It is currently Wed Mar 25, 2026 5:37 pm
Reply to topic  [ 1379 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 35  Next
 Kawi FXT00V "Let the good times roll"
Post Re: Kawi FXT00V "Let the good times roll"
:mrgreen: Been sorta a slow summer hours wise ;) trolling motor catchin' hell as always though
PRODRIVE 1860 CC
Tue Oct 21, 2014 5:24 pm
1850 Uncle J
Delta Performance level 4 GTR
Wed Oct 22, 2014 7:03 pm
He'll I'm over that. I'm back to grind on this engine.
Wed Oct 22, 2014 7:11 pm
Wed Oct 22, 2014 8:24 pm
^^^^gee, that makes a lot of sense. :?
Wed Oct 22, 2014 9:27 pm
Thu Oct 23, 2014 4:30 am
Great example on why all warning labels should be removed...
Thu Oct 23, 2014 5:02 am
Thu Oct 23, 2014 5:32 am
Just trying to stir the pot a little bit.
Thu Oct 23, 2014 6:03 am
Hooked, I'll forgive ya this time as I know that after several pages of AKA diarrhea it must have been difficult to keep up with the jist of this project. Peace 8-)
Btw I don't hold it against ya, hell some guys like black girls but, hey, puzzy's puzzy right! Haha
PRODRIVE 1860 CC
Thu Oct 23, 2014 6:09 am
Hey hey hey! Don't go getting all crazy and shit. :lol:
Thu Oct 23, 2014 6:49 am
It's ALL good :D have me a laugh this mornin :lol:
PRODRIVE 1860 CC
Thu Oct 23, 2014 7:04 am
Thu Oct 23, 2014 7:31 am
Nice tits! That avatar is M E S M E R I Z I N'....
PRODRIVE 1860 CC
Thu Oct 23, 2014 8:13 am
^x10
1754 XSeries Kawi Powered PRODRIVE ...
Thu Oct 23, 2014 9:29 am
OK - funs over get back to work on the coolest project/thread - you ugly humps
Thu Oct 23, 2014 9:41 am
Thu Oct 23, 2014 10:21 am
Mostly Tits and Retards!!!!
Thu Oct 23, 2014 11:23 am
1850 Uncle J
Thu Oct 23, 2014 12:13 pm
Chit... Guess I'll get back ta woik then, got a limiter to install and test...
PRODRIVE 1860 CC
Fri Oct 24, 2014 1:42 pm
Couldn't you shim the valve springs you currently have?
Mon Oct 27, 2014 5:22 am
Yes and no. We were looking at possibly doing a shim plate, that would shim both at the same time and somewhat keep it in place. But I have a test spring that should be here Tues or Wed, hopefully. If this spring works, Im ordering a set and see how they do. The stock springs are 16-18 lbs each. This test spring is 26 lbs. I don't think it will take much to get it pass 5k rpms. If it does allow to get pass 5k, then I'll pitch my prop to get rpms back down to a good level.
Mon Oct 27, 2014 5:29 am
Well I worked on the limiter Saturday but its not picking up a strong enough signal from the plug wires. Going to try to shorten the signal wires and get the signal pulse right at the coils. If that doesn't work then I guess I'll go with a proximity switch off the flywheel.
PRODRIVE 1860 CC
Mon Oct 27, 2014 9:36 am
Mon Oct 27, 2014 10:38 am
:lol:
PRODRIVE 1860 CC
Mon Oct 27, 2014 10:47 am
I believe he approximately has his whole head up his ass. :lol:
Mon Oct 27, 2014 10:49 am
Which is the approximate location. :lol:
Mon Oct 27, 2014 10:52 am
:lol:
Tue Oct 28, 2014 5:02 am
Any updates?
Wed Nov 05, 2014 4:56 am
One just got sat on a Gen 3, trying it out real soon.
Wed Nov 05, 2014 6:06 am
Wed Nov 05, 2014 8:29 am
Wed Nov 05, 2014 9:19 am
Wed Nov 05, 2014 9:57 am
Wed Nov 05, 2014 1:31 pm
Ok guys, here a little update on the springs. Installed them and they work great. I was able to push pass past the 4760 valve float, but not much. The more I trimmed up up, the rpms kept climbing. When I got to about 4900, the prop started to loose bite and lost speed. So now I know that I'm good as far as valve float. Speeds were about the same (consistant 34's, bumped 35 again) at 4830.
But... being I have been somewhat of the test subject for all this, one thing that I have noticed is this motor is a torque monster. The collective group is trying to do everything we can to get the rpms up to get it to run with the briggs. Although its not running the same rpms as the briggs, it is however running faster than my briggs stage 2 did, not by much. After several cam swaps, different springs, I just don't know if the rpms are gonna break the 5000 mark and still pull with power. It may, and maybe we just haven't found the right combo yet. But one thing I do know, this bitch pulls. I have tried a number of times to load this thing till it was about to sink, and it got up and ran 29-30. The pull from 2500-4400 is stupid. Which seems funny being a short stroke engine. I was always told that a short stroke engine still makes power at higher rpms, they spin up faster. Well it does, but kinda flattens out. So I think I'm gonna look at it a different way. Diesel engines make tons of torque by don't really rev that high. If this engine truly has the low end grunt and power to haul elephants, then props will push it over the edge.
I should have caught that earlier when Lee (Bug) took a bone stoke Kawi and spun a 14 pitch on his barge. I bet this stage 2 monster would spin the shit out of that 14. So my next order of business will be to get with a prop guy (Baggy, La Prop, whoever) and see what he can do with it and what do they think. And in the end, if nothing changes, I'll keep my 34-35 mph elephant toting, non-crankcase leaking, mean green diesel pulling machine like it is. :twisted:
On a side note here is what my Stage 2 mods consist of:
Heads - ported, polished, decked .025" (180 psi), valve guides cut down
Exhaust - open exhaust with 4" can and (2) 1.5" outlets
Mikuni (initial test) - HSR42, 4.2 needle seat, stock Kawi pump, 167.5 main, 20 pilot, short Summit racing carb adapter.
Mikuni (now) - HSR42, 2.3 needle seat, Briggs fuel pump, new billet cab adapter (longer, more mix time), drilled and tapped carb adapter for vacuum fitting for briggs fuel pump, 22.5 pilot, 167.5 main.
Now, Jerimiah just got his heads back and decked them .030". When we did this initially, we decided to go .025" to be on the safe side with clearances. So if his .030" works, then there some additional power to be had. And when I pull these heads after hunting season to check the valves and such, prob get a valve job done (haven't done anything yet, still stock valves) and deck alittle more, depending on his outcome.
Tue Nov 11, 2014 6:06 am
Tue Nov 11, 2014 10:25 pm
If you take anything that dude said seriously you are as dumb as he is.
Wed Nov 12, 2014 5:31 am
The village idiot is gone!! Let's not keep him around in memory.
Wed Nov 12, 2014 5:47 am
Wed Nov 12, 2014 5:55 am
Please refrain from clouding this informative thread with off topic references.
Wed Nov 12, 2014 6:04 am
