It is currently Mon Mar 16, 2026 6:14 am
Reply to topic  [ 20 posts ]
 Jack Plate vs. Built-up Transom
Post Jack Plate vs. Built-up Transom
If one was to put a tall transom motor on a short transom boat, what are the advantages/disadvantages of using a jack plate verses just building up the transom the old fashioned way with welded aluminum.
Not sure how much difference it makes, but this hypothetical situation is in reference to a 36 ProDrive, which, as you know, is heavily back weighted.
Tue Sep 30, 2014 7:44 pm
Post Re: Jack Plate vs. Built-up Transom
I'd build up transome and be done with it. A jack plate will put that heavy ass motor 6" further back which will make it want to squat. You'll notice it when taking off in shallow hard bottom. Besides what you will spend on a Jack plate you could put toward building up the transom.
Tue Sep 30, 2014 7:47 pm
Sounds like a bad idea to me..
And x2 on msm
Tue Sep 30, 2014 7:48 pm
It's definitely cheaper to build up a transom, which is obviously a factor. I wasn't sure how much the offset was. 6" is more than I'd imagined. My biggest worry would be strength. How susceptible would the jack plate be to damage under mud motor running conditions? (Stumps, logs, kicking up, dropping hard, etc.)
The only real advantage I see in my head is that by being able to drop a tall transom motor to short transom height would give you an extra 4-6" of downward reach with improved drive angle. In theory, a ProDrive would benefit immensely from this with respect to reverse.
Is that logical thinking?
Tue Sep 30, 2014 7:55 pm
Y'all have said everything I would have.
Another thing is will your transom hold up with putting all that weight 6" further back on the transom?
I would build it up if it were my rig.
Sent from my beeper
Tue Sep 30, 2014 7:58 pm
Tue Sep 30, 2014 8:07 pm
Eat - Sleep - Hunt ! ! !
Tue Sep 30, 2014 8:10 pm
It may be possible to get a 4" setback but idk for sure. Everyone I ever seen seemed like it was 6".
Tue Sep 30, 2014 8:11 pm
you would need three hands to operate trim, hydraulic jack plate, and throttle at the same time. DDM runs them on his big boat and they have been able to withstand the abuse
Tue Sep 30, 2014 8:12 pm
I agree if you built a boat strong enough to hold one it would be a great option for the pd's in the soft stuff.
Sent from my beeper
Tue Sep 30, 2014 8:13 pm
In theory it sounds great. However, If you look where the gear knuckle of the PD is, it is above the bottom of the boat at all times. If you lower the whole motor you increase the area causing drag. Will it work in some cases, yes. To make a PD run mud like a GTR, no. There is more factors that are involved in traversing mud flats than how deep you can get.
Tue Sep 30, 2014 8:36 pm
I'm pretty sure I've seen 4" set back jacks. Search micro jack plates if I remember right (it's been a while)
17*38 Klibert 23GDLT
Tue Sep 30, 2014 8:37 pm
Check your clearances with the trim ram.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Tue Sep 30, 2014 8:43 pm
How long is your hunt deck?
Tue Sep 30, 2014 8:50 pm
Forget it. It isn't feasible on my rig. I'm glad I asked the question, but it doesn't seem like it's an option. My HD is 22". I certainly can't afford to lose another 6"!
Just looked, and the 4" setbacks are for "small outboards"...
Tue Sep 30, 2014 8:58 pm
A jackpot sets your motor back off the transom and makes the boat sit lower in the water. Build the transom
1850 Uncle J
Delta Performance level 4 GTR
Wed Oct 01, 2014 10:29 am
Hunt decks and pro drives aren't a real good fit. I had a hd/pd rig once. Wasn't optimal to say the least. But mine was a short transom. I'm sure a tall makes a difference.
HOTSAUCE170 wrote:
Wed Oct 01, 2014 11:50 am
I tried a jack plate and ran it once then went straight to the weld shop. Wish I had that Saturday back that I wasted putting that thing on.
Wed Oct 01, 2014 11:57 am
I like my hunt deck and Prodrive but then again mines a CC. :)
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Thu Oct 02, 2014 4:58 pm
Thu Oct 02, 2014 5:21 pm
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 1 guest
