It is currently Thu Oct 31, 2024 6:19 pm
Reply to topic  [ 45 posts ]  Go to page 1, 2  Next
 GTR 35 REBUILD (PICS)
Post GTR 35 REBUILD (PICS)
Getting ready to get my second motor built for my dual rig I will be ordering this season.
Not many build topics on here any more so I figured I would start one.
I started my rebuild yesterday. I coated this engine in oil and PB blaster in the fall hoping that it would soften things up a bit. So far I have been met with lots of rust and aluminum oxidation problems. What a nightmare getting some of these bolts out was...This engine only has 115 hours on it but I think the guy who owned it must have left it uncovered for a long time.
I plan to build this motor to the same specs of my motor I am currently running. I got this motor for a good price so a few grand and I should have it up and running like new. Hopefully saving me a few bucks in the long run.
So Far Junk Parts Are:
Carb
Coils
Stator
Ignition
Most of the wiring
Good usable parts:
Block
Case
Exhaust
Planitary Gear
Lower unit
Heads
Prop
Air Cleaner Cover
Plastic
Reverse Caliper
Heres what I started with:
Fri Apr 19, 2013 12:43 pm
Post Re: GTR 35 REBUILD (PICS)
Shit that thing looks better than mine from the beginning lol
17x48 extreme stage 2 GTR
Fri Apr 19, 2013 12:54 pm
Pressure washed everything and got most of the grease and oil off of the motor.
My cheap rust remover device from the toy store.
Works great
Before porting
Shit.....to the bridgeport....
Leaky oil problem area everyone is talking about
[URL=http://s20.photobucket.com/user/Mallardsx2/media
Cylinder # 2 Facing out
/IMG_20130419_162022_zps90ff78b3.jpg.html][/URL]
Crankshaft land cant decide what to do...I scratched it a little pulling out the crank.. Probobly just hone it out a smidgen..
Inside case Needs a little cleaning.
Fri Apr 19, 2013 4:44 pm
Nice!
Fri Apr 19, 2013 5:14 pm
Wish I had the knowledge to do this kind of stuff. Very nice
1646HD GTB and a 35GTR w/ with Calens stage 1
Fri Apr 19, 2013 6:05 pm
Sat Apr 20, 2013 8:04 am
Love this kinda stuff! Thanks for sharing!
And go pet that poor dog!
Sat Apr 20, 2013 9:53 am
And spray some penetrating oil on them damn fuel pump bolts that you broke :lol:
Sat Apr 20, 2013 3:19 pm
The only thing I will be spraying on them is cutting fluid when I am running a carbide end mill down through the center of them....lol
I was super pissed when I snapped them off but I tried everything and that aluminum oxidation just had them in there something fierce.. I'm gona try and weld a washer then a nut to the top of them and get them out again before consulting the bridgeport....
Sat Apr 20, 2013 4:42 pm
Sat Apr 20, 2013 4:56 pm
Just realized that your stator / flywheel bearing was damaged. You can buy those! Just not for the crank case.
Bought this one for my vert a while back.
Sat Apr 20, 2013 5:32 pm
Just had to buy a new crank case cover because I scratched the bearing pretty bad taking it off. The covers are $342.
YIKES!!!! :o
That sure was a kick where it hurts!
Modded 36 PD draggin' around an 1848 PD boat backwards!
Sat Apr 20, 2013 5:53 pm
Got everything Cleaned up. Replaced the lower seal that was blown out my the previous owner. Never ceased the shit out of everything. New grease in the lower unit. Never had to remove the lower seal before but I can tell you this much keep your fingers out from behind that pully when you run the impact gun on that taperlock bushing....holy shit did that hurt! Pressure washed everything and got most of the grease off of the motor and parts pressure washed the belt to get the grease off of it while I was at it. I went over the lower unit every bolt and found some to be loose so I tightened as necessary.
The one thing that surprised me is that this unit has not grease fittings. That shows it age. It is #479 motor. I will install grease fittings at various places. Getting this trim unit off was quite a chore....ended up using a 10 ton press to press the old bolts out. Aluminum oxidation....what a pain...never cease is my new best friend.
Fixed my broken bolts.
What a mess this was to clean out....
