It is currently Sat Nov 01, 2025 8:23 pm
Reply to topic  [ 22 posts ]
 Trailer Bunks
MMT Moderator
Post Trailer Bunks
Noticed some pitting on the bottom of the hull nothing major but it's only where the boat sits on the carpet for the trailer boards.
Will putting the plastic caps, like you see below prevent and slow down any future pitting etc. Any other design or product I should look at?
GTB 1860 w/ 2019 GTR40XD-HO
Tue Nov 22, 2011 1:28 pm
Post Trailer Bunks
Coe, I'm using the bunk slicks made by tie down engineering. Had them on my old rig and now on my new one. No problems with pitting on either hull.
Tue Nov 22, 2011 1:34 pm
MMT Moderator
Post Re: Trailer Bunks
Thanks. I'll get some slides to screw them into the bunk boards. I was looking at a few just haven't decided which direction I want to go.
Tue Nov 22, 2011 1:40 pm
You could always take the carpet off and put frog spit, steel flex, or gator glide on it. That's what I plan on doing.
Tue Nov 22, 2011 2:09 pm
Post Trailer Bunks
Check out the plastic deck boards at lowes. We been using em they work great and are about 20$
Tue Nov 22, 2011 2:22 pm
MMT Moderator
Post Trailer Bunks
Lowes and HD are my favorite stores lol
Tue Nov 22, 2011 2:44 pm
Lowes and Homedepot suck at life! You need to find you an Ace and a tractor supply! :lol:
Tue Nov 22, 2011 2:46 pm
MMT Moderator
Tue Nov 22, 2011 3:10 pm
Post Trailer Bunks
Just take the carpet off.
Tue Nov 22, 2011 3:13 pm
Take the carpet off the bunks the salt water will tear up a aluminum boat......if you think it tears up aluminum you should see what it does to fiberglass!!
Tue Nov 22, 2011 3:16 pm
will the carpet mess with the aluminum if its only in freshwater? just curious because i have no clue :)
1436 custom walked slowly by a 13hp Homemade LT.
The second amendment is what makes the first amendment possible.
Tue Nov 22, 2011 3:21 pm
Tue Nov 22, 2011 3:27 pm
Pick you up some plastic bunk board pieces. They help a ton when you have to deal with ice. I have them on my 1752 and I love them. I also bolted my bunk directly to the trailer frame. It lowered the boad 5+ inches so i dont even have to put my axle hubs in the water now.
:mrgreen:
Tue Nov 22, 2011 5:13 pm
I have those on mine WEA and love em. No more pitting since I put them on. Took about 30 mine to install. Easier on and off the trailer too.
Wed Nov 23, 2011 8:49 am
When yall use the plastic deck boards do yall coat them with anything or just bolt them on and do aluminum to plastic?
snakebreaker
Wed Nov 23, 2011 9:32 am
Maybe a sacrificial anode would help more then any thing.
"Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut." -- Ernest Hemingway
Life time member BAA http://www.bowfishingassociation.com/baa/Home.html
Life time member NFC http://www.carpbusters.com/
Life time member BASS http://www.bassmaster.com/
Wed Nov 23, 2011 9:53 am
Wed Nov 23, 2011 10:09 am
Wed Nov 23, 2011 10:27 am
8 foot sneak boat with 8hp go devil going Mach 1
Layout blinds and a whole bunch of decoys
Wed Nov 23, 2011 12:34 pm
Post Trailer Bunks
Wed Nov 23, 2011 5:04 pm
"Drop the Hammer"
Excel 1651 F4 with a Mud Buddy HD7000
Excel 1860 F4 with a Mud Buddy HD5500
Mon Dec 19, 2011 4:55 pm
I removed my carpet and installed plastic bunk covers made by Magic-Tilt because of corrosion. They were the most affordable ones I could find and you can cut them to length. You'll need to purchase little end caps for the bunks in addition to the covers but they are very inexpensive. I also installed battery switches on both of my batteries just to be sure there is no electrical current running through my hull that could cause electrolysis.
They have helped tremendously with corrosion but didn't stop it 100%. I think saltwater is just hard on unpainted aluminum but at least I'm not worried about pinholes leaks forming in the bottom of my boat anymore.
Tue Dec 20, 2011 2:18 am
