It is currently Fri Dec 26, 2025 12:21 pm
Reply to topic  [ 43 posts ]  Go to page 1, 2  Next
 GT 3 Blade Review Thread
Post GT 3 Blade Review Thread
09 GTR on an GT 1860CC GT Stage one
Deep water I ran 29 by myself at just under 3700 rpms. I used to run the near the same speeds with a fresh 2 blade but at 3700-3800rpms. I can't tell if it vibrates less with the CC set up but it feels like it has a little more low end and reverse is improved.
I'll post shallow water speeds and loaded weights at a later date. I just wanted to get the info out there. FYI, the prop did not come with a cup which recesses the nut into the prop.
Sun Apr 20, 2014 9:10 am
Post Re: GT 3 Blade Review Thread
Sun Apr 20, 2014 9:40 am
What # is stamped on the blades. Mine is 567.I wonder what it means as for as indentifaction purposes.
Btw 3800 with a stage 1 motor seems low with a two blade. I would think you would be around 4000.
What does your stage one consist of?
Sun Apr 20, 2014 9:51 am
#567 stamp also. An early Hoyt cam, decked heads and exhaust. I never ran 4000 or over until my 2 blade prop got worn.
Sun Apr 20, 2014 10:07 am
something isnt right with that motor then because my stock one turns 3800 easy 28mph deep water
07 16x50 w/ 07 35 gtr
Sun Apr 20, 2014 10:16 am
But it will run 26-28 with a 4 man bowfishing load with generator and loaded ice chest. I know it will run faster with the 2 blade probably 30-31 unloaded. Don't forget I'm running a 1860 CC with 2 batteries and some misc equipment weight
The motor never reved up high in all the years I had it. My cam is different then the the ones out there now. Not sure if that is the difference.
Sun Apr 20, 2014 10:20 am
Sun Apr 20, 2014 10:21 am
What hole are you running your motor At top middle or bottom
- Mark Twain
Sun Apr 20, 2014 10:34 am
Middle is the sweet spot for this rig
Sun Apr 20, 2014 10:36 am
You might try moving it with the new three blade
- Mark Twain
Sun Apr 20, 2014 10:37 am
I run a 1754 xtreme CC stage one and run 4350 Rpms and 31 mph. When I ran 3 blade I went down to 4100 and 29-30 mph
Sun Apr 20, 2014 11:25 am
Sun Apr 20, 2014 1:02 pm
Their running different gears. I tell you this I know my boat is a dual but I love my 3 blades on it. Not saying it outperforms the 2 blade but it's a better for me and what I do.
17x48 extreme stage 2 GTR
Sun Apr 20, 2014 1:15 pm
I've been running it for a month or so now and love it, hole shot is better, tiller torque is noticeably less with a load for me. It did fine in thick grass with a light load but with 4 people I had to change back to the 2 blade foe frogging.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Sun Apr 20, 2014 1:32 pm
[quote="BayouBuster"]I've been running it for a month or so now and love it, hole shot is better, tiller torque is noticeably less with a load for me. It did fine in thick grass with a light load but with 4 people I had to change back to the 2 blade foe frogging.
^^^^^^^^^^^^^^^^^^With 4 people I had to change back to the 2 blade foe frogging.......
It's NOT all that to me, you lose RPM's and it don't carry a load good I just stick with a 2 blade hands down I rather a 2 blade for performance and all around prop.
Sent from da woods!
Sun Apr 20, 2014 1:56 pm
17x54 Extreme W/ GTR-35L Stage 1
Sun Apr 20, 2014 3:44 pm
2007 is the year for my motor
Sun Apr 20, 2014 3:48 pm
Old gearing will not turn it that good. My stage two with old gearing could only turn it about 4200 rpms. Im upgrading to the new gearing now. I post up the results after its complete.
Sun Apr 20, 2014 3:51 pm
2 blade > 3 blade
Only thing better about a 3 blade is reverse and you can idle shallower than the 2 blade. Everything else, nod goes to the 2 blade.
Sun Apr 20, 2014 5:05 pm
i dont have any complaints out of my three blade so far, but i haven't ran a two on this boat yet either. This is a stock motor also and ive seen 30 in deep water light that plenty satisfy s me being a stock motor anyways. Is GT gonna offer both now when you call to buy one?
Sun Apr 20, 2014 5:19 pm
Sun Apr 20, 2014 5:30 pm
I ran one on stock 1852 lost speed. I'll try agian when get stage one
1852 Dfou custom 35gtr
Mon Apr 21, 2014 8:41 pm
1854 Extreme CC 35 GTR
RTR!!!
Mon Apr 21, 2014 8:53 pm
If the three blade performs close to the same as the two blade, even if its a lil slower...
the blades look a lil thicker on the three blade, so it might not wear out ad fast as the two blade.
It may be worth a shot for me even though i have old style pulleys.
Mon Apr 21, 2014 9:09 pm
Tue Apr 22, 2014 7:05 am
Yep Delta is right, this would help your rig alot with how heavy it is. The new gear does really well in all aspects.
Tue Apr 22, 2014 7:34 am
Well then....make room...let me know when to bring it. :D
I have one more week off.
Tue Apr 22, 2014 8:09 pm
hahahaha
Tue Apr 22, 2014 8:11 pm
The other night I had 6 of us in that heavy rig with the bowfishing gear.
It barely wanted to plane in deep water but ran 26-27 in shallow.
I think that was the hardest that motor ever worked coming home with all those people,28reds,15sheep head,and 9 drum fish.
Got on step and kept it up till back at launch.
I think my worn 2 blade actually helped with that big load.
And....what the fuk was so damn funny?
Tue Apr 22, 2014 8:28 pm
Bring it over, we will get it done
Wed Apr 23, 2014 6:43 am
Nothing wrong with that. The gears will help you with the loads.
Wed Apr 23, 2014 11:27 am
What do I order? Top gear? Bottom gear?
What ratio will it change it to?
How bout the new trim unit I heard about? Is that in stock too yet?
Wed Apr 23, 2014 10:11 pm
Bottom gear belt housing and a belt. Gear ratio 1.26 from the 1.18 ratio.
Wed Apr 23, 2014 10:17 pm
GTR, Waitin' on a DFOU hull
Wed Apr 23, 2014 10:37 pm
For the record, oow Rpm's were a little over 4000. There is some adjusting to be done as it just came from the shop after the rocker boss incident. Still 29 ain't bad.
Wed Apr 23, 2014 10:55 pm
I guess if u gotta get a whole new belt housing to change gears u might as well get the new style lower unit too.??
Do u need to grease and change seals as often with the new style?
Wed Apr 23, 2014 10:59 pm
Thu Apr 24, 2014 7:15 am
Thu Apr 24, 2014 7:50 am
Housing is to accommodate larger pulley. Belt is to fit 48t pulley instead of 45t.
Thu Apr 24, 2014 7:53 am
Thu Apr 24, 2014 7:57 am