Tue Apr 23, 2013 10:18 am
This is a good video for reference of removing that taper-lock bushing. NO BULLSHIT you need some manly snap-ring pliers. I broke my little sissy snap ring pliers and ended up making a pair out of some nails and an old pair of pliers...and no I'm not showing a picture of that....
viewtopic.php?f=41&t=31614
Tue Apr 23, 2013 10:26 am
Never seize is definitely your friend...except when you're trying to get it off your skin!!! Then you cuss the bastard that invented it up and down and sideways...lol
Tue Apr 23, 2013 4:53 pm
Cool thread.
As far as a rust buster/corrosion penetrator goes, I've tried a lot of different products and haven't found anything better than ACF-50. Not sure if you're already past the tear down phase, but it's still handy to have on the shelf.
32 PD with EVT cam, decked heads, shaved pistons and not enough sense to leave things alone!
Tue Apr 23, 2013 5:15 pm
Aero kroil. It must be good. I see it on every production platform I go to.
Tue Apr 23, 2013 5:27 pm
Tue Apr 23, 2013 5:43 pm
Well Id have say false. There shit stays in the salt air and spray for 24-7-365. I'd say they use it for a reason. Your lil mm rust to shit within one season of minimal salt use.
BTW money is no object for the oil field.
Tue Apr 23, 2013 5:57 pm
Kroil is some good stuff!! They proud of it too!
Tue Apr 23, 2013 6:01 pm
1846 GTB & 35 GTR
Team Gator-Tail
(409) 720-8949
Tue Apr 23, 2013 6:18 pm
They sale it but the gallon but I have never priced it
Tue Apr 23, 2013 6:21 pm
We use kroil at the plant too. It's good shit, PB blaster is good stuff too. 50/50 mix of acetone and transmission fluid works like a champ too.
Tue Apr 23, 2013 6:32 pm
CRC Knock'r Loose is the same thing as Kroil. As soon as Aero Kroil's patent ran out CRC came out with the same formula. Much cheaper.
Tue Apr 23, 2013 6:54 pm
Tue Apr 23, 2013 7:52 pm
Tue Apr 23, 2013 7:53 pm
Just saying its the generic version kinda like all generic stuff normally not as good as the original
Tue Apr 23, 2013 7:55 pm
Tue Apr 23, 2013 9:59 pm
Yeah we had a puller on it too.... But get kroil it creeps!! :lol:
Tue Apr 23, 2013 10:06 pm
I bought 5 gallons if this stuff. I will show before and after pictures of how it works. It has great reviews all over the internet.
http://www.northerntool.com/shop/tools/ ... =evaporust
If I owned a sandblaster I wouldn't even bother with this stuff but I dont so this is worth a shot to me.
Wed Apr 24, 2013 7:39 am
Wed Apr 24, 2013 8:25 pm
The best thing I found for rust, as far as soaking something is kings ford lighter fluid. It will take every speck of rust off the rustiest whatever u have If u submerge it for a day. I'm talking brand new..except for the pitting
Wed Apr 24, 2013 10:12 pm
X2 on lighter fluid
1852 Dfou custom 35gtr
Thu Apr 25, 2013 4:48 am
Thu Apr 25, 2013 7:13 am
Ever put this thing all back together?
Tue Jun 04, 2013 7:29 pm
Got shipped out on pipeline job for now. I have everything except for my heads and my carb and new rings. I'm on the fence about replacing the origional hydraulic trim unit while I am at it. These older style trim units really suck...I have constant problems with mine.
Thu Jun 06, 2013 9:25 am
At least i'm making some money to pay for all of the upgrades. I sure wish I hadnt paid so much for the motor used. I had to replace and re-work and clean every single nut and bolt on this motor. Right now I am more focused on making sure my existing motor is running good because I am going to Virginia to shoot stingrays for a 5 days to shoot stingrays. I replaced the belt on my 2008 motor with a belt from my old 2006 motor and it seems super tight and I am getting a whine from the belt. This is with no shims. I am going to take that belt off and put one of the brand new belts I got from calen on the motor.
Thu Jun 06, 2013 9:26 am
Doesn't look like there much to it from the pic's are all gatortail frames the same my buddy has one but it like 10years old does look like that.
1542 stuck to a 27mini. She gone.
1746 with a modded 35 gdsd
Capt Team total asalt
Thu Jun 06, 2013 11:52 am
BTW The Evapo-Rust works great and I would highly recommend it to anyone.
Thu Jun 06, 2013 12:06 pm
Thu Jun 06, 2013 1:21 pm
Users browsing this forum: Majestic-12 [Bot] and 135 guests
