Seand717
 Motor hits rev limiter at 1/4 throttle???
I've got a 1750 gator trax with 35 mud buddy with cam,rockers, carb, exhaust. Like title says when I get to 1/4 throttle I'm running 4500 rpm. I've taking carb apart and can't see anything out of place. I've been having a problem with it pushing the boat. With 3 people it struggles to get on plane but a few months back ran perfect and could do 26 with 3 people and gear. I've replaced clutch also thinkin it was slipping and that helped a little bit but not much..I'm lost on what it is
| Fri Nov 29, 2013 4:34 pm |
msm8281
Joined: Fri Oct 09, 2009 1:50 pm Posts: 9673 Location: New Iberia, La.
 Re: Motor hits rev limiter at 1/4 throttle???
Measure your prop. Sounds like a worn prop.
| Fri Nov 29, 2013 4:45 pm |
Seand717
I've swapped props both were used but the same thing. Even in my. Garage running the motor with prop spinning it hits 4500 rpm at between 1/8 and 1/4 throttle
| Fri Nov 29, 2013 4:58 pm |
msm8281
It will do that ooh with no load on it.
Measure it from tip to tip.
| Fri Nov 29, 2013 5:00 pm |
Seand717
Forgot to say before I could hit 30 by myself now won't go passed 24 mph
| Fri Nov 29, 2013 5:02 pm |
AKA Freshwaterkilla
Sounds like u néed to change gears to low of gearing I got a 48 t bottom gear I will sell u Sent from the baddest mudmotor out there
| Fri Nov 29, 2013 7:00 pm |
Seand717
It didn't used to do this. Used to run perfect. I have 38/48 gearing
| Fri Nov 29, 2013 7:57 pm |
woodsman1977
prop must be worn as all hell, don't understand how u are hitting 4500 at just quarter throttle. u say u used to hit 30.....have u adjusted anything else? If not it must be the prop
Sent from my iPhone using 2 somewhere in the swamp
| Fri Nov 29, 2013 8:03 pm |
Seand717
I've tried re adjusting the air/fuel screw and idle. Even in my garage with the prop spinning it will hit 4500 rpm at 1/8 - 1/4 throttle
| Fri Nov 29, 2013 8:26 pm |
msm8281
So will mine or any other motor will do that with a mikuni. There is no load on the motor when it's out of water. Check your PROP I bet it is close to 11.5" or less.
| Fri Nov 29, 2013 8:31 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
It's not the prop if it doing it in the garage. What is your idle at? ~900-1100??
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
| Fri Nov 29, 2013 8:32 pm |
Seand717
Yea idle is 900-1100. I've tried turning idle down and adjusting air screw and other way around. It was running lean as my plugs were brown and dry and exhaust would glow so I raised the jet but this didn't affect the 1/4 throttle problem
| Fri Nov 29, 2013 9:06 pm |
Seand717
Seand717
Gameover
When u open at 1/4 throttle and hitting limiter is your carb slide open all the way?
| Fri Nov 29, 2013 9:12 pm |
Gameover
If so u may have cable adjusted to tight and leaning out motor big time just to get idle back down.
| Fri Nov 29, 2013 9:13 pm |
Seand717
No slide is only opened 1/4 with throttle. The cable is adjusted out as much as it can
| Fri Nov 29, 2013 9:40 pm |
odass
if it's not the prop, then maybe the clutch is messed up, even tho I haven't seen one really slip, they normally just mess up, and break.
_________________ Dead Fowl Custom 1954hd with a GTR
| Sat Nov 30, 2013 6:49 pm |
Seand717
I just put a new clutch on it..
| Sat Nov 30, 2013 11:49 pm |
ak
Joined: Tue Oct 23, 2012 11:09 am Posts: 897 Location: MATAGETDOWN, TX
its the prop i bet money... you got two used props that are the same size. I got two used props that are the same size too both wore the flock out. I put one of them on when the river was low to save my new one. I could barely get on a plane had to go 1/4 throttle as well and was running slow annnnddd was hitting my rev limiter every time I applied a lilttle gas. The rev limiter only shuts you off when it sees rpms over what they are rated for but that doesnt mean you wont spin that wore up prop to well over what you should be before the rev limiter catches you. Be careful not to throw a rod doing that it can happen.
