WestEndAngler
MMT Moderator
 SOB!!!
I'm driving home about 1/2 mi from the house and come to crossover to get into my neighborhood, now just blocks from the house. Stop and let a lady cross with a dog. Apply the gas & KABOOOM!!!! I come to instant stop, rear end is locked up! AAA just took my truck to the dealer. To add insult to injury a guy trying to follow me across unaware that I was trying to get the disabled truck out of the road hits me as I find out I can only go 3' forward until instant stop... He rear ends me backs up flips me off then takes off. I only got the first 3 of his license plate but have seen his truck in the neighborhood. Man I'm heated. Right before duck season and no truck! Did you know rentals come without a hitch so you can't pull anything?! My buddy who I'm taking tomorrow luckily has a truck so we are good for tomorrow but DAMN!
| Fri Nov 04, 2011 4:50 pm |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
 Re: SOB!!!
Go rent a pick up from u haul!
| Fri Nov 04, 2011 4:55 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Fri Nov 04, 2011 4:58 pm |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: SOB!!!
unless its under warranty DO NOT put the factory unit in it!!!! go with a detroit tru trac. http://www.eaton.com/Eaton/ProductsServ ... PCT_221471
_________________ I gave up mud motors
| Fri Nov 04, 2011 5:09 pm |
BradS
Joined: Wed Jan 14, 2009 5:23 am Posts: 4514 Location: Lafayette, La
 Re: SOB!!!
Enterprise rents trucks you can tow with,
I think they are all 3/4 ton diesels
| Fri Nov 04, 2011 5:19 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
 SOB!!!
Damn the luck..
Brothers stealing rims and tires, and transmissions going out.. Damn the bad luck.
Just remember... Jesus doesn't through anything in your path which you can't handle.
Rev. Uncle J
| Fri Nov 04, 2011 5:23 pm |
WestEndAngler
MMT Moderator
 SOB!!!
| Fri Nov 04, 2011 5:26 pm |
T-Bubba
 Re: SOB!!!
the stock differential in GM half tons is garbage. It is made by eaton and it has clutches... they are known to blow up at any givin time.
| Fri Nov 04, 2011 5:30 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Fri Nov 04, 2011 5:32 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
 Re: SOB!!!
Put a set of Dana 60's in it and be done.
_________________ Put yer face in the myrtles.
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Fri Nov 04, 2011 5:33 pm |
T-Bubba
 Re: SOB!!!
dont let the stealership fix it... bring it to your buddies shop and have him put in a true trac.. you wont break it this is what you need... with new carrier bearings http://www.performanceoffroadcenter.com ... cts_id=908
| Fri Nov 04, 2011 5:52 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
Had a tow truck pick up the Tahoe today from the dealer. He took it out to the Katy area to Lonestar Ring & Pinion. Actually an old higher class guy that I knew way back 13 years ago.
He already inspected the locker, ordered me new parts & said I can come pick it up Friday!
| Mon Nov 07, 2011 1:02 pm |
MaXXis85
 Re: SOB!!!
GM half ton Locker/ posi units are GARBAGE. They all will eventually fail. Towing makes them fail faster or abuse.
| Mon Nov 07, 2011 1:05 pm |
BROOKS
Joined: Tue Jan 13, 2009 9:46 pm Posts: 4596 Location: East TEXAN Proud
 Re: SOB!!!
_________________ Git a Gator-Tail or ride in mines wake ...... MtrFact !!!!! '05 Model .... Still Number One on the Water !!!!
| Mon Nov 07, 2011 1:11 pm |
MaXXis85
 Re: SOB!!!
| Mon Nov 07, 2011 2:05 pm |
The Shafer
Joined: Tue Jan 13, 2009 7:46 pm Posts: 1947 Location: Longview. TX
 Re: SOB!!!
_________________ WC 1848 Bateau w/ 36 PD FPR
| Mon Nov 07, 2011 2:15 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
Well I tow a 22' Robalo with my truck & my 1860 all over the place... I bet my Tranny is next
| Mon Nov 07, 2011 2:25 pm |
BROOKS
 Re: SOB!!!
