It is currently Sat Feb 14, 2026 2:09 pm
Reply to topic  [ 11 posts ]
 Weathering Fast Grass
Post Weathering Fast Grass
I am re grassing my boat blind and I am planning on using fast grass again. Last time it took about a year for this stuff to weather and not stand out so much. I am wondering does anyone have any idea how to weather it faster ( maybe spray paint) or would it be better to use camo netting and forget the fast grass?
Wed Oct 21, 2009 6:04 pm
MMT Moderator
Post Re: Weathering Fast Grass
Not suggesting you do this but I have a new set that I'm using... I rinsed my boat and forgot about one of them that was folded up. Well 1 week goes by and it molded up, rinsed it off and let it dry looks pretty good now actually...
GTB 1860 w/ 2019 GTR40XD-HO
Wed Oct 21, 2009 7:01 pm
I use Camosystems leafy camo netting Mossy Oak B/U.
I baught a mesh 8x20 tarp at Harbour freight, cut it in half , and zip tie the camo to the mesh. Camosystems also has a wind blocker I use, but you could get one of the canvas tarps HF sells.
17x48 EXCELL/36PD
Wed Oct 21, 2009 7:46 pm
go to home depot, get you the camo spray paint. think krylon makes it. dark brown, tan and green. spray it about 1ft away and just mix it up. it will take the gloss off of the grass and leave it in the weather open the sun will do the rest. did mine last year like that. ill try to find the pic for you to see
Thu Oct 22, 2009 7:04 am
i added some killer weed bundles & sprayed it all down w/ waterseal from da marts (think it was actually amor all b/c they were out of thompsons). supposedly makes the grass last longer, but also darkens it up a little once dry. after dry, i sprayed some areas w/ krylon camo paint to darken it more - my marsh area is greener & darker than plain fast grass light brown.
Gator Tail GTR35 on a Go Devil 16x56
Thu Oct 22, 2009 7:43 am
i have used the avery fast grass the past 2 yrs and both times i hated it. its too damn heavy when its wet and doesn't last at all. im trying some military camo netting that im getting from cousin in national guard. i hope it works out better. im going to add some stuff to it to give it a more 3-d effect and hopefully that will work out.
Thu Oct 22, 2009 8:22 am
"I just want silence. Jesus, it doesn't mean I don't like you. It just means right now, I like silence more."
Thu Oct 22, 2009 10:34 am
Read this on another web site. Wet you mats then roll them up and leave them in a cool moist place for a week or 2. I tried it and worked pretty well.
Sat Oct 24, 2009 7:17 pm
I have just bought some MOJO Ghillie bundles from Cabela's. This material is already on a net and it is made of synthetic material which won't rot or get heavy like the different grasses that you can purchase. It does have a shine, but I bought a bunch of different cans of Krylon camo paint and painted the material. It looks like it is going to be awesome and should last a lot longer than any grass. Also, if you lose any of the small bundles on the net, you can order a pack of 32 to attach to the net. Each net is 5' tall and 8' long. :idea:
19' X 4' Charles Leonard flat boat (bateau) w/35 HP GTR
15' x 7' Alumitech Airboat w/502 C.I. GM motor
Sat Oct 24, 2009 9:53 pm
i sprayed mine with a garden hose, and left it laying on the driveway for a week, spraying it daily. then hung it over the fence for about 2 weeks. it darkened it up and gave the blades some curl. even though it takes some time, i too some palmettos and stripped the fronds then wove them in the mats for a subtle blend of green, i also took some flat brown paint for a shadow effect. the prob with palmetto is they die and fade to a light tan after a little while.
18/54 skiff 36 pro-drive
Sun Oct 25, 2009 7:19 pm
overspray with camo paint and let it get wet and dry a few times outside inthe sun. it will age up pretty quick.
Mon Oct 26, 2009 9:09 am
