It is currently Wed Apr 01, 2026 4:06 am
Reply to topic  [ 4 posts ]
 1442 Weldbilt Crawdad Motor Advice
Post 1442 Weldbilt Crawdad Motor Advice
I recently picked up a 1442 Weldbilt Crawdad and I'm looking to put a longtail on the back of it for hunting some muddy and weed choked areas here in West Michigan. I've pretty much narrowed it down to a Back Water SWOMP Lite but I'm trying to figure out what size to go with.
Would the 23 be too much weight for a boat like mine? Would I be better off with just getting the kit and putting a 13hp Predator on it to save some lbs?
As for payload, I hunt alone 90+% of the time and at most with 1 other person. I tend to hunt pretty light: gun, shells, blind bag, push pole, 2 dozen or so decoys, and the previous owner put a pop-up blind on the boat that I'm planning to keep so that adds a couple pounds as well.
Any advice on what direction to go with the motor would be appreciated.
Thu Apr 07, 2016 10:07 pm
Post Re: 1442 Weldbilt Crawdad Motor Advice
Backwater lists the lite 23 (160#) for a 1442 boat hull and up. I would call the good folks at Backwater and get some good advice as far as your needs and motor selection!
Fri Apr 08, 2016 9:13 am
If I recall correctly, I don't think the weight increase from a 13HP to a 23HP is very much at all.
_______________________________________________________________________________
1542 F&F 23HP Backwater SWOMP (under construction)
"Well we don't rent pigs and I figure it's better to say it right out front because a man that does like to rent pigs is... he's hard to stop" -Augustus McRae
Fri Apr 08, 2016 1:15 pm
I had a 27 mudbuddy on a boat just like that.
You will be fine with a 23.
Fri Apr 08, 2016 6:32 pm
