It is currently Thu Jul 17, 2025 7:24 am
Reply to topic  [ 21 posts ]
 surface rust on shotgun
Post surface rust on shotgun
what do yall recommend for removing surface rust on a shotgun that wont ruin the bluing?
Thu Nov 11, 2010 6:10 pm
Post Re: surface rust on shotgun
There is a po boy version of parkerizing that only needs mild
heating.... Forgot the brand, cost about 20.00, gpt it at a gun
show - I did an old pump gun that was a rust ball and it looked
good and stopped the rusting....
Looked a bit like a black krylon crackle finish when done...
Eat - Sleep - Hunt ! ! !
Thu Nov 11, 2010 6:18 pm
ive heard of using 0000 steel wool and wd 40, anybody try this? its rusted from being next to the seat of my truck and gettin beer spilled on it
Thu Nov 11, 2010 6:20 pm
The steel wool cuts into the bluein a bit...
Just don't use Naval Jelly unless you want ALL the blue removed
I made that discovery / mistake once....
My old Belgan Browning A5 rusts when you look at it wrong - spray with
3in1 - wipe down after afew hours with cotton cloth - then RemOil to finish
seems to work best on it....
Thu Nov 11, 2010 6:23 pm
K thanks Giga, ima try that.
Thu Nov 11, 2010 6:28 pm
I think Brownells Aluma-Hyde - was the stuff I was tryin to remember
in that first post.... It was a last resort due to the gun's condition and
turned out great.... Lasted for years....
They have some instructional vids too..
http://www.youtube.com/watch?v=raeeeCc9SWw
Thu Nov 11, 2010 7:04 pm
I've used steel wool and oil to take off some surface rust. Just be careful and it shouldn't do too much damage to the bluing. I have an old ithica that had a lil on it when it was acquired. That's what I used to get it off. Keep in the safe in a silicone sock now, rust never came back. Hunted with it for several years and just wiped it down with a silicone rag after almost every hunt.
Thu Nov 11, 2010 8:09 pm
If you a serious duck hunter if have it dipped or wrapped .. Gander mt does it now for pretty cheap itll save yoalotot of head ache
Gave up hunting ducks and started underwater basket weaving!
Thu Nov 11, 2010 8:13 pm
[quote="BASSMASTER"]If you a serious duck hunter if have it dipped or wrapped .. Gander mt does it now for pretty cheap itll save yoalotot of head ache
My gun is already camo, but i dont know about you. i wouldn't want to send my gun off for 6 to 8 weeks to have it dipped even if it is for P.D.
Thu Nov 11, 2010 8:30 pm
Fri Nov 12, 2010 8:04 am
Krylon
Fri Nov 12, 2010 8:11 am
:lol: :lol: yeah its not a duck hunting gun. Its a ninja and squirrel hunting gun :D
Fri Nov 12, 2010 8:14 am
Rem oil and let it soak. It will penetrate the rust and you can wipe it off after a few hours.
Fri Nov 12, 2010 8:49 am
kroil will dissolve the rust right off. I suspect any rust penetrationg oil will do the same.
1554 excel- custom MB sport totin a stage II generac temporarily
20XRD Bullet- 300X Merc
Fri Nov 12, 2010 9:04 am
Fri Nov 12, 2010 9:32 am
Steel wool (used lightly) or even a grainy rag -you just need something with a little roughness to it, used with the gun powder solvent that you use to clean the barrel. Then wiped down good with rem oil or the like.
Then you have to keep it oiled.
If you get too much of that bluing off it will be a problem forever or until you get reblued.
Fri Nov 12, 2010 9:48 am
I've used Rusty Duck gun oil to remove surface rust before. Spray it down good & let it soak for a few mins then wipe it off. Gettin harder to find it around here now tho. :(
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Sun Nov 14, 2010 7:18 pm
send it off and get it camo diped. a buddy just did his and it looks good
18x48 homemade skiff pushed by a 2010 36 prodrive tiller drive long shaft,
camo, with hydro trim and manual reverse
Tue Nov 16, 2010 11:41 am
Forget the dip and try this. I know it sounds lame but it's amazing how good this works. 3 seasons of hunting saltwater and around salt cedars with no rust. It's even more durable then a dip job. You can find my benelli on this post.
Sat Nov 20, 2010 10:53 pm
Sun Nov 21, 2010 8:00 am
Aeon, that camo finish of your is first class!
I have several of my guns finished in Stealth Coat. You can find the place at www.gunfinish.com and I have a 12 gauge that I take on my boat while fishing in salt water that doesn't have a speck of rust on it in over 4 years that it's been on my boat. If you take the gun apart yourself, the finish will cost you like $120 or so I think it's a pretty good deal.
"We Are Products Of Our Decisions"
Mon Nov 29, 2010 9:03 pm
Users browsing this forum: No registered users and 49 guests
