It is currently Sun Jul 20, 2025 9:27 pm
Reply to topic  [ 21 posts ]
 Go-Devil 23 SD Leaking Oil From Belt Housing?
Post Go-Devil 23 SD Leaking Oil From Belt Housing?
I have a 2011 Go Devil 23 SD with about 20 hours on it. I was running out this morning and (unknowingly) had fuel leaking out from just below the small white plastic fuel filter at the engine. The motor started running strangely, backfired once and then died when I let of the throttle. I looked things over, found the leak and tightened the hose clamp, re-primed the engine and fired it up and headed on my way.
When I got back to the the boat ramp I noticed what appeared to be oil leaking out from the starboard side belt housing vent ? I am pretty new to the whole mud motor thing and really have no idea what is causing this or whether it is safe to run the motor with this happening? Anybody here have any idea what might be happening?
Sat Nov 19, 2011 1:52 pm
Post Re: Go-Devil 23 SD Leaking Oil From Belt Housing?
Open the drain plug and see if you have water in the housing. Duckdon
Sat Nov 19, 2011 8:45 pm
I did, no no water and no oil came out of the drain plug...
Sat Nov 19, 2011 11:26 pm
No water... How is the oil level in the motor? Notice any loss of oil in the engine? I am guessing the shaft seal between the block and the belt housing is bad. I would suggest that you take it back to the dealer and have it checked out. With only 20 hours my guess is that it came defective from the Briggs factory. It should be covered under warrenty. Duckdon
Sun Nov 20, 2011 12:55 pm
It is definitely oil, the engine oil level has gone down a bit since I started noticing the leak. I guess there is some sort of drive shaft seal in there that must be leaking. Is this a common problem? How big of a job is the repair?
Mon Nov 21, 2011 7:05 am
Take the inspection plates off of the rear of the belt housing and make dern sure it is oil in the belt housing. It is normal for black powdered rubber to come out of the vent hole.
I lost a bolt holding the rear plate on the engine (the actual engine not the belt housing). It was leaking oil so bad you would swear it was coming from everywhere. It could very well be the same thing, a bolt on the engine come loose and allowing the oil to come out.
So check the engine bolts and takes those plates off and hollar back at us with your findings.
snakebreaker
Mon Nov 21, 2011 7:50 am
These bolts
snakebreaker
Mon Nov 21, 2011 7:55 am
If those bolts are tight and you in fact discover oil in the belt housing then I would say the rear seal on the engine is phugged and you will need to replace it.
snakebreaker
Mon Nov 21, 2011 7:57 am
All of those bolts look to be fine. There is motor oil (not belt residue/water/other) coming out of this vent hole;
Mon Nov 21, 2011 11:38 am
If you say there is no doubt about it being oil coming out of that vent hole then the only way it can get in there that I know of is the rear seal of the engine has failed and allowing oil into the housing. I don't see how it could get there any other way.
snakebreaker
Mon Nov 21, 2011 12:59 pm
I would still pull that rear inspection plate and see what your working with inside before I did anything.
snakebreaker
Mon Nov 21, 2011 1:00 pm
The red is the bolt that rattled out of mine. Is this a dirt and oil mixture circled by the blue?
snakebreaker
Mon Nov 21, 2011 1:04 pm
I would have to agree with pintail I think it is coming from the rear cover on the engine. Fortunately mine was fixed with a bolt and the gasket was ok.
snakebreaker
Mon Nov 21, 2011 3:13 pm
Mon Nov 21, 2011 9:41 pm
Mon Nov 21, 2011 9:45 pm
There is no other oil in a GDSD - except motor oil....
The lower pulley and U-Joints have a small amount of grease
inside them - but the outdrive is basically a hollow box....
You most likely have a bad case gasket or shaft seal on your
motor which is leaking motor oil - or a loose bolt as has been
suggested.... My Briggs case gasket began leaking at 100 hours
so I had GD replace it under the Briggs warranty... Sure a lawn
mower shop could do it but they likely would not be familiar
with re adjusting the belt....
Take it to GD !
Eat - Sleep - Hunt ! ! !
Mon Nov 21, 2011 9:55 pm
It has to be one of the two. Now with it coming out of the vent in two or three streams I would bet money it is the shaft seal.
snakebreaker
Tue Nov 22, 2011 3:49 am
If the case gasket is the culprit, how would that oil find its way into the belt housing and out of the vent hole?
Tue Nov 22, 2011 6:37 am
When My gasket was leaking I found oil everywhere even on the front of the engine cover.
Have you taken the rear cover off and looked yet? We will be guessing until you take that cover off and look.
snakebreaker
Tue Nov 22, 2011 7:21 am
Tue Nov 22, 2011 12:59 pm
I was not aware of any sort of safety mechanism protecting the engine from a low oil malfunction? Is there really such a shut off mechanism?
If that is the case, I can just keep some oil handy and top it off when it gets low. All the oil slinging around will help prevent corrosion :lol:
Tue Nov 22, 2011 2:07 pm
Users browsing this forum: Majestic-12 [Bot] and 106 guests
