Small Generator Specs. http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=17629 |
Author: | TURBODRIVE [ Sun Apr 10, 2011 12:30 pm ] |
Post subject: | Small Generator Specs. |
For those of you looking into buying a small suitcase style generator for bowfishing/ etc.. Yamaha EF2000iS (*Est. $1,000) Maximum AC Output 2000 watts Rated AC Output 1600 watts Rated / Maximum AC Current 13.3 / 16.7 amps @ 120V Engine 79cc OHV, Forced Air-Cooled, 4 Stroke, Single Cylinder Overall Length 19.3 in Overall Width 11.0 in Overall Height 17.9 in Dry Weight 44.1 lbs. Fuel Tank Capacity 1.1 gallons Continuous Operation at 1/4 Rated Load 10.5 hrs. Noise Level 51.5 - 61 dB (A) Warranty 3 Years Limited Warranty Honda EU2000iA (*Est. $1,000) Maximum AC Output 2000 watts Rated AC Output Rated / Maximum AC Current 16.7 amps @ 120V 12v - 8.0A DC output Engine 4 Stroke Overall Length Overall Width Overall Height Dry Weight 47 lbs. Fuel Tank Capacity 1.1 gallons Continuous Operation up to 9.6 hrs. on 1.1 gal Noise Level 53 to 59 dB (A) Warranty 3 year residential and Commercial Honeywell 2000i (*Est. $500) Maximum AC Output 2000 watts Rated AC Output Rated / Maximum AC Current Engine 125cc, air cooled, OHV ,4 stroke Overall Length Overall Width Overall Height Dry Weight 58lbs. Fuel Tank Capacity 1.5 gallons Continuous Operation 5 hrs. at 50% load Noise Level 62 dB at 7-meters (no load) Warranty NOT good reviews ETQ IN1800i (*Est. $500) Maximum AC Output 1800 watts Rated AC Output 1600 watts Rated / Maximum AC Current Engine 3.4 HP OHV, Air-Cooled, 4 Stroke, Digital Overall Length Overall Width Overall Height Dry Weight Fuel Tank Capacity 6.42 gallons Continuous Operation 11 hrs. on 50% load Noise Level Less than 60dB Warranty Generac ix2000 (*Est. $550) Maximum AC Output 2200 watts Rated AC Output 2000 watts Rated / Maximum AC Current 60Hz 16.3/18.3 amps @ 120V/ 12v DC Engine 126cc OHV, Variable speed,4 stroke Overall Length 22 in Overall Width 12 in Overall Height 18 in Dry Weight 49.6 lbs. Fuel Tank Capacity 1 gallon Continuous Operation 4.7hrs. on 50% load Noise Level Warranty 2 year Residential 6months commercial Champion 2000W Inverter (*Est. $600) Maximum AC Output 2000 watts Rated AC Output 1600 watts Rated / Maximum AC Current 14 amps @ 120V/ 12v DC Engine OHV, Variable speed, Overall Length 16.3 in Overall Width 13.2 in Overall Height 19.3 in Dry Weight 48 lbs. Fuel Tank Capacity 1 gallon Continuous Operation 9.5 hrs. at 25% load Noise Level 54 dB at ΒΌ load Warranty 2 year Residential 6months commercial Kipor IG2000 Inverter (*Est. $700) Maximum AC Output 2000 watts Rated AC Output Rated / Maximum AC Current 13.3 amps @ 120V/ 12v DC Engine OHV, single phase, single cylinder, 4 stroke, air cooled, digital Overall Length Overall Width Overall Height Dry Weight 48.5 lbs. Fuel Tank Capacity 1 gallon Continuous Operation 3.5 on full load Noise Level 54-59 dB Warranty Hyundai HY2000si (*Est. $500) Maximum AC Output 2200 watts Rated AC Output 2000 watts Rated / Maximum AC Current 16.6/20 max amps @ 120V/ 12v 8.3A DC Engine 125cc, 4 stroke Overall Length 525 mm Overall Width 330 mm Overall Height 575 mm Dry Weight 32kg Fuel Tank Capacity 7 liters Continuous Operation 5.5 hrs. Noise Level 65 dB Warranty 2 years Briggs &Stratton 30473 2000w Inverter (*Est. $500) Maximum AC Output 2200 watts Rated AC Output 1600 watts Rated / Maximum AC Current 20 max amps @ 120V/ 12v 5A DC Engine 105cc Overall Length 19.5 in Overall Width 11 in Overall Height 17 in Dry Weight 50 lbs. Fuel Tank Capacity 1 gallon Continuous Operation 6.5 hrs. at 25% load Noise Level Warranty 2 year limited |
