It is currently Fri May 09, 2025 4:15 pm
Reply to topic  [ 446 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 12  Next
 ProDrive 2-Blade Gen 3 Prop
Post Re: ProDrive 2-Blade Gen 3 Prop
I will say this about my gen 3 it has a lot more low end. With a fuel 13 gallon tank and 5 Ppl in the boat (850-900 lbs) I can get on step and run about 16. I don't think that's bad. Also from a dead stop in thick Lillys I will leave my brother and his gen 2. Best case is that the new prop ads a couple mph and I can change props a cording to load
Sun Feb 22, 2015 4:55 pm
19x48 MAD MAN CUSTOMS 36PD (stock for now)
Sun Feb 22, 2015 5:03 pm
I've been dead stop in an inch of water in my rig with a 4 man bow fishing load, 50 qt yeti loaded down, 120qt ice chest with fish and ice, 14 gals of fuel, bow fish rails, and 3 big batteries, and been able to get out with out outs problem (of course have to have softer mud than firm Sandy mud, not gunna lie and say that I can do that in freaking sand) lol
Sent from my SAMSUNG-SM-N900A using Tapatalk
Sun Feb 22, 2015 5:05 pm
Sounds like I shouldve saved the 400 bucks and got the gen 2 lower instead.
Sun Feb 22, 2015 5:15 pm
Sun Feb 22, 2015 5:17 pm
My personal opinion is that prodrive went so long without anything new a the computing caught up so they rushed out the Gen 3 and wasn't rdy yet. I will say this to anyone thinkin about buying one if u go into thinking torque and not speed u won't be disappointed. Also seriously think about auto reverse. That's the best 1000 I've spent on a mud motor ever
Sun Feb 22, 2015 5:20 pm
Sun Feb 22, 2015 5:28 pm
Sun Feb 22, 2015 5:36 pm
Sun Feb 22, 2015 5:41 pm
Well guys there is a 18/54 side console down here with 3 batteries troll motor fishing equipment and two people breaking 30 the boat is far from light the prop is the new 2 blade but it is pitched and 30/31 was held the jetting on carb was not correct so it will be rejetted soon and I'm sure Todd will post speeds after and this motor has heads cam and carb new two blade like I said of course adjusted by baggy
Sun Feb 22, 2015 6:17 pm
Dam that's impressive right there
Sun Feb 22, 2015 7:11 pm
Tue Feb 24, 2015 10:04 am
Yes this is an 18/54 gen 3 with briggs has mikuni ,heads,and cam contact toddc he can give you more details I wanna say prop was pitched to 17
Tue Feb 24, 2015 11:41 am
Can someone explain to me the pros and cons of the different pitches. Is a certain pitch better in the mud and another pitch better for speed in open water. Just need to be educated on it
Tue Feb 24, 2015 12:00 pm
Tue Feb 24, 2015 12:01 pm
Tue Feb 24, 2015 12:28 pm
Tue Feb 24, 2015 12:38 pm
Agreed Craig but this sight is designed to help each other out so we can all spend our money wisely hell I'm almost willing to go to the gen 3 myself now im not as interested in top speed anymore get load carring around 30/32 and you got an all around good package
Tue Feb 24, 2015 12:46 pm
All the top secret shit is for the birds
Tue Feb 24, 2015 12:48 pm
Tue Feb 24, 2015 1:17 pm
Tue Feb 24, 2015 5:55 pm
Do you know if it was 3/16 or 1/8 bottom? Just trying to get as much info as possible.
Wed Feb 25, 2015 6:52 am
Can someone explain to me what is the advantage of the tapered shaft vs the straight shaft on the Gen 3 lowers? When I called to order a new prop they needed the serial # to determine which shaft I had.
2014 Pro Drive Gen 3
2014 17x54 X-Series
Wed Feb 25, 2015 8:40 am
The tapered shaft has a larger diameter than the straight shaft. I want to say that the tapered shafts were released right after thanksgiving last year.
37 PD EFI FPR 18x48 Tiller
SOLD -- 27 PD FPR 16x36 Skiff
Wed Feb 25, 2015 8:43 am
Anyone run one yet????
Wed Feb 25, 2015 8:58 am
Wed Feb 25, 2015 9:33 am
Gotcha. Mine's 1948 3/16 bottom and full 1/8 floor, so probably still a little heavier, but fairly comparable. I just wonder what the Briggs EFI would do with a prop like that...
Wed Feb 25, 2015 10:06 am
Wed Feb 25, 2015 10:10 am
Wed Feb 25, 2015 10:45 am
When I order my .125 1854 with a 37 EFI PD I am hoping it runs about 25 MPH with 2 people. That is about all I need out of it to do what I do.
40HP Gatortail
Wed Feb 25, 2015 10:48 am
Wed Feb 25, 2015 10:51 am
40HP Gatortail
Wed Feb 25, 2015 10:52 am
Wed Feb 25, 2015 10:53 am
40HP Gatortail
Wed Feb 25, 2015 11:01 am
Wed Feb 25, 2015 11:06 am
^^^Cannot dissagree with that...
Wed Feb 25, 2015 11:09 am
Wed Feb 25, 2015 11:20 am
Wed Feb 25, 2015 11:34 am
Wed Feb 25, 2015 12:35 pm
It may have been more like 4400-4500 with me and the ole lady, but I can't remember exactly. Either way, I needs a prop with some more ass! If I trim it a little higher, it'll hit the rev limiter and lose speed...
Wed Feb 25, 2015 12:43 pm
Users browsing this forum: Google [Bot] and 100 guests
