It is currently Thu May 15, 2025 2:01 am
Reply to topic  [ 13 posts ]
 This doesn't look good
Post This doesn't look good
What a day. 88* sunny and hot. See all total of about 20 ducks and ended up with 3 out of 5 shots. So decided to scout a bit on the way back in. Heard a thump and then smell 90 W gear oil. Look back and find MILK :(
Stephen Simpson
1462 3 man Gator Hide with a Hot Rodded 36PD FPR
Sun Nov 20, 2011 5:50 pm
Post Re: This doesn't look good
drain lu oil
remove prop
remove seal nut
replace with new seal nut
reinstall prop
add gear oil
run it like you stole it
Sun Nov 20, 2011 5:52 pm
"heard a thunk"? Did the case split? Gears lock up? Still running or what?
Sun Nov 20, 2011 5:56 pm
I have never seen oil hat white. Where did it come from.
Sun Nov 20, 2011 6:08 pm
18x48 Charles Leonard / 36PD
Sun Nov 20, 2011 6:10 pm
The lower seal was replaced with the new 3 seal nut about 6 weeks ago. Ran the motor with new 90W and drained it again refilled again with new 90W. This all came out of the top behind the cover for the clutch.
Oh and it didn't lock up. Eased it back to the ramp and onto the trailer.
Stephen Simpson
Sun Nov 20, 2011 6:20 pm
thats what just happened to mine. Lower seals went out, sucked in water, built up pressure and blew it out the vent which is by the clutch. Replace seals.
Sun Nov 20, 2011 8:30 pm
Sun Nov 20, 2011 8:33 pm
You should have bought a tall transom! You could have gotten at least 2 more hunts out of it! :lol:
Hate to say it, but you might have a worn prop shaft ( look for grooves where the seals ride the shaft). The plus side is you can upgrade to the newer grease filled LU! Its the schitt!
Sun Nov 20, 2011 8:36 pm
mine looks like the right now because i sucks some avery fast grass up. shit bogged my motor down. 30 minutes to cut it out
Sun Nov 20, 2011 8:39 pm
Stephen Simpson
Mon Nov 21, 2011 7:22 pm
Got the seal nut in yesterday and installed it last night. Filled with 90W and we're ready to go again.
Stephen Simpson
Wed Nov 30, 2011 9:07 am
Glad you back on the water, thankfully it was a fairly easy fix
Wed Nov 30, 2011 11:49 am
Users browsing this forum: No registered users and 133 guests
