It is currently Fri Jul 18, 2025 9:46 am
Reply to topic  [ 78 posts ]  Go to page 1, 2  Next
 Best four wheeler tires
Post Best four wheeler tires
What are the best all around four wheeler tires out there? I'm looking for a light, all around tire. What do y'all use?
Sun Oct 27, 2013 8:01 pm
Post Re: Best four wheeler tires
Try out some of the radial "all terrain" 4 wheeler tires. Know a few guys running them and love em. What you puttin em on? If side x side I would run the outlaw radials.
Sent from my beeper.
Sun Oct 27, 2013 8:13 pm
Mud bitch
Sun Oct 27, 2013 8:21 pm
swamp lites, mudlites, 589's are a few of the good all around tires. outlaws, silverbacks, moto monsters etc. will cause alout of damage if u have stock parts
Sun Oct 27, 2013 8:29 pm
Right now I have a set mud machines on my grizzly 700 ducks unlimited. I love the tires but I don't think they make them anymore and I'm gonna need to replace not too far down the road.
Sun Oct 27, 2013 8:44 pm
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sun Oct 27, 2013 8:47 pm
I run Itp mud lite xtr on can am and love them. It's a radial mud tire . Runs smooth with no vibration at high speeds and grabs good in mud or loose terrain. They are not and extreme mud tire but they work good for all around use
17/54 gator tail extreme with a stage 2 gator tail strapped on the back
viewtopic.php?f=5&t=43412
Sun Oct 27, 2013 8:49 pm
Sun Oct 27, 2013 9:22 pm
I work for a wholesale 4 wheeler parts company and we sell thousands of every tire imaginable every month, for a good "all around" mud terrain tire alot of the guys already have it covered.
Mud-lite and Mudlite XTR's, Swamp lites, Maxxis Zillas, are all good tires.
I would also look at Reptile Radials, STI Black Diamonds, STI Outbacks (new tires, look pretty good) Maxxis Ceros, good ole Super Swampers, or ITP Blackwaters
If you want a cheaper tire, look into Carslile 489, Kenda Bearclaws, GBC Dirtdevils, or Slasher 301/401's
Personally, If I had to have one set of all around fourwheeler tires forever, they'd be mudlites.
I have a set of 25" Bearclaws just for a cheap set to put on my wheeler when I hunt WMA's with tire restricions
Sun Oct 27, 2013 9:29 pm
Very good post Woodie... Very accurate as well.... Maxxis Zilla is one of the lightest tires on the market till this day and have been for some time.. They make a good all around tire, and are the lightest... The one tire id choose alongside those would be mudlites.. mudlites are a great all around tire.
1850 Uncle J
Delta Performance level 4 GTR
Sun Oct 27, 2013 10:39 pm
I vote stocks!! I have a new ranger that is bone stock and is staying that way!! But I also have a rubicon with 28" outlaws on it!
If I ever wear the tires out on the ranger I will probably go with the mud lites.
Mon Oct 28, 2013 8:47 am
Mudlites are a good tire for jus riding trails n shit wouldn't put em in the mud. Outlaws are a good tire an so are backs I've rode 30 silverbacks an 31outlaws and 32s all on same stock axles! Never broke anything on my canam. These are heavy tires an will fuk some shit up if you are heavy on the throttle! they both pull hard in mud an will float good in water. The silverbacks are more thicker rubber and last a lil longer than outlaws but the outlaws ride smoother on road. I enjoyed my 32s the most
1852 Dfou custom 35gtr
Mon Oct 28, 2013 10:35 am
Would it be better to go shorter and wider or taller and skinnier?
Mon Oct 28, 2013 11:59 am
I'll probably end up with zillas
Mon Oct 28, 2013 12:00 pm
Tail n skinny is better than short n fat ;)
Mon Oct 28, 2013 12:01 pm
Go with 27-28 10s all around would be my vote
The Zilla is a light tire, but they almost seem "too light" if you run in cut overs or stobby trails, i wouldn't recommend them
Mon Oct 28, 2013 12:02 pm
i have mega mayhems and i really like em..suppose to be just like zillas but a tad tougher and only a little bit heavier..i have 27s all the way around and my 420 turns them in the thick no problem and they are pretty smooth on trails
Mon Oct 28, 2013 1:05 pm
I've got 29.5 outlaws on my 09 grizzly 700 DU edition. Now with that being said with the super aggressive mud tires you need to go with stronger axles. I run gorilla axles front and rear. Somewhere around $250-300 each. Have 4 inches of lift and 2 inch wheel spacers. Now tall and skinny (also called pizza slicers) cut down deep and to the bottom. Fat tires displace mud and tend to float. Mine are the wired. 29.5x12 and 29.5x10. I went wide because I do more water riding than mud. Its snorkeled and rear tires are ½ full of water to sink them to bottom instead of float. Makes water wheelies so much easier. I ride 5-6 from deep water all the time. Now this isn't good on bearings so maintenance is increased.
