mudslut
Joined: Mon Dec 06, 2010 6:54 pm Posts: 2061 Location: Natchitoches,La
 Throttle cable froze up
Is there anything I can do to keep the cable from freezing up?
Sent from my iPhone using Smoke Signals
_________________ 1646 Gatortail dragging a stage 1 GTR
| Sat Nov 30, 2013 8:19 am |
BayouStateHunter
Joined: Sat May 16, 2009 1:04 pm Posts: 2037 Location: On da Northshore -- Louisiana
 Re: Throttle cable froze up
Antifreeze in a Cajun injector into the cable
_________________ 1860 GTB/35GTR CC w/ Hoyt Stage 1 - bowfishin'/rodnreel/duckhunting
| Sat Nov 30, 2013 8:32 am |
mudslut
That's a good idea
| Sat Nov 30, 2013 8:51 am |
MNGunner
Joined: Mon Jan 09, 2012 8:56 pm Posts: 2623 Location: Minnesota
_________________ 1754 Gator Trax Hybrid Hunt Deck with GTR35
| Sat Nov 30, 2013 10:27 am |
mudslut
This is the second morning in a row it has done it. The motor stays under my carport and the trailer freezes to the bottom of the boat.
| Sat Nov 30, 2013 10:44 am |
swampbilly
Joined: Fri Oct 07, 2011 6:08 pm Posts: 1054 Location: Dam-b, Texas
Mine was froze at the carb yesterday mornin, so last night I wrapped an old Tshirt around it then taped a plastic Walmart sack on it. Took it off at the boat ramp this mornin and didn't have a problem with it.
_________________ pd36 fpr 1754 cc rig
| Sat Nov 30, 2013 12:40 pm |
barrelburner
Hey guys mine has froze too many times then I care to speak of, motor was useless in cold weather. I would have too exercise the throttle in the back of the boat manually which was dangerous. Just an idea and not sure if it will work for your motor but I was getting desperate and pissed off. What I did was remove a section of throttle cable sleeve in the middle exposing it and left about 10 or 12 inches on each end. It has worked great since then and no more problems. I keep the exposed part of the cable greased a little bit too stop corrosion and rust. Cable is cheap to replace vs the aggravation of a froze cable at ( O Dark Thirty in the morning). Just to add, my throttle cable is unconventional because I use a small screen door pulley and wheel clamped to the handle bar too keep the angle of the cable small before it hooks to the throttle arm on the motor.
| Sun Dec 01, 2013 7:39 am |
barrelburner
Also, forgot to mention motor is a 6.5hp homemade surface drive.
| Sun Dec 01, 2013 7:43 am |
