It is currently Wed Mar 25, 2026 12:43 am
Reply to topic  [ 13 posts ]
 Hull?
Post Hull?
Been lurking for a while trying to get an idea of what I need in a hull. I know I'm going to go custom and pretty much how I want the layout. I will be using the boat to bass fish and duck hunt, I'll be in deeper water mostly (4+ft) but have a ton of beaver dams to contend with. Would I be better off with a 3/16 bottom or will 1/8 be okay crossing dams all the time? I also would like a center console, but I'm not sure about jumping dams with a cc. Thanks in advance
Wed Feb 05, 2014 12:40 pm
Post Re: Hull?
Ill put it to you like this when i called to order my material, they guy told me if i was gonna break 1/8 then id break 3/16. So you should be fine with 1/8th if your just jumpin dams
35 GTR chasin a BBC 1848
Wed Feb 05, 2014 12:48 pm
Post Re: Hull?
Wed Feb 05, 2014 12:51 pm
Post Re: Hull?
Wed Feb 05, 2014 12:52 pm
Post Re: Hull?
what would be the weight per sq ft of 1/8 and 3/16 ? obviously the bottom would weigh 30% more but may not be enough to concern ya if you are wide enough.
http://www.gatorglide.com/
gatorheads@comcast.net
Wed Feb 05, 2014 1:07 pm
Post Re: Hull?
3/16 braced correctly is significantly stronger than 1/8.
Well worth the extra weight IMO
Wed Feb 05, 2014 1:11 pm
Post Re: Hull?
i jump levees in my boat and its 1/8 with no problem....some of the levees have rollers or hard plastic hose to help get over..... no hooks or dents. unless you are running stump fields wide open, I wouldnt go with the 3/16. but dont go under 1/8 on the sides either if you are jumping levees and beaver dams.
Black ops IITX marshstalker
1840 WC www.wccustomboats.com
fuel injected 25 GTR
Wed Feb 05, 2014 1:12 pm
Post Re: Hull?
Post Re: Hull?
Wed Feb 05, 2014 1:28 pm
Post Re: Hull?
Thanks guys. So I guess I may as well do 3/16th and be done with it. I'm not looking for speed demon, just trying to get where I can't in the skeeter.
Wed Feb 05, 2014 1:43 pm
Post Re: Hull?
I would go with 3/16th. Not enough weight difference to matter.
Wed Feb 05, 2014 1:49 pm
Post Re: Hull?
Better to have it and not need it then to need It and not have it.
GatorHide - MB
Wed Feb 05, 2014 1:54 pm
Post Re: Hull?
1744 WC Custom
25 GTR
Wed Feb 05, 2014 4:37 pm