Mon Oct 28, 2013 1:43 pm
Here some of us riding at Crosby
http://m.youtube.com/watch?v=AzqqVl6d68s
Mon Oct 28, 2013 1:57 pm
I think you'd be better off with a boat haha.
Mon Oct 28, 2013 2:29 pm
I'm running the ITP mud lites and love them.
Running a Alumacraft 1442 NCS with a 25 HP Orion surface drive. Not the best, but it works.
Mon Oct 28, 2013 6:42 pm
If you ever get out the all terrain mode into Fsu mode these will do the trick
35 GTR chasin a BBC 1848
Mon Oct 28, 2013 6:58 pm
those are the heaviest tires on the market.
have seen them with that middle knob grinded off, they are sick.
ive seen a can-am with the mombas and middle knob cut off and it just destroyed the mud hole.
man ur best bet is zillas. if u plan on ridin a lof ot mud go with the mega mayhems. im bout to put skinny wide combo 28s on my big bear, 14" rim.
9s in the front and 11s on the back
Mon Oct 28, 2013 7:25 pm
I fuckin hate those black mambas, the 32x10x14 weighs like 75 lbs I believe... Retardedly heavy.
If you don't put your bike off in stupid mud holes to FSU and you actually use it to hunt and ride trails The Zillas will be good tires, I'd just be worried about punching holes in em.... If you do decide to get some Big Azz tires, buy slasher axles and pay for my huntin' toys :mrgreen:
Mon Oct 28, 2013 7:55 pm
I know this is probably hard for some of you to believe but not everyone runs there 10k four wheelers in 10 ft of water for fun they actually use it to hunt and use on ranches and deer leases.the guy asked a good all around tire, not what is the best extreme mud tire which are out laws and silver backs both of those tired ride like shit on hard pack and at good speed ,so neither is and all around good tire lol, damn fools
Mon Oct 28, 2013 8:17 pm
^ Hey, this guy is getting better! :lol:
Mon Oct 28, 2013 9:58 pm
Mon Oct 28, 2013 10:28 pm
HEY KALBEB.. STFU AND SIT BACK AND LISTEN DUMBASS...
Whatever you do.. DO NOT get the BLACK MAMBAS.. They too heavy. Listen to jet ski boys advice and get what he has... best all terrain tire out there..
1850 Uncle J
Mon Oct 28, 2013 11:16 pm
Tue Oct 29, 2013 2:52 am
Goodyear Mud Runners will surprise you, pull good, ride smooth compared to many others and they last a long time.
Tue Oct 29, 2013 5:32 am
Oh and I prefer a 9" wide in front and a 12" in back, not same width front and back, this makes it easier to steer plus the skinny in the front leaves something for the back to grab! Never understood why people run the same width all the way around, I've seen them just dragging the back because it's already rutted out by the front...
Tue Oct 29, 2013 5:36 am
Tue Oct 29, 2013 5:53 am
Tue Oct 29, 2013 6:14 am
U can't put those tires on a bike that had no power to turn them ^ that y your shit is broke. That thing prob struggled since the day u put them on. U need a gear reduction or jus get a canam n be done wit weak ass bikes
Tue Oct 29, 2013 6:52 am
Tue Oct 29, 2013 6:53 am
Tue Oct 29, 2013 7:06 am
Tue Oct 29, 2013 7:14 am
Tue Oct 29, 2013 8:10 am
Tue Oct 29, 2013 8:31 am
Might think about the swap lite tire if your looking for a lite all around tire that's wears good. A friend of mine has a set of these and he went every where I went on my outlaws at mudfest last year. He runs stock axles and his bike handles them well.
Tue Oct 29, 2013 8:52 am
Users browsing this forum: No registered users and 62 guests
