It is currently Wed Jul 02, 2025 1:21 pm
Reply to topic  [ 18 posts ]
 GTR Case leak fix
Post GTR Case leak fix
Can someone post up steps on how to remove the belt, transmission, clutch, and pulley on a GTR? I need to take my motor to a shop near the house to get my case gasket replaced under warranty, but there is no gator tail dealer close so I need to break it down to just the motor for them to work on. I have done all this on a MB but not a GTR.
Thanks
1848 Prodigy
35 GTR
Tue Dec 23, 2014 5:58 pm
Post Re: GTR Case leak fix
Damn....once you get all that done, the case gasket is the easy part.
Tue Dec 23, 2014 6:38 pm
I have to replace my transmission so I would love any helpful hints about all this too
Tue Dec 23, 2014 8:02 pm
Drain oil in block
Remove
Clutch cover
Caliper off rotor
Drain oil out of planetary
Will be a 5/8 head bolt in center of planetary remove it
Then pull the planetary apart
The back half of the planetary U can bump it with a piece of wood and hammer, might have to drive it off. A puller would be better.
Then loosen up the motor bolts and tilt the motor down in the rear. That way u can work the belt of the pulley over the clutch.
Take clutch off and zip tie it up
U will wanna rock the motor toward the boat and place a board under the back that way u can remove the case gasket. And also with motor tilted that way, that lil bit of oil left in be block won't run out.
Then u can start taking the case apart.
Hope this makes sense and helps!
Tue Dec 23, 2014 8:04 pm
1848 Prodigy
35 GTR
Wed Dec 24, 2014 8:45 pm
The clutch will come off easy. But the planetary will need a puller
Wed Dec 24, 2014 9:30 pm
Wed Dec 24, 2014 10:25 pm
Whats the torque on the cover bolts doing mine today to
1440 xpress 23 gdsd... Sold
1644 gd 35 gtr
Wed Dec 24, 2014 11:11 pm
Located in engines & mod talk. Here you go. Merry christmas.
Thu Dec 25, 2014 8:10 am
Didnt no if a 36 was the same
1644 gd 35 gtr
Thu Dec 25, 2014 8:18 am
Very important: cover the hole on the top of the belt housing to prevent stuff falling down in there. You will thank me later.
Thu Dec 25, 2014 8:30 am
Case cover bolts are recommended 16.8 pounds I believe.
Thu Dec 25, 2014 11:17 am
Thu Dec 25, 2014 11:23 am
From the briggs manual, 200 in. lbs.
Thu Dec 25, 2014 12:19 pm
Fri Dec 26, 2014 6:27 am
Fri Dec 26, 2014 11:50 am
Is there no thrust washers on the crankshaft pulled my cover off put it back on and noticed it had a decent amount of thrust how are you supposed to take that out
1644 gd 35 gtr
Fri Dec 26, 2014 3:07 pm
Fri Dec 26, 2014 5:42 pm
Users browsing this forum: Google [Bot] and 102 guests
