Ideas for a Higdon Pulsator 2 decoy bag
http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=8&t=47173
Author:  RWRiverRat [ Thu Nov 07, 2013 10:38 pm ]
Post subject:  Ideas for a Higdon Pulsator 2 decoy bag
I just got a Higdon pulsator 2 decoy and I am looking to find/make a case for it. If you have any ideas let me know
Author:  Bigbuckfever [ Thu Nov 07, 2013 10:47 pm ]
Post subject:  Re: Ideas for a Higdon Pulsator 2 decoy bag
Edit: i misread
Author:  diddyduck [ Thu Nov 07, 2013 10:48 pm ]
tackle box or smaller tool box
guessing your talking about for in the boat? or does it have to go in the water or something?
Author:  Bigbuckfever [ Thu Nov 07, 2013 10:52 pm ]
I just store mine in a rubbermaid tote. Holds three swimmers and a butt in a standard sized one. In the boat i just take them out of the you're and stick em in to whatever space is available. Boxes in the boat take up too much space for me. They're very durable.
Author:  RWRiverRat [ Thu Nov 07, 2013 11:02 pm ]
They seem to be put together pretty well except for where the pump connects to the bottom of the decoy. Has that broken on you ever? That is really the only part I'm worried about
Author:  Bigbuckfever [ Thu Nov 07, 2013 11:08 pm ]
No. The higdon I've got is the swimmer, but it should be attached the same. The rest i built off that design. I've had it for 2 years getting beat up in boats and the bed of my truck sometimes and not one issue yet.
Author:  petrel [ Fri Nov 08, 2013 5:13 am ]
The pulsator is a great addition to a hunting spread and Higdon is a good company to work with. However, the pulsator is not as rugged as it would initially appear. You need to handle it with care or your will end up replacing connections. Putting a loop in the cable at the pump and zip tying it to the pump housing can save a failure there. If you are going to run it in deep water, buy the extensions to avoid fatiguing the connections.
The less you handle them and bang them around the better. I carry mine in a rubbermaid tub with the hook in the hose used to hang the decoys over the side of the tub and the battery packs stacked in the bottom of the tub.
Author:  tinman454 [ Fri Nov 08, 2013 8:52 am ]
Two seasons on mine put a pice of foam in the bottom of a Rubbermaid tote also works good.
Author:  cajun1085 [ Fri Nov 08, 2013 11:24 pm ]
I have 2 pulsators, I just throw them in the boat and don't worry about it. They are well built. I don't have a lot of room for extra boxes.
Author:  Migrator [ Fri Nov 08, 2013 11:54 pm ]
I have been carrying mine around in a zipper tool bag & small duffel bag for several years. Old series motor played out on the first. Higdon is very helpful and CS was awesome.
Author:  lilfukr79 [ Sun Nov 10, 2013 12:02 pm ]
Throw mine in a 5gallon bucket then in the boat, battery on bottom. Never any troubles after 2 seasons.
Author:  RWRiverRat [ Tue Jan 07, 2014 12:00 pm ]
I found a ammo box at Cabelas for $14 that it just fits in with the battery on the bottom and bilge disconnected. It is a tight fit but it is pretty compact with a nice handle on it too.
Author:  CLICKSTER [ Tue Jan 07, 2014 1:55 pm ]
i have three of the duck butt pulsers on hidgeon and two i made. i put mine in a milk crate. two fit perfect in a milk crate with everything and sits in the boat without getting beat up. plus the milk crate works for a pretty good seat in the marsh.
Author:  mudslut [ Tue Jan 07, 2014 2:23 pm ]
I got a green Plano tub from Walmart it holds all my mojos and stuff. Has 4 snaps on the lid think I paid $30 for it.
Sent from my iPhone using Smoke Signals
Author:  mudslut [ Tue Jan 07, 2014 2:24 pm ]
You can see it in this pic
Author:  diddyduck [ Tue Jan 07, 2014 3:27 pm ]
they got some smaller ones like that at academy^^
Author:  WIpool7 [ Tue Jan 07, 2014 7:24 pm ]
Buy two more and use a 6-slot decoy bag, alternate battery boxes in one side and butts in other. I've had mine this way for 3 seasons without any problems.
