It is currently Mon Apr 06, 2026 12:48 pm
Reply to topic  [ 17 posts ]
 RPM Question
Post RPM Question
So when I'm cruising, let's say I'm at 95% throttle, I'm turning around 4200 to 4250 rpms. But when I open up to 100% throttle, my rpms drop to 4100 to 4150.
Is it starving? Could the governor be the problem even though at one point it turns up higher?
Here is a rough chart to help illustrate what I'm talking about.
Stock 27 Kohler.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Thu Aug 22, 2013 11:33 am
Post Re: RPM Question
Because its going up hill!
Thu Aug 22, 2013 11:46 am
Well shouldn't it pick back up on the down side???
Thu Aug 22, 2013 11:51 am
Um I never seen a mudboat do down hill! lol
Lost velocity, jetting. How close are you to hitting the governor at wot.
Thu Aug 22, 2013 11:58 am
Governor is around 4600 neutral.
Thu Aug 22, 2013 1:14 pm
Is this something that just started or has it always been this way?
Can you make it repeat this response in neutral, out of water?
Initially, sounds like you are hitting a rev limiter?? Mine will drop to 3600 once I hit the 4350 mark.
Thu Aug 22, 2013 1:22 pm
Thu Aug 22, 2013 1:25 pm
Thu Aug 22, 2013 2:21 pm
Thu Aug 22, 2013 2:23 pm
your gov. has no idea if its carrying one delta or three deltas.
Thu Aug 22, 2013 5:15 pm
Thu Aug 22, 2013 5:27 pm
Did you ever do a plug check at WOT? May be going lean at WOT. Easy way to check, pull choke lever in small increments if possible when at WOT see if rpm rises.
Thu Aug 22, 2013 5:38 pm
here is something to try set gov. back to 3600 rpms and do another run test. get back to me. do it with a no load in boat.
Thu Aug 22, 2013 5:44 pm
Thu Aug 22, 2013 5:49 pm
Thu Aug 22, 2013 5:52 pm
first of all set ur carb at wot. with ur throttle cable not any further. than set ur gov at lets say 4000-4100 rpms. and see what happens.
Thu Aug 22, 2013 6:30 pm
