msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Airboat help
I thinking of getting an airboat. I found a used 14x7 pathmaker with a 440SBC motor with 45 hrs. The seller is telling me that the motor puts out 600Hp.
My questions: Has anyone run this hull or know anything about it? How does it compare to a robicheaux hull? How will the engine hold up beings its a hopped up shortblock? How does the fuel consumption compare to a 454?
Thanks
| Mon May 21, 2012 11:04 am |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
 Re: Airboat help
go to airboattalk.com
_________________ Gator tail
| Mon May 21, 2012 7:21 pm |
msm8281
 Re: Airboat help
There is hardly anyone on that site.
| Mon May 21, 2012 9:51 pm |
Tony B
MMT Site Admin
Joined: Sat Jan 10, 2009 10:10 pm Posts: 2258 Location: Loreauville, LA
 Re: Airboat help
Yea, it's kinda empty in there Yall go and sign up, been trying to get it off the ground and it could be a very cool place just like MMT, just need members. Spread the word about it and it will grow
_________________ Tony Broussard Admin | Owner Admin | Owner Admin | Owner Admin | Owner Admin | Owner CEO | Graphic Details Digital Media
| Tue May 22, 2012 7:18 am |
Frogmaster33
Joined: Wed Nov 02, 2011 8:17 am Posts: 30 Location: South Louisiana
 Re: Airboat help
I'm going on 5 years working air boat now. Pathmacker hulls or ok theres nothing that can compare to a robicheaux hull that's number 1. Now the motor your better off getting something els and putting on there. A motor putting out that much hp belongs in a race car after 15 hours it needs to be rebuil. I've never seen them go over 100 hours. Don't get me wrong it well be bad ass if it hold up running in and out of 5 grand is not for that motor. Of course it's goin to burn more gas thin a 454 it's pushing 175 more hp. You'll be better not with that motor.
| Tue May 22, 2012 11:25 am |
msm8281
 Re: Airboat help
Yea, thanks...that is what I thought. I would really like a 14' with a 350 zz4.
| Tue May 22, 2012 2:26 pm |
MaXXis85
 Re: Airboat help
airboats motors should have alot of torque. Torque is made with displacement and stroke. Smallblocks work ok on a decent hull, But the Big Block shines in the torque department.
| Tue May 22, 2012 3:10 pm |
Frogmaster33
 Re: Airboat help
I got some friends that has boats with 350 on them and run circles around big blocks. You looking at 200 to 300lb weight different between 350s and big blocks in a airboat less weight is better. The big blocks shine when u can load it down and run. If all ur doin is hunting and froging the 350 is perfect easy on gas. it's all in the driver.
| Tue May 22, 2012 3:56 pm |
MaXXis85
 Re: Airboat help
Werd on weight. Look at a Lycoming 260Hp. It is a 6 cylinder, 540 Cubic Inches, and has over 500'# of torque. That will most of the time walk the dog over a small block and burn less fuel.
| Wed May 23, 2012 7:35 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: Airboat help
Those hopped up engines don't last long.
Nothing will compare to a Robicheaux. But I think those are decent hulls. I think dautrive and faucheux use them.
And yes a 260 or 300 lycoming is the way to go unless you want a big boat
_________________ I gave up mud motors
| Wed May 23, 2012 8:59 am |
Frogmaster33
 Re: Airboat help
When them aircrafts brake who you going to get to fix them if u know nothing about them. Them motors cost a pretty penney and the parts. U can go to any autozone and get parts for a automotive.
| Wed May 23, 2012 10:15 am |
msm8281
 Re: Airboat help
I'll stick to an automotive engine. I know several mechanics that'll work on for a case of beer. lol
| Wed May 23, 2012 10:44 am |
da go get'er
Joined: Wed Oct 27, 2010 8:30 am Posts: 3406 Location: Prairieville
 Re: Airboat help
_________________ 17*38 Klibert 23GDLT I toast to staying positive and testing negative!
| Wed May 23, 2012 11:00 am |
Frogmaster33
 Re: Airboat help
A lot of power line work the power lines are in the marsh or the swamp. Some surveying, the bp spill, now I'm do seismographing.
| Wed May 23, 2012 11:38 am |
brlcla
Joined: Tue Jan 13, 2009 5:11 pm Posts: 955 Location: Lake Charles, LA
 Re: Airboat help
Advice before you buy:
1. Decide what you will use it for and where as the environment makes a difference on power choice. 2. Decide on how many on average you will carry plus gear. 3. People will tell you small blocks are not made for airboats, but if the boat is built right they work fine... small blocks are for boats under 14' and less than 7.5' wide. 4. Shop around... lots of good used boats. Talk to American Airboats as they are in the business of not only building but buying and selling used boats and they are great people. 5. I own a small 12' American Airboat which I am currently dropping 170HP GM Ecotec onto which is currently being built in Florida so dont be afraid to think outside the box. You dont have to settle for the standard big block, small block, or A/C motors as they are dated... LS Smallblocks are great power plants and can make BB Tq in a small block format.
| Thu May 24, 2012 7:47 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
 Airboat help
What about the 500 caddy motor? Looking at a 16' glass boat with a direct drive. How does the direct drive set up do?
| Thu May 24, 2012 8:16 pm |
T-Bubba
 Re: Airboat help
Direct drive sucks.
Glass airboats suck. Save your money for a better boat
| Fri May 25, 2012 6:53 am |
msm8281
 Re: Airboat help
| Fri May 25, 2012 7:15 am |
T-Bubba
 Re: Airboat help
A zz4 350 set up right on a 13 or 14ft boat will run awesome
Mike do you know Jake Spangler. He has a 14ft with a zz4. Sweet running boat
| Fri May 25, 2012 7:29 am |
msm8281
 Re: Airboat help
I remember the name, I just can't put a face. My uncle had a 14' robiceaux with a 350zz4, so I know how they run. I wish I was instrested in an airboat 5 years ago when he sold it.
| Fri May 25, 2012 7:54 pm |
drake1
 Re: Airboat help
Here is my little 12' hull with a 65 hp motor. Turbo is next for more power. Video shot is with two 200 lb adults 2 40lb kids and a 50lb sack of crawfish bait. http://www.southernairboat.com/phpBB3/v ... 57&t=45431
| Fri May 25, 2012 9:09 pm |
