problems (other than a chunk out the prop)
mixed up a 6 gal batch of gas oil and a double shot of seafoam. ran it out and cleaned up fine. then we ran about 50 gal with stabil. never missed a beat.
the other stuff is called startron by starbright. sposed to be the chit. i will try it after i burn up the stabil i have.
Sun May 30, 2010 12:49 am
Seafoam....works
Twin aucouoin 17-48's and three 6's of the pd.
Sun May 30, 2010 5:21 am
I use seafoam and stabil on occasion. about once a year I run some Marvel Mystry Oil thru 1 tank.
Sun May 30, 2010 7:05 am
I run stabil in every tank to keep the water out of my fuel because I have an aluminum tank and it will sweat.
I havent had any water show up in my fuel/water seperator yet, so either it works or my tanks does not sweat inside.
Sun May 30, 2010 8:12 am
AV Gas 100 LL need I say more :D
Sun May 30, 2010 8:47 am
Sun May 30, 2010 8:48 am
Sun May 30, 2010 4:26 pm
havent used the seafoam in my mm. but i have used it to clean junk out of swamped fourwheelers several times with good success.
35 GTR with marshmellow on 1854 Gator Tail Boat.
Tue Jun 01, 2010 2:12 pm
My PD has 312 hrs on it, just dumped all the gas out of the water seperator andfilledit with sea fom. Dumped the rest in the 6 gal tank. Fired her up, she spit a nice big black cloud, ran rough for about 15 sec, turned up the throttle to 3000RPM for app. 60 sec and went on my way. As the day went on you could feel her run better and better. I think she actually runs better than new to be honest... Only time I ever used it in my MM.
18'X4' Brother Breaux Skiff, 36PD, SETX mods by Cody & Crew
Tue Jun 01, 2010 7:39 pm
MMT Moderator
I did use Sea Foam I did use Stabil... I have now found a new product... Pri-G
http://www.survivalunlimited.com/fuelst ... wworks.htm
Tue Jun 01, 2010 7:52 pm
