It is currently Mon Feb 23, 2026 11:06 pm
Reply to topic  [ 8 posts ]
 Throttle cable froze up
Post Throttle cable froze up
Is there anything I can do to keep the cable from freezing up?
Sent from my iPhone using Smoke Signals
1646 Gatortail dragging a stage 1 GTR
Sat Nov 30, 2013 8:19 am
Post Re: Throttle cable froze up
Antifreeze in a Cajun injector into the cable
Sat Nov 30, 2013 8:32 am
That's a good idea
Sat Nov 30, 2013 8:51 am
Sat Nov 30, 2013 10:27 am
This is the second morning in a row it has done it. The motor stays under my carport and the trailer freezes to the bottom of the boat.
Sat Nov 30, 2013 10:44 am
Mine was froze at the carb yesterday mornin, so last night I wrapped an old Tshirt around it then taped a plastic Walmart sack on it. Took it off at the boat ramp this mornin and didn't have a problem with it.
pd36 fpr 1754 cc rig
Sat Nov 30, 2013 12:40 pm
Hey guys mine has froze too many times then I care to speak of, motor was useless in cold weather. I would have too exercise the throttle in the back of the boat manually which was dangerous. Just an idea and not sure if it will work for your motor but I was getting desperate and pissed off. What I did was remove a section of throttle cable sleeve in the middle exposing it and left about 10 or 12 inches on each end. It has worked great since then and no more problems. I keep the exposed part of the cable greased a little bit too stop corrosion and rust. Cable is cheap to replace vs the aggravation of a froze cable at ( O Dark Thirty in the morning). Just to add, my throttle cable is unconventional because I use a small screen door pulley and wheel clamped to the handle bar too keep the angle of the cable small before it hooks to the throttle arm on the motor. :D :P
Sun Dec 01, 2013 7:39 am
Also, forgot to mention motor is a 6.5hp homemade surface drive.
Sun Dec 01, 2013 7:43 am
