It is currently Sun Jun 16, 2024 10:04 am
Reply to topic  [ 182 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 gear vs belt driven motor (pro drive and go devil)
Post Re: gear vs belt driven motor (pro drive and go devil)
2-4-6-8 who do we appreciate..CALEN....CALEN.
Wed Oct 17, 2012 8:50 am
Wed Oct 17, 2012 8:51 am
Wed Oct 17, 2012 8:55 am
Wed Oct 17, 2012 8:56 am
I'm done there is no hope for you, hopefully you don't work on anybody's motor. you scare me
Wed Oct 17, 2012 9:01 am
Wed Oct 17, 2012 9:07 am
On our latest big project we have 4 solar turbines that are staged to produce 100 megawatts, im guessing they are not gonna be belt driven!!!
According to you fools, it would...i would love to see that!!! :lol:
Wed Oct 17, 2012 9:11 am
Wed Oct 17, 2012 9:14 am
Wed Oct 17, 2012 9:27 am
Correct....and in the mudmotor application belts ARE more durable than gears.
Wed Oct 17, 2012 9:31 am
Wed Oct 17, 2012 9:37 am
Either way a belt is cheaper and easier to replace
Wed Oct 17, 2012 9:40 am
Maybe you need to do some in the field study's. Mm related of course.
17x48 extreme stage 2 GTR
Wed Oct 17, 2012 9:42 am
Wed Oct 17, 2012 9:43 am
Wed Oct 17, 2012 9:54 am
300 hrs on mine with no problems..just sayin.
Wed Oct 17, 2012 9:56 am
So how often or how many PD's broke gears? If so, what happened?
Over 300 on mines, original gears...
Wed Oct 17, 2012 9:57 am
It's was a big issue a few years back. Nock on wood but I have put plenty hours in and never broke a belt. I no it has happened but just not to me
Wed Oct 17, 2012 10:02 am
Gears rust so anytime you get salt water in that lower unit the next thing you better be doing is tearing it apart. put salt water on gears, gears rust, gears fall apart, put salt water on rubber belt, belt stays the same, keep driving motor. Of course gears will take a while but they will fail in continous salt water applications. thats what happened to my buddies lower, the housing cracked and slowly leaked salt water in the caseing
Wed Oct 17, 2012 10:07 am
So did it fail from having salt water and corrosion, or did it fail from not having any fucking oil in the housing?
Wed Oct 17, 2012 10:10 am
Wed Oct 17, 2012 10:11 am
You too huh......had a small crack and was leaking water and he didn't know and finally it screwd up and when he pulled the lower and opened it up there was metal teeth all inside the case and rusted to hell, not a single sign it was fixing to happen it just happened. So 800 later he upgraded the lower
Wed Oct 17, 2012 10:13 am
I'm sure it was rusted, because it was full of salt water and not oil.
Wed Oct 17, 2012 10:15 am
Shit i forgot i was done with this but i like argueing. Point is gears suck belts are better, everyone knows that.
Wed Oct 17, 2012 10:16 am
Damn it sucks to think that everyone w/ out a gatortail that runs in saltwater is just on borrowed time.
Your such a fuckstick.
Wed Oct 17, 2012 10:17 am
Wed Oct 17, 2012 10:18 am
Wed Oct 17, 2012 10:27 am
Gears...I've knocked the hell out of quite a few rocks at WOT and don't have an issue with the gears. (To the point I will be tacking on another aluminum roll before long on the bottom of the skeg) I've seen a PD gear set lock up but it was due to poor maintenance and had water in the housing. I believe if you keep the oil clean and full, the gears they have now will last as long as you want to run it. Yes, PD undersized them in the beginning but it's not an issue now. Go to a pulp wood plant and check out a tube grinder, this thing pulverizes anything you put in it and has a very similar gear set up. Gears are meant to be tougher but you gotta maintain the oil. In reality gears aren't meant to touch at all, they ride on the cushion of the oil. When that cushion is removed is when you have problems.
No comment on belts.
Wed Oct 17, 2012 10:31 am
Wed Oct 17, 2012 10:36 am
Wed Oct 17, 2012 10:51 am
Test drive a pro drive and a gator tail and YOU make the decision. Although my pd is kinda new its never seen fresh water and neither has my buddy's his has a few hundred hours and they hold up as good as any other motor.
Do regular Maintenance on what ever motor you buy gt,gd,pd or mb and they will last a very long time
Wed Oct 17, 2012 11:02 am
I haven't seen a belt driven mud motor with full power reverse so I could care less about a belt or a motor that can't get out of the shit it gets into just saying
Wed Oct 17, 2012 11:34 am
Wed Oct 17, 2012 11:38 am
Wed Oct 17, 2012 11:42 am
The kind that will go around u and pull u out the mud if need be
Wed Oct 17, 2012 11:48 am
Wed Oct 17, 2012 11:50 am
This is getting better than the Debate last night....
That a lie!!!! :lol: :lol: :lol:
Wed Oct 17, 2012 11:54 am
Users browsing this forum: Google [Bot] and 251 guests
