It is currently Mon Jun 03, 2024 2:15 pm
Reply to topic  [ 9 posts ]
 35hp Vanguard running problem? Updated
Post 35hp Vanguard running problem? Updated
As the title says, I have a 35 hp Vanguard. In order to keep it running it has to be choked. After running for awhile it wouldn't run at all unless the air filter cover was removed, choked or not. New air filter.
Took the carb off and y'all were right. Had a lot of jelly looking buildup in the carb bowl. Ran great after cleaned out. Now I am fighting the motor doesn't want to stay in the water, wants to keep blowing out. I read on this forum that I need to adjust the cavitation plate but its a Beavertail motor and the plate is not straight the last few inches has about a 45 degree angle down. I guess I will bend that up until condition improves.
Thanks again to everyone who replied.
Fri Nov 16, 2012 12:16 pm
Post Re: 35hp Vanguard running problem?
Sounds like the carb needs to be cleaned out.
Fri Nov 16, 2012 12:22 pm
^^^this
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Nov 16, 2012 12:40 pm
Thanks for the replys. Do you recommend running something like Seafoam through it or just go ahead and rebuild the carb?
Thanks
Fri Nov 16, 2012 6:03 pm
Too late for sea foam. Tear it down & clean the jets out
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Fri Nov 16, 2012 6:09 pm
B. MacDonald
Sat Nov 17, 2012 4:43 pm
Sat Nov 17, 2012 11:30 pm
Anyone have a stock carb for sale? Thanks again for the help.
Sun Nov 18, 2012 1:32 am
Mudbuddy has them for a descent price
1650 ribbed abused by a Gt-35 and push pole reverse
Sun Nov 18, 2012 4:51 am
Users browsing this forum: Google [Bot] and 243 guests
