It is currently Tue Dec 16, 2025 3:29 pm
Reply to topic  [ 22 posts ]
 48watt (eBay) led light wiring question
Post 48watt (eBay) led light wiring question
Does anyone have any experience wiring these lights up? I'm using 10 gauge wire and wiring them up in series (12total) and the lights are humming. Very annoying sound! They're only supposed to draw about 4 amps each. I tried running just 3 lights and still a humming sound but with only 2 lights wired up it is quiet? Any help is appreciated :)
1960 uncle j gtr35
Sun Jan 17, 2016 1:40 pm
Post Re: 48watt (eBay) led light wiring question
Are the wires hot?
Sun Jan 17, 2016 4:40 pm
Not at all. I'm thinking the battery I'm using is goin to shit. It's a new boat I'm tryin to get setup and threw an old battery in to test everything. I'm gonna get some new batts next week and see if that cures the problem
1960 uncle j gtr35
Sun Jan 17, 2016 5:08 pm
I ran tiny little wire. Like 18 ga to all 12 of mine, and no humming. Wires never got hot etc.
IDK what to tell you. It's probably not the wire. Either the lights or the battery.
Kool-Aid Brigade
www.southernfowler.com
Tue Jan 19, 2016 9:49 am
I got new batteries and will try them tonight and post results
1960 uncle j gtr35
Tue Jan 19, 2016 11:22 am
(12) 48 watt lights = 576 total watts/12 volt supply = 48 amps total
10awg is plenty big enough, you can run 145' of that gauge for that load
16awg would be ideal, good for 35'
18awg is fine as long as the total line length is less than 23' (fyi)
If it still does it with a fresh battery, it's the lights themselves.
Tue Jan 19, 2016 11:43 am
1754 prodigy- stage 2 GTR
Tue Jan 19, 2016 1:39 pm
Tue Jan 19, 2016 2:42 pm
Cool info. I'm not a math person myself. I'd just have to give the wiring a blind shot. If it produced fire then I would know to go a different route :lol:
1850 & 36pd
Tue Jan 19, 2016 3:17 pm
Second thought, probably not the battery, most LEDs are good for 9v-36v
Tue Jan 19, 2016 3:23 pm
3rd coast killer... Is your lights on a 12 or 24 volt system?
1960 uncle j gtr35
Tue Jan 19, 2016 4:23 pm
They still humm with new batts
1960 uncle j gtr35
Tue Jan 19, 2016 6:26 pm
Kool-Aid Brigade
Tue Jan 19, 2016 7:21 pm
Do you have them on a switch? If so take the switch out and connect straight to the battery and see if that makes any difference.
Tue Jan 19, 2016 8:18 pm
Ya I tried that. I eliminated the relay and breaker too. I emailed the eBay supplier and they said to wire up each light individually instead of in series. Gotta get more wire tomorrow and try that.
1960 uncle j gtr35
Tue Jan 19, 2016 8:32 pm
Well that sucks. I would like to know what the voltage drop was when adding each light while in series. I have run 4 on a 14 foot run of 12awg before with no problem but I didn't check voltage.
Tue Jan 19, 2016 9:03 pm
Series or parallel? Series wiring would not make much sense.
Tue Jan 19, 2016 9:17 pm
Good point CB ... Pigglet you did run + and - wire to each light and wire them red to + black to - right?. And CB just to be clear I wasn't referring to a series circuit just to a series of lights or a row of lights. I know what it looks like but that wasn't what I meant.
Tue Jan 19, 2016 10:06 pm
Ya I ran a 10g power and ground to them. I didn't run 2 wires back to the relay from each light just 2 wires along the deck and spliced in the lights on those 2 wires. That's what I mean by series
1960 uncle j gtr35
Wed Jan 20, 2016 5:57 am
Could it just be the light. I have a light bar that does the same thing. I've never had any issues, I can only hear it when there is no noise around. Usually it's not even noticeable.
Wed Jan 20, 2016 6:04 am
It could be. My light bar doesn't do it and my old boat had the 50watt customfitz LEDs and they were quiet
1960 uncle j gtr35
Wed Jan 20, 2016 6:39 am
The lights are finally quiet! I had to put 2 lights on 1 circuit so now I've got 6 sets of wires running up to the deck for lights. Not sure why having 3 on a circuit made them humm but it does. Cheap Chinese lights I guess. Thanks everyone for all your help
1960 uncle j gtr35
Wed Jan 20, 2016 7:00 pm
