RWRiverRat
Joined: Mon Aug 06, 2012 10:32 am Posts: 43 Location: Red Wing, Mn
 Ideas for a Higdon Pulsator 2 decoy bag
I just got a Higdon pulsator 2 decoy and I am looking to find/make a case for it. If you have any ideas let me know
Thu Nov 07, 2013 10:38 pm |
Bigbuckfever
Joined: Sat May 28, 2011 11:18 pm Posts: 2114 Location: Slinger, WI
 Re: Ideas for a Higdon Pulsator 2 decoy bag
Edit: i misread
_________________ Every day I'm paddlin' 1848 Gatortail boat and 37 efi GTR.
Thu Nov 07, 2013 10:47 pm |
diddyduck
Joined: Mon Sep 02, 2013 10:24 pm Posts: 2624 Location: ponchatoula, la
tackle box or smaller tool box guessing your talking about for in the boat? or does it have to go in the water or something?
Thu Nov 07, 2013 10:48 pm |
Bigbuckfever
I just store mine in a rubbermaid tote. Holds three swimmers and a butt in a standard sized one. In the boat i just take them out of the you're and stick em in to whatever space is available. Boxes in the boat take up too much space for me. They're very durable.
Thu Nov 07, 2013 10:52 pm |
RWRiverRat
They seem to be put together pretty well except for where the pump connects to the bottom of the decoy. Has that broken on you ever? That is really the only part I'm worried about
Thu Nov 07, 2013 11:02 pm |
Bigbuckfever
No. The higdon I've got is the swimmer, but it should be attached the same. The rest i built off that design. I've had it for 2 years getting beat up in boats and the bed of my truck sometimes and not one issue yet.
Thu Nov 07, 2013 11:08 pm |
petrel
Joined: Mon Jan 11, 2010 9:51 am Posts: 770 Location: NVA
The pulsator is a great addition to a hunting spread and Higdon is a good company to work with. However, the pulsator is not as rugged as it would initially appear. You need to handle it with care or your will end up replacing connections. Putting a loop in the cable at the pump and zip tying it to the pump housing can save a failure there. If you are going to run it in deep water, buy the extensions to avoid fatiguing the connections.
The less you handle them and bang them around the better. I carry mine in a rubbermaid tub with the hook in the hose used to hang the decoys over the side of the tub and the battery packs stacked in the bottom of the tub.
_________________ Phowler 2066 w/ E5 37 ProDrive w/ Illowa Marine Heads MoMarsh Fatboy/2 Honda
Fri Nov 08, 2013 5:13 am |
tinman454
Joined: Mon Feb 07, 2011 10:47 am Posts: 732 Location: Ontario ,Canada, eh!
Two seasons on mine put a pice of foam in the bottom of a Rubbermaid tote also works good.
_________________ 08 35 mudbuddy, gator traxx 3 man hide.
Fri Nov 08, 2013 8:52 am |
cajun1085
Joined: Fri May 10, 2013 2:57 pm Posts: 183 Location: Silver Spring, MD
I have 2 pulsators, I just throw them in the boat and don't worry about it. They are well built. I don't have a lot of room for extra boxes.
_________________ GTB 1646 w/HD, Boat Blind-25GTR
SOUTHEAST GATORTAIL
Fri Nov 08, 2013 11:24 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
I have been carrying mine around in a zipper tool bag & small duffel bag for several years. Old series motor played out on the first. Higdon is very helpful and CS was awesome.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Fri Nov 08, 2013 11:54 pm |
lilfukr79
Throw mine in a 5gallon bucket then in the boat, battery on bottom. Never any troubles after 2 seasons.
Sun Nov 10, 2013 12:02 pm |
RWRiverRat
I found a ammo box at Cabelas for $14 that it just fits in with the battery on the bottom and bilge disconnected. It is a tight fit but it is pretty compact with a nice handle on it too.
Tue Jan 07, 2014 12:00 pm |
CLICKSTER
i have three of the duck butt pulsers on hidgeon and two i made. i put mine in a milk crate. two fit perfect in a milk crate with everything and sits in the boat without getting beat up. plus the milk crate works for a pretty good seat in the marsh.
Tue Jan 07, 2014 1:55 pm |
mudslut
Joined: Mon Dec 06, 2010 6:54 pm Posts: 2061 Location: Natchitoches,La
I got a green Plano tub from Walmart it holds all my mojos and stuff. Has 4 snaps on the lid think I paid $30 for it.
Sent from my iPhone using Smoke Signals
_________________ 1646 Gatortail dragging a stage 1 GTR
Tue Jan 07, 2014 2:23 pm |
mudslut
You can see it in this pic
Tue Jan 07, 2014 2:24 pm |
diddyduck
they got some smaller ones like that at academy^^
Tue Jan 07, 2014 3:27 pm |
WIpool7
Joined: Wed Feb 29, 2012 9:54 am Posts: 42 Location: Trempealeau, WI
Buy two more and use a 6-slot decoy bag, alternate battery boxes in one side and butts in other. I've had mine this way for 3 seasons without any problems.
_________________ I drink the KOOL-AID! Hunting Rig-'12 Gatortail 1860 Extreme pushed by a '12 35gtr STAGE II Fishing Rig-'13 Gatortail 1860 Extreme pushed by a '13 35gtr STAGE II
Tue Jan 07, 2014 7:24 pm |
