It is currently Sat Jul 05, 2025 9:59 am
Reply to topic  [ 10 posts ]
 GDSD lower unit rattle
Post GDSD lower unit rattle
The silver circular piece that is in the house but closest to the prop is loose and moving around. I'm doing a terrible job of explaining but it's right behind the u - joints. When I'm running the motor, it sort of rotates and it rattling. Also, I can tell that grease from pressure filler is overflowing back into the housing. Is there any way to reseat that silver piece? I have about 174hrs on the motor and have always greased and what not but have replaced the bushings or seals. if you grab the prop, it'll move just slightly. Not badly like I have seen some people w blown seals.
2013 1660 Go-devil w 35gdsd
Tue Apr 14, 2015 8:10 am
Post Re: GDSD lower unit rattle
By not replacing seals you have additional wear on your bushings and possibly shaft too....
Movement indicates bushing issues - bad seals alone won't cause that....
Good news $100 will get you all your parts - call GD with serial number in hand as they require
that when ordering parts - rent the specialty tools from GD too or find a good GD dealer to
help you out....
Eat - Sleep - Hunt ! ! !
Tue Apr 14, 2015 8:24 am
I would call Go Devil and ask them. If it's something you can fix they will tell you how to do it. or they can get the part or parts on the way.
Not sure what to tell you. I gotta call them myself about a seal that needs replacing. Mine is starting to leak at the end of the shafts before the prop. Mine has been in use since 2005.
18x48 GDSD boat
Gig what tools are needed to replace the seal inside the stainless piece at the end of the shaft?
18x48 GDSD boat
Tue Apr 14, 2015 8:27 am
sounds good. what do you think it would cost if i got them to do it? or is it pretty straight forward? i just dont want to f-it up
Tue Apr 14, 2015 8:33 am
1542 stuck to a 27mini. She gone.
1746 with a modded 35 gdsd
Capt Team total asalt
Tue Apr 14, 2015 8:43 am
Tue Apr 14, 2015 8:45 am
Tue Apr 14, 2015 8:46 am
you think i could get them to do it for 300 total? w labor? im just pressed for time these days with my job.
Tue Apr 14, 2015 8:49 am
I'm fairly handy with a wrench so I will tackle it soon. Gig I seen that tool your talking about at Go devil. When I'm in La. I stop by and get Warren to buy me lunch.
18x48 GDSD boat
Tue Apr 14, 2015 6:42 pm
Users browsing this forum: No registered users and 56 guests
