It is currently Mon Jul 21, 2025 11:24 am
[ 6 posts ] |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
 Hull bracing
I have an older allwelded hull. It has longitudinal braces but not cross braces. The bottom of the hull is slightly concave between the braces but It appears the braces are still level left to right. My question for all you boat builders and others, do I need cross braces or is the hull still gonna bend between those braces over time with hitting logs etc?
Fri Jan 14, 2011 6:09 pm |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
 Re: Hull bracing
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
Fri Jan 14, 2011 6:17 pm |
dfou
 Re: Hull bracing
I guess the better question is, do the bends hurt performance etc? I know hooks front to back are bad
Fri Jan 14, 2011 7:06 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
 Re: Hull bracing
Its one of those things that we have to see.... the concave affect shouldnt hurt your running.. Though, if it is flexing it WILL break your welds at some point..
Sat Jan 15, 2011 7:47 am |
dfou
 Re: Hull bracing
Question for you Uncle J, if I decide I want the hull "fixed" what's the solution? Do I beat the hull flat and hve braces added or is it better to cut off the bottom and let u put me on a new 3/16 one? Or is that more expensive than it's worth?
Sat Jan 15, 2011 7:17 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: Hull bracing
Just beat it straight and add some ribs. Its more work putting a new bottom on a boat than building one from scratch. I actually pulled the double bottom out of my boat today and beat a bunch of hooks out of it. Ill be adding some bracing in between every brace thats in there.
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
Sun Jan 16, 2011 5:58 pm |
[ 6 posts ] |
Users browsing this forum: No registered users and 162 guests |
