It is currently Sat Oct 03, 2026 2:18 pm
Reply to topic  [ 25 posts ]
 Beretta A300 Outlander reviews?
Post Beretta A300 Outlander reviews?
I have eyed this gun for the last two seasons and look like a great buy for an entry level semiauto. Any field reviews? I have a five year old 3901 Citizen that has been solid and I need a companion semiauto.
Sun May 17, 2015 5:09 am
Post Re: Beretta A300 Outlander reviews?
Bought mine in Nov 2012. No complaints here. Shoulders really well for me with the extra 1" spacer.
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Sun May 17, 2015 8:52 am
Nice shooter but the finish sucks. Would be a good candidate for cerakote if you hunt hard
1850 & 36pd
Sun May 17, 2015 2:06 pm
- Mark Twain
Sun May 17, 2015 2:15 pm
Thanks. We get a mess of rain, but I don't hunt the salt, I can do without the camo's xtra 100$ cost. Just can't justify the twice the price A400. 3" shells are plenty for black jacks, teal, woodies, and mottleds.
Sun May 17, 2015 4:31 pm
My younger brother bought one this past fall, I shot it a few times and was impressed with it... He does alot of upland bird hunting and like it really well.
1436 Lowe
Tue May 19, 2015 11:54 am
I never shoot 3.5" shells but I absolutely love the A400. It is a great gun. I have only handled the gun in question but I am a huge Beretta fan and it looks to me to be a nice gun. I see no reason that it cannot do everything you would need as a waterfowler.
Wed May 20, 2015 6:46 pm
This shotgun worked like a champ!!! I bought it last year after returning from North Dakota on a pheasant. I was a little upset with a few things and had been wanting a Beretta for a while and decided to go ahead and get one. As I said above it worked like no other semi-auto shotgun I have ever shot and since it is a gas operated gun very little kick and through in the Kent fast lead number 4s it was nothing but a winning combination!!!
___________________________________
Thu Jun 25, 2015 12:07 am
Profile YIM
Has anyone ever their outlander not cycle? Mine is firing, ejecting the spent shell, then the bolt gets stuck halfway as its loading the second round. I've been through the gun in and out. it almost seems like the loading tray is stopping it. Any input?
Sat Aug 08, 2015 6:44 pm
If you have cleaned the receiver and bolt assembly thoroughly and it is still a problem, a likely culprit is the recoil spring in the stock. It is often neglected, and vital to the operation of the gun. Make sure it is clean and free of obstruction, and also make sure that it hasn't become compressed if you have shot it a lot.
24x60 Dual Prodrives
Sun Aug 09, 2015 10:29 am
The a300 comes with two gas Pistons that interchange for light and heavy loads. If the piston for heavy is installed light loads will not cycle and do exactly what your talking about!
Stock 35gdsd skidding 1654gd
Sun Aug 09, 2015 11:53 am
Sun Aug 09, 2015 11:54 am
Sun Aug 09, 2015 1:31 pm
Sun Aug 09, 2015 1:36 pm
Sun Aug 09, 2015 6:54 pm
Mon Aug 10, 2015 2:34 pm
Mon Aug 10, 2015 6:38 pm
It's not difficult to figure out if you at least have the mechanical aptitude of a 4th grader. Pretty self explanatory. You'll need a long ratchet extension to reach the nut that holds the stock on. And pay attention to the orientation of the shim that goes between the stock and receiver when you take it off. Just make sure the spring is in good shape, and there is no fouling or corrosion inhibiting free movement. Once again, it can get compressed over time and cause the symptoms you are seeing. But that is after many thousands of rounds. It's very cheap to replace.
Mon Aug 10, 2015 8:59 pm
When you free it remember it is a SPRING and will probably want to fly across the room, or into your face, so be careful. Seems odd that it would be the spring but it definitely is a possibility and cheap to replace so worth a check. The spring that is in the magazine tube is another possibility for causing issues and that should be able to be removed and cleaned as well.
Do you see any wear marks on any of the parts and pieces?
Tue Aug 11, 2015 5:28 am
Tue Aug 11, 2015 6:32 am
I have not checked for the outlander but for all their other guns Beretta has a step-by-step breakdown on YouTube for each component.
Tue Aug 11, 2015 6:50 am
Tue Aug 11, 2015 7:14 am
One thing to make sure of is that you don't set the gun stock down in water being that the spring goes down into the stock. Mine got wet when wading across a pond and I hit a deep hole. Took it all apart. Carefully cleaned the spring and spring compartment and wiped a light coat of oil on the spring and in the compartment. I wasn't having and cycling issues but I wanted to make sure the spring didn't start to rust or anything after getting wet
"The internet"
Tue Aug 11, 2015 1:30 pm
Once dropped mine in a muddy pond, fished it out and it cycled perfectly for the rest of the day. Got home, cleaned it, and never had a problem.
1644 GoDevil 35 hp GDSD
Wed Aug 03, 2016 8:20 am
Did you break it in with a 3" magnum load? I would look into a sure cycle also, put one in my 390 after the factory spring rusted up. Never had issues after that
Thu Aug 04, 2016 7:33 am