| Sun Dec 01, 2013 12:35 am |
UP ON THE STEP
Put a new prop on it and it will be fine! Seen this exact scenario more than once
| Sun Dec 01, 2013 5:36 am |
Seand717
It does this in my driveway also. Not just in the water. With no load on it the carb only opens 1/8-1/4 way and it's at 4500 Rpms.
| Sun Dec 01, 2013 10:59 am |
odass
| Sun Dec 01, 2013 12:44 pm |
bbb
Joined: Wed Sep 02, 2009 2:54 pm Posts: 1554 Location: SW Georgia
_________________ 19x54 Seminole Extreme with a 35hp CDI GDSD. Mikuni. Marsh Mellow. Heads. Cam.
| Sun Dec 01, 2013 1:00 pm |
Seand717
If you ease on the throttle really slow it will hit 5k at 1/8-1/4 throttle?
| Sun Dec 01, 2013 1:01 pm |
Seand717
I've talked to mud buddy and a few different places and they all said it shouldn't do this
| Sun Dec 01, 2013 1:02 pm |
cb5331
With no load, the motor will hit 4-5k at less than 1/4 throttle. That is normal.
| Sun Dec 01, 2013 1:05 pm |
Seand717
Well shit. Would it cause it to act exactly the same in the water? No motor what trim the motor is at it won't go passed 1/4 throttle , won't push the boat and have lost 6 mph
| Sun Dec 01, 2013 1:10 pm |
odass
Hell today I had 100 dekes, 4 guys , dog and all the normal crap, and at half throttle I was running 4300, empty I can nail 5k at half, take it out of water and it revs to rev limiter instantly with minimal pressure, honestly it dont matter, you are losing traction with warn prop. it's slipping, and you ain't getting going fast, dint take but a little sand to ruin a new prop. they are touchy
| Sun Dec 01, 2013 1:11 pm |
Seand717
Alright. Well I'll see if my buddy will let me. Borrow his new prop and see. Been thinkin about gettin the hammer. Maybe it's time
| Sun Dec 01, 2013 1:16 pm |
bbb
| Sun Dec 01, 2013 1:18 pm |
Seand717
| Sun Dec 01, 2013 1:21 pm |
bbb
My motor would push A new Big Blade 4150 in the water and run 28mph. That prop doesn't have much room to wear before its shot.
My GD 3 blade prop spun 3750 new and ran 26mph. After over 100 hours it's just now hitting 4100-4150 and running 28mph. I actually had to wear some cup down to get better speeds. But lost some performance in the shallows with the lost cup.
Once a prop loses cup it's worthless. The BB in my opinion is more of a performance prop that works best when new.
Anyone ever weighed a Mud Buddy big blade and a GD 2 blade? I held one in each hand and there's a noticeable difference.
| Sun Dec 01, 2013 1:27 pm |
Seand717
When I really noticed it starting to mess up was when I had my deck on the front and was tryin to push all the weight it seemed like it slowly lost speed and push. I thought clutch was bad because it was all rusted. I sent pictures to mud buddy and they said it looks bad so I replaced it and could feel it hooking up more but still wouldn't push like it should. Hopefully it is the prop
| Sun Dec 01, 2013 1:38 pm |
msm8281
Measure the damn thing already!!
| Sun Dec 01, 2013 1:56 pm |
ak
| Sun Dec 01, 2013 2:20 pm |
Seand717
One prop is 11 7/8 other is 11 3/4. I'm gonna order a new prop next pay day. Thanks for the help I hope that's my problem
| Sun Dec 01, 2013 3:10 pm |
msm8281
Definitely your problem. A new one is like 12.25"
I told u that on the first post...just sayin:smile:
| Sun Dec 01, 2013 3:25 pm |
Seand717
Ha yea. Thanks guys.
| Sun Dec 01, 2013 3:53 pm |
