DuckHunter251
Joined: Mon Jan 24, 2011 5:00 pm Posts: 233 Location: Milledgeville, GA
 Grass screen
Anyone ever had the grass screen catch on the plastic cowling and break the three studs that hold it on to the fly wheel? Then rip the fan to shreds? Had to order the new parts today. Heard that this is a common occurrence with the 35.
_________________ 1846 GTB with GTR 35
| Tue Jul 30, 2013 7:05 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
 Re: Grass screen
Yep. You must have been the other boat at Seminole.
Broke 2 of the 3 studs on the fun run.
My solution. No more spinning guard.
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Tue Jul 30, 2013 7:23 pm |
CJB
Joined: Tue Sep 13, 2011 11:46 am Posts: 5216 Location: Across the Bayou, LA
 Re: Grass screen
Happened to mine a while back
_________________ 35 GTR - 1754 Extreme
| Tue Jul 30, 2013 7:24 pm |
mizzippi jb
Joined: Wed Sep 21, 2011 2:53 pm Posts: 5077 Location: The duck Mecca called Ga!
 Re: Grass screen
Smart thinking Mr. Triple b. That will serve the same purpose without that stuff spinning. Probably gonna do mine like that before it happens.
_________________ HOTSAUCE170 wrote: I've never gone to Seminole for the amenities/luxury the two reasons I go down there are to kill shit and get fucked up with like minded individuals aka OG'S. If you want to swirl wine and stay in a room where politics and investment diversity are discussed (with no roaches) lake lanier is near Atlanta. If you wanna have an awesome time and maybe stay in a room where children were conceived on one side and someone got stabbed over an 8-ball on the other come on down I got a can of raid.
| Tue Jul 30, 2013 7:28 pm |
Choclab
 Re: Grass screen
You know damn well you're gonna have to shoot some paint on those zip ties before you're happy with that setup! I'll let you borrow some dead grass green paint. Only takes a week to dry.
| Tue Jul 30, 2013 7:33 pm |
mizzippi jb
 Re: Grass screen
| Tue Jul 30, 2013 7:35 pm |
DuckHunter251
 Re: Grass screen
I ordered a new fan and had Boat DR cut down some new studs. I'm gonna do my screen like you did bbb. Andy said you need to keep the metal ring and three studs in place to help support the fan. I'm going to try and get the broke off studs out with a left hand drill bit.
| Tue Jul 30, 2013 7:48 pm |
bbb
 Re: Grass screen
I was able to drill a small hole into the broken stud and used a tap on the drill in reverse and backed the sheared bolt out. I got lucky they weren't in there too tight. Then put the ring back on and found 3 bolt screws with the same thread. Looked for the black zip ties for 10 minutes and settled on those as I was headed to the lake again. See my boat doesn't sit out in the driveway 4 days waiting for the paint to dry. While I was on the lake I found the black zip ties in my dry box. Thinking about powder coating the guard.
| Tue Jul 30, 2013 8:23 pm |
bbb
 Re: Grass screen
| Tue Jul 30, 2013 8:27 pm |
Team Camo
Joined: Thu Oct 01, 2009 4:49 pm Posts: 8536 Location: Bridge City, TX
 Re: Grass screen
The torx bolts that hold the screen on are the same size as the tower bolts. I used them to hold the metal ring on the fan, & put the grass screen on the inside of the cage with small black zip ties. A quick rattle can job, & it looks just like stock.
_________________ 1846 GTB & 35 GTR Team Gator-Tail
Killer Kallz & ANGLE PORT dealer (409) 720-8949
| Tue Jul 30, 2013 8:34 pm |
banded-mallard
 Re: Grass screen
That's why y'all stupid mofo should have a PD.
| Tue Jul 30, 2013 8:37 pm |
bbb
 Re: Grass screen
| Tue Jul 30, 2013 8:57 pm |
DuckHunter251
 Re: Grass screen
I turned the motor off as soon as I heard it go but it was too late. It didn't break any of the fins but chewed them up pretty bad.
| Wed Jul 31, 2013 12:50 am |
pooldoo73
Joined: Tue Jan 25, 2011 5:47 pm Posts: 886 Location: Plaquemine
 Re: Grass screen
U need to leave the metal band and 3 bolts that hold the cooling fins down n the middle. The fins will flex out when running and rub the shroud if u don't. U need to cut down the center bolts so they are only buttons r they will eventually shear off too. Just get rid of the grass guard completely.
_________________ 18'x54"CC Hanko/ 36PD
| Wed Jul 31, 2013 4:06 am |
Will
 Re: Grass screen
I saw a post on here a long time ago where a vertical did the same thing except it messed up the fan, a coil and busted the main shroud. I went home that night and took all that crap out including the grass catcher. Everybody I know personally had done it.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Jul 31, 2013 5:02 am |
Will
 Re: Grass screen
Cut those long studs off like a typical bolt head and put em back in there.
| Wed Jul 31, 2013 5:04 am |
OwenDickeson
 Re: Grass screen
Why do you need the grass catcher? I just took mine off completely.
| Wed Jul 31, 2013 8:37 am |
Puddler45
Joined: Thu May 03, 2012 9:07 am Posts: 1199 Location: Wisconsin's waters and woods
 Re: Grass screen
raffia from the blind gets sucked in from time to time.
_________________ 1744 floating a 23 MBHD Stage 2
| Wed Jul 31, 2013 8:47 am |
JIMMY W
Joined: Tue Jan 13, 2009 8:02 pm Posts: 4534 Location: South Louisiana
 Re: Grass screen
_________________ 17/54 GT EXTREME Center Console, Huntdeck w/ GTR 35
| Wed Jul 31, 2013 9:31 am |
Bigrich
Joined: Wed Dec 19, 2012 7:52 pm Posts: 7064 Location: Mallard country
 Re: Grass screen
Ouch!!!!
| Wed Jul 31, 2013 9:33 am |
Will
 Re: Grass screen
| Wed Jul 31, 2013 10:17 am |
banded-mallard
 Re: Grass screen
| Wed Jul 31, 2013 10:18 am |
