It is currently Tue Jul 01, 2025 12:00 am
Reply to topic  [ 56 posts ]  Go to page Previous  1, 2
 Headwork
Post Re: Headwork
Yes that was one of the problems, I fixed that yesterday but it was still a few thousandths from hitting the arms. What is the main purpose for the screw with spring adjustment on the back of the carb?
1854 GatorTrax GE chased by MB 5500 Mag
Sun Aug 17, 2014 8:05 am
Post Re: Headwork
Bend your big spring out some and it'll allow it to drop idle completely. Then if your not hitting rev limiter OOW, zip tie the spring coils to get it to pull the arm harder when u give throttle.
It's an adjustment for the gov. Clockwise turn will make it hit rev limiter but will pull your idle up. So turn it down and bend that spring to allow it to drop completely to idle.
Your motor a cdi?
Sun Aug 17, 2014 8:23 am
Post Re: Headwork
Sun Aug 17, 2014 9:45 am
Post Re: Headwork
4350 coils. When I rev out of water it's just below 4300. Thanks, I'll play with it a little more to adjust the gov adjuster. Are your springs set about half way for a good basis?
Sun Aug 17, 2014 11:09 am
Post Re: Headwork
I meant is your screw with the spring about half way turned down or more in than out or vice versa?
Sun Aug 17, 2014 11:10 am
Post Re: Headwork
I got the mikuni now but I think it was more turned up. It won't matter once you get your spring to let the arm fully back to idle, then zip tie to bang rev limiter outta water. Your basically just gonna override the governor. It's a waste to have 2 governors on a motor. The Briggs linkage system just slows your throttle response down. They were not designed for varying throttle
Sun Aug 17, 2014 12:44 pm
Post Re: Headwork
Good info, thanks fellas
Sun Aug 17, 2014 7:20 pm
Post Re: Headwork
So I bent out the upper left spring looking at the backside of the carb and that dropped my idle arm down just like you said, perfect... I adjusted the screw length basically all the way out to allow me to run at rev limiter level... Will I "wear out" the limiter doing this? Or should I adjust screw back down... At one point I turned 4400 rpm's with 4350 limiter, is this dumb talk or can happen?
Tue Aug 26, 2014 5:33 pm
Post Re: Headwork
Not sure if you can "wear" one out or not. Its built into the coil itself and not a box. 4400 is normal to see, your tach may not always read 100% accurate.
Tue Aug 26, 2014 5:38 pm
Post Headwork
You don't want to constamtly ride on the limiter. It's there to bounce off of if you hit something, not to ride against.
Wed Aug 27, 2014 8:39 am
Post Re: Headwork
Wear out a rev limiter? Wow.
Wed Aug 27, 2014 9:34 am
Post Re: Headwork
Wed Aug 27, 2014 11:31 am
Post Re: Headwork
Well spoken bayouboy... About to purchase the 4700 so I don't get anymore wow factor...
Wed Aug 27, 2014 3:54 pm
Post Re: Headwork
18x48 EXTREME w/ 35GTR MARSH MELLOW XX
Thu Aug 28, 2014 5:34 pm
Post Re: Headwork
South LA, depends if you do the work yourself and send them or you drop your boat off and he does the work. Pm him, that's what I did, great work and you won't be dissapointed
Thu Aug 28, 2014 8:46 pm
Post Re: Headwork
Loreauville, LA
Thu Aug 28, 2014 8:47 pm
Users browsing this forum: No registered users and 152 guests
