It is currently Wed Jul 23, 2025 11:07 am
[ 8 posts ] |
jerimiahw
Joined: Sun Sep 23, 2012 8:10 pm Posts: 1191 Location: chauvin
 Gator tail
Any of u gt owners ever try using an ss engine or a rotax motor seems like it would be better than hopping up Briggs I'm almost considering buying a gt just to try it I don't have that option with prodrive but if I did I don't think I would put a penny in a Briggs if anyone has done this I would like to se pics and see how they perform ? how fast?
Thu Oct 25, 2012 5:59 am |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
 Re: Gator tail
Yep..both have been done.
The Harley engine needs constant air flow to keep cool...which is a set back unless you also rig it with a radiator of some sort. The other setback is clutches. The clutches that are used on these motors aren't capable of withstanding the power/torque that the Harley engines emit.
As for using Rotax engines, Kyle at GT had one at Mud Fest back in '06 or '07. It had lots of top end (ran 50-55 mph) but sucked royally on the bottom, as Rotax engines need to spool up pretty high before producing power.
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
Thu Oct 25, 2012 6:36 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
 Re: Gator tail
all you need is a new motor bracket with a 90* gear box from the shaft on the engine to the vertical shaft
Marty(basinhunter) build a GT with a harly engine clone (IIRC) but had problems with the clutch holding up.
I heard he was working on a prodrive also.
_________________ I gave up mud motors
Thu Oct 25, 2012 6:50 am |
jerimiahw
 Re: Gator tail
I figured the ss engine would have heat issues when u stuck in mud just seems like some one out there could build something better than Briggs something with 70 plus horse power
Thu Oct 25, 2012 7:06 am |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: Gator tail
Thu Oct 25, 2012 9:12 am |
dadazzsaleen
Joined: Tue Nov 09, 2010 11:24 pm Posts: 743 Location: Mandeville, LA
 Re: Gator tail
I have always been interested in this. but have just not had the time to get involved. having 1 or 2 e-fans would help with the heating issues. they have some pretty power compact fans on the market, 2,000-3,500 CFMS.
_________________ [Stage 2.5]
Thu Oct 25, 2012 10:16 am |
985piranha
 Re: Gator tail
i have a 700 street bike motor i wanna make a surface drive .looking for ideas
Sun Oct 28, 2012 10:51 pm |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
 Re: Gator tail
Cooling would be easy, big oil cooler and fan! Like Craig said, clutch won't hold up, solve the clutch issue and I think it would be fairly easy....
Mon Oct 29, 2012 4:53 am |
[ 8 posts ] |
Users browsing this forum: Majestic-12 [Bot] and 131 guests |
