| Only casualty http://www.mudmotortalk.com/mmt_v2/viewtopic.php?f=84&t=53976 |
| Author: | dguidry [ Sun Jun 15, 2014 4:17 pm ] |
| Post subject: | Only casualty |
Noticed this when I stopped for gas. image.jpg |
| Author: | DUCK HEARSE [ Sun Jun 15, 2014 4:18 pm ] |
| Post subject: | Re: Only casualty |
Nothing a tie strap won't take care of |
| Author: | Smoke [ Sun Jun 15, 2014 4:50 pm ] |
So how did the pick up band do? Gosh I wish I over closer than a 1000+ miles I woulda loved to go on the caddo run. |
| Author: | dguidry [ Sun Jun 15, 2014 6:04 pm ] |
| Author: | BAG Hunter [ Sun Jun 15, 2014 6:38 pm ] |
What happened to the wood boat? |
| Author: | dguidry [ Sun Jun 15, 2014 6:48 pm ] |
| Author: | baron von [ Sun Jun 15, 2014 8:43 pm ] |
nice |
| Author: | dguidry [ Thu Jun 19, 2014 9:34 am ] |
You know, this is the third bracket that has broken on my motor. The last two broke from accidentally trimming down with it while it was still on. I'm thinking all that traveling I did on the way back from Caddo might have engaged the trim switch a bit which caused this latest break. I looked back a few times and noticed my tiller handle was flopping all over the place up and down. Its pretty loose and mover freely. The repeated bouncing may have caused the switch to engage ever so slightly each time it hit bottom on a bounce. Not sure but maybe that's what happened. Anyone come up with an alternate solution to the bracket besides ratchet straps. |
| Author: | North LA Hunter [ Thu Jun 19, 2014 9:36 am ] |
I broke mine on my last one at about 100 hrs. I need to build a carbon one so it won't bend like the alum one does. Sent from my beeper |
| Author: | baron von [ Thu Jun 19, 2014 9:40 am ] |
That sounds plausible Dean-O but probably not very possible – most likely metal fatigue on the aluminum from the bouncing incurred while trailering? |
| Author: | baron von [ Thu Jun 19, 2014 9:51 am ] |
has anyone tried a support from the trailer with GTs, or does anyone see any problems with transporting a GT in this manner? |
| Author: | gfowel [ Thu Jun 19, 2014 10:31 am ] |
I broke mine in the second week of use. Just made one out of thicker material. It's a little harder to get it on but it works. |
| Author: | basinhunter2012 [ Thu Jun 19, 2014 11:01 am ] |
| Author: | deltaduckmaster [ Thu Jun 19, 2014 11:08 am ] |
Stop trimming it so tight. That how you stop that. Snug it up and that it Sent from my iPhone using Tapatalk |
| Author: | baron von [ Thu Jun 19, 2014 11:19 am ] |
good to know - thanks for the tip DDM! |
| Author: | OwenDickeson [ Thu Jun 19, 2014 12:00 pm ] |
Yup just snug it up. Not so tight it sounds like the trim is in a bind. I had no problems out of mine and it definitely made some miles on the trailer. Sent from my XT1080 using Tapatalk |
| Author: | MarshJB [ Thu Jun 19, 2014 12:07 pm ] |
| Author: | mizzippi jb [ Thu Jun 19, 2014 4:22 pm ] |
Mines made out of steel flat bar with hydro turf on the inside. Stout. Sent from my SM-G900V using Tapatalk |
| Author: | MarshJB [ Thu Jun 19, 2014 4:23 pm ] |
| Author: | mizzippi jb [ Thu Jun 19, 2014 4:30 pm ] |