Thanks Marcus ..... That educated me somewhat !!!  Prudy dawg-gone amazin' mechianical marval the rear end is. Mines 1/2 ton Chevy "clanks" in the rear end from time to time .... so far I just been turnin' up on the radio ......
| Mon Nov 07, 2011 2:56 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Mon Nov 07, 2011 3:00 pm |
BROOKS
 Re: SOB!!!
| Mon Nov 07, 2011 3:05 pm |
MaXXis85
 Re: SOB!!!
The clanking is the locker doing it's thang. When it goes Kaboom, its One HELL of a clank!!!!! That is when you slap a Truetrac and rock on. My 1/2 ton I installed a trutrac and loved the damn thing. It works well!
| Mon Nov 07, 2011 3:07 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Mon Nov 07, 2011 3:16 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
Marcus, my 10bolt had a GovLoc lock in there.
| Mon Nov 07, 2011 3:22 pm |
MaXXis85
 Re: SOB!!!
WHen they become like a Full detroit, Usually something brke and is causing it to Remain locked. then eventually boom. Run them till they break, and replace them with a better unit. Most likely the Ring and pinion will need replacing too. Heck when Bubba blew his it took out his tranny too from the shock load!
| Mon Nov 07, 2011 3:26 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Mon Nov 07, 2011 3:32 pm |
MaXXis85
 Re: SOB!!!
WHat unit are they using? Not a factory replacement?
| Mon Nov 07, 2011 3:33 pm |
WestEndAngler
MMT Moderator
 Re: SOB!!!
| Mon Nov 07, 2011 3:35 pm |
MaXXis85
 Re: SOB!!!
THe zip locker is an Air locker, The yukon Duragrip is their clutch based LSD. You will need an air compressor for the Zip locker or it will be one Expensive ass Open carrier.
| Mon Nov 07, 2011 3:47 pm |
WestEndAngler
MMT Moderator
 SOB!!!
Ok maybe I heard him wrong I caught Yukon dura grip sounds right.
| Mon Nov 07, 2011 4:13 pm |
Migrator
Joined: Sun Apr 17, 2011 2:29 pm Posts: 3227 Location: Black River, MS
 Re: SOB!!!
Gottdang raggledy-azz Bowties. Ya'll get a real truck to tow w/ if'n you gonna pull a trailer.
_________________ WC CUSTOM 20X54 Battleship w/ Gator Glide Pushed & Pulled hard by an HDR!
Don't be scared...Hit It and Hold It!!!
| Mon Nov 07, 2011 6:39 pm |
T-Bubba
 Re: SOB!!!
the yukon dura grip is basically just like the stock unit... DONT DO IT
| Mon Nov 07, 2011 7:11 pm |
MaXXis85
 Re: SOB!!!
| Wed Nov 09, 2011 11:32 am |
WestEndAngler
MMT Moderator
 Re: SOB!!!
Marcus, what type of break in am I talking here?
I have heard from a few people to either do A or B.
A. 15 mi driving to heat it up. Let completely cool. Do this 3x and then change the oil.
B. Drive 500 miles normal driving, avoiding excessive acceleration etc. then change the oil.
During the break in, can I pull a trailer?
Saturday & Sunday can I haul the GTR down to the coast 60 miles and go hunt?
| Wed Nov 09, 2011 11:37 am |
MaXXis85
 Re: SOB!!!
| Wed Nov 09, 2011 11:42 am |
WestEndAngler
MMT Moderator
 Re: SOB!!!
So I should probably drive to Dallas & back Friday before towing my vehicle...  Looks like I'll have to borrow a car again from someone
| Wed Nov 09, 2011 11:44 am |
MaXXis85
 Re: SOB!!!
WHen you tow you flex the teeth and will start to breakin a new portion of the ring and pinion so Its best to tow lightly after you do the intial breakin. Honestly I dont see an problem latching onto the boat as it dosent weigh much. Just stop say halfway and let the diff cool for a bit then finish your journey. Vary speeds and keep them under 60 MPH during breakin.
| Wed Nov 09, 2011 11:50 am |
BROOKS
 Re: SOB!!!
Ya'lls fo real ??? Why don't you have to break in a factory one ???
MaXXis85
 Re: SOB!!!
Most normal people baby a new truck anyway for a few hundred miles.. THe first 15 -20 mile are the most inportant then take it easy..
| Wed Nov 09, 2011 11:55 am |
kibb
 SOB!!!
I thought everyone put them through hell during the first 30 min while test driving. Lol.
| Wed Nov 09, 2011 12:00 pm |
