It is currently Sat Jul 19, 2025 9:52 pm
Reply to topic  [ 21 posts ]
 anyone with 3.31 gears?
Post anyone with 3.31 gears?
Just ordered a 2015 f350. The only one I found with what I wanted has the 3.31 gears. I have always went with the 3.55. I don't think there will be that much difference. The most I tow is 12,000 lbs. Plus this 6.7 has 40 more hp and 60 more pounds of torque than my 2012. Any opinions? Thanks
23 swomp/ 1542 tracker
Fri Mar 27, 2015 6:04 pm
Post Re: anyone with 3.31 gears?
That's a tall gear... You a flatlander? I ran an old Chevy with 307's a long time ago, rascal would stroll but was hell on u-joints! U shouldn't have any trouble unless you're running in the mountains I wouldn't think.
PRODRIVE 1860 CC
"Let the good times roll"
Fri Mar 27, 2015 6:18 pm
I know it's totally different but. My personal f_150 has 3:55 gears with the ecoboost engine. My work truck is the same with 3:15 gears. I couldn't find any difference pulling my airboat. I know it's not that heavy but it's like pulling a parachute.
Fri Mar 27, 2015 6:24 pm
It is all flat by me except once a year I take the boat to the Atlantic
I would say the ratios in the transmission will be geared to accommodate the higher ratio
Sat Mar 28, 2015 9:33 am
I'm sure it all has to do with unloaded fuel economy set by the EPA. I know the 6.7L in a f250 with 3.55's really hauls the mail. The transmission ratios take some of that into account as well. Typically I seen the 350's have deeper ratios such as 3.73. You may want to look into it. Is it a DRW F-350?
Tue Mar 31, 2015 7:35 am
Just picked it up yesterday. I think my calculating is correct with 3.31 gears and 18" rims that brings it up to about 3.45 ratio. I was worrying about nothing. The fukn thing flies
Tue Mar 31, 2015 2:58 pm
I have the 3:31 gears and have never wanted anything higher numerically. Mine has the 20" rims and I average 18 mpg. That is normal driving not babying it. The heaviest thing I pull is about 12,000 lbs and that is on flat ground. If you don't tow in the mountains you should be fine.
Tue Mar 31, 2015 7:06 pm
Rim size has no effect, tire size does and a 3.31 gear set still is a 3.31 gear set.
Wed Apr 01, 2015 7:14 am
Wed Apr 01, 2015 9:18 am
Yea. Sorry I didn't specify. The larger rim has a bigger tire. Sits 3/4".higher
Wed Apr 01, 2015 1:11 pm
You math is going wrong way. if you go from a say a 31" tire with 3:73 to a 35" tire you are going to want around a 4:10 to get you back to "stock"
Wed Apr 01, 2015 2:53 pm
Stop making me have buyer's remorse you assholes. Let my math be wrong and tell me that I am right
Wed Apr 01, 2015 3:50 pm
:lol: :lol: it will tote the mail regardless and gear sets are cheap if you want replace them as long as you do work yourself :lol:
Wed Apr 01, 2015 6:16 pm
Thu Apr 02, 2015 7:03 am
Thu Apr 02, 2015 10:13 am
Y'all are just splitting hairs now lol
35 GTR - 1754 Extreme
Thu Apr 02, 2015 12:25 pm
If the truck is rated for 12,000# pull 12,000# and don't worry about it.
I pull approximately 10,000# with 3:55 gears and a gas engine. Although I don't pull it that far or that often. Never had a problem. I just pull it in a lower gear to be safe.
Thu Apr 02, 2015 1:13 pm
Thu Apr 02, 2015 3:16 pm
Yep mine looked like someone took buckshot to mine
Thu Apr 02, 2015 3:36 pm
34" tires ( factory), 20" rims , 3:31 gears. Truck is rated for 15,000 lbs so the the final drive in the new six speed must be pretty low.(higher numerically).truck is fast for a big truck but I did get beat by a 6.2 raptor the other day.
Thu Apr 02, 2015 5:47 pm
Users browsing this forum: Google [Bot] and 67 guests
