It is currently Thu Jun 26, 2025 7:52 am
Reply to topic  [ 15 posts ]
 DIY Mallard Machine, ? about wiring
Post DIY Mallard Machine, ? about wiring
I'm in the process of making a DIY Mallard Machine. I've got too much free time and a free trolling motor. I've got everything worked out but the wiring. The power goes inthe the tm tiller/head then to a control box that controls speed adjustment. From that point, leaving the little box, are 4 wires-a black and red for power and a blue and a yellow wire. all four wires run to the lower unit/powerhead. I had considered using the tiller apparatus for on/off. Would be nice as I could adjust the thrust too this way, but I'd have to run four wires from the boat to the MM. I had planned on using an outdoor extension cord, but I'd have to use two. now I'm thinking I'll just use a simple on?off switch and discard the tiller. What do I do with the ends of the other two wires (blue and yellow)-wire them together? cover the ends and not wire together?
Thanks
Wed Dec 12, 2012 1:19 pm
Post Re: DIY Mallard Machine, ? about wiring
Why not just use a 4 conductor wire??
Wed Dec 12, 2012 4:42 pm
Figured it would be expensive. I need about 25-35 yards.
Wed Dec 12, 2012 6:27 pm
use an extension cord and cut the ends off .
1836 go devil, 23 hp LT go devil
Wed Dec 12, 2012 6:30 pm
That was my plan, but there are only three wires in an extension cord (see op)
Wed Dec 12, 2012 7:11 pm
Tape two cheap two wire cords together.
Wed Dec 12, 2012 7:14 pm
Trailer wiring not sure if it would be big enough gauge tho.
Wed Dec 12, 2012 7:17 pm
Had the same thoughts about trailer wire.
Thought of zip tying two extension cords together, but the problem with that is that I have to attach both of them to the lower unit in a water-tight fashion and two won't fit in the hole. I could strip them down to the inner wires. That would fit. Then a bunch of silicon. I think I'll just see how much a four conductor wire is. I tested the motor and it doesn't seem to matter if the blue and yellow wires are connected or not. Runs both ways.
Wed Dec 12, 2012 7:34 pm
Get a single peice of speaker wire and wrap it/zip tie it the length of the 3 wire ext. cord.
Wed Dec 12, 2012 8:47 pm
Use one heavy duty extension cord and one of those momentary switch you put on the front deck of your boat for the trolling motor.
17/50 GT/HD-MB???
They can run, but in the end they will just die tired.
Wed Dec 12, 2012 8:56 pm
You can also wire in a automotive flasher 2 make it pulse and save battery power.
Jay Dore
Wed Dec 12, 2012 9:45 pm
Y'all are way over complicating this. Go to lowes and buy irrigation control wire, it's 5 or 7 conductors and is waterproof and cheap.
Wed Dec 12, 2012 10:18 pm
http://www.trollingmotorparts.com/defau ... chprompt=1
Like this??
My suggestion is ext. cord black to black
White from positive of battery throught the flasher out to red on motor
F the speed control shit
Wed Dec 12, 2012 10:20 pm
Yes, wired like that. I'm tending to agree with you, pp.
At some point it turns into too much shlt for a nickel, which takes the fun out out of it.
Wed Dec 12, 2012 10:35 pm
Wed Dec 12, 2012 10:40 pm
Users browsing this forum: No registered users and 47 guests
