duckslayer182
 kohler problem
I have a 27hp kohler engine has 395 hrs on it and just recently started killing while its running. The engine will start right back up after it dies. When motor is at high rpms it kills faster then it would if it was at low rpms. Checked bulb and fuel filter still has gas in both. I tried everything i could think of and it still dies. Any suggestions?
| Wed Dec 05, 2012 8:09 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
 Re: kohler problem
Maybe your carb needs to be cleaned. The jets and float can cause some crazy things.
| Wed Dec 05, 2012 8:11 pm |
duckslayer182
 Re: kohler problem
I had carb cleaned about a week ago. Thought that maybe it was a oil sensor so i disconnected the oil sensor and it still kills. Some times it will run for ten minutes without killing and sometimes it will run for 3 minutes and it will kill
| Wed Dec 05, 2012 8:22 pm |
bassmastrbw96
Joined: Wed Mar 17, 2010 7:54 pm Posts: 45 Location: Cleveland Tennessee
 Re: kohler problem
Have you checked coils could be cracked could be bad gas also
| Wed Dec 05, 2012 8:46 pm |
scatters boy 316
Joined: Sun Jun 05, 2011 9:19 pm Posts: 721 Location: carrollton MS
 Re: kohler problem
I have had my coils do that at 400 hrs it would get up to about 3200 rpms and then bog and die, replaced the coils and spark plugs while I was at it and she has been runnin hard ever since.
_________________ 8 foot sneak boat with 8hp go devil going Mach 1 Layout blinds and a whole bunch of decoys
| Wed Dec 05, 2012 8:52 pm |
AKA Freshwaterkilla
 Re: kohler problem
Make sure ur key switch isn't turning off from vibration mine got wore out would be running wide open and it would just shut off and took a few times before I figd it was just the key turning off
| Wed Dec 05, 2012 8:56 pm |
duckslayer182
 Re: kohler problem
Havent checked coils but i made sure both plugs had good fire. I have a gas tank out of another boat going to try different tank and see if anything changes.
| Wed Dec 05, 2012 8:58 pm |
UNCLE-J
 Re: kohler problem
Sell your problem to me, and go buy a new one.
| Wed Dec 05, 2012 9:07 pm |
duckslayer182
 Re: kohler problem
Anything is for sell if the price is right
| Wed Dec 05, 2012 9:08 pm |
UNCLE-J
 Re: kohler problem
All you said was Motor manufacture. What drive is it on? Mud-buddy?
| Wed Dec 05, 2012 9:09 pm |
duckslayer182
 Re: kohler problem
prodrive fpr
| Wed Dec 05, 2012 9:11 pm |
Old School
Joined: Thu Dec 17, 2009 9:44 pm Posts: 3067 Location: Earth
 Re: kohler problem
Mine did the same thing, my tank was not venting.
_________________ Gator tail
| Wed Dec 05, 2012 9:12 pm |
UNCLE-J
 Re: kohler problem
Well?? Offer sent via PM
| Wed Dec 05, 2012 9:21 pm |
