It is currently Mon Jul 07, 2025 11:31 pm
Reply to topic  [ 12 posts ]
 Remove hydrilla from duck hole
Post Remove hydrilla from duck hole
What is the best / easiest / most effective way to clear out hydrilla from a hole I don't wanna do the whole hole just a small place to clear out to put out decoys
2010 gtr cdi with a stage 2 pushing a 18x46 home made HEAVY DUTY boat
Fri Dec 12, 2014 6:46 am
Post Re: Remove hydrilla from duck hole
Drag a small anchor or small piece of grading around and up root it. Then maybe it will sink to the bottom and die.
Fri Dec 12, 2014 6:59 am
This looks pretty cool. Never used one though.
http://www.weedrazers.com/
17*38 Klibert 23GDLT
Fri Dec 12, 2014 7:06 am
I'll try the grading we have a lot of stumps and stuff so I won't be able to drag the bottom if that don't work I'll try a rake it's perty thick so a rake might do it
Fri Dec 12, 2014 7:24 am
Remember, every piece of grass u break sinks and starts growing as a new plant.
Hydrilla is almost impossible to get rid of. Your best bet would be to run your boat in the area u want to open up until u have the bottom washed clean. That will get u through the season, but it would b a maintenance thing to be able to hunt it
18'x54"CC Hanko/ 36PD
Sun Dec 14, 2014 8:23 am
Make you a pen with chicken wire and put some grass carp in it. Crazy idea but i bet it would work
Sun Dec 14, 2014 9:51 am
We run the boat in a series of hard over circles (as tight as the boat will circle in reverse) and just cut a hole. It doesn't seem to work going forward. The circle isn't as tight, so the grass doesn't get pulverized. Typically we open up several holes in the hydrilla prior to the season coming in so we don't have to deal with it in the dark. Fortunately, here it is only an early season issue. It begins to die down after the first few freezes.
MoMarsh Fatboy/2 Honda
Mon Dec 15, 2014 7:25 am
1748 Cottonmouth Hybrid Custom with a 2015 35GTR
7 yr old Boykin Spaniel
One Badazz wife that that hunts like a champ
ROLL TIDE!!
Mon Dec 15, 2014 3:22 pm
Ima try a rake first and if that don't do it ima try just ridin around in it you don't wanna back up hard you catch a stump
Backing up a couple times dedicated and you break stuff
Mon Dec 15, 2014 5:13 pm
http://aquaplant.tamu.edu/management-options/hydrilla/
Diquat works well!
18X44 Geaux Custon Powered By MB 4500 BD
Tue Dec 16, 2014 5:43 am
Tue Dec 16, 2014 11:26 am
Which one did you use
Thu Dec 18, 2014 4:43 am
Users browsing this forum: Google [Bot] and 33 guests
