ibfishin
Joined: Sun Dec 05, 2010 8:20 pm Posts: 1127 Location: Okeechobee, FL
 Gasket removal question
What is the most efficient way to remove the factory head gasket form the block?
_________________ 35 GTR pushing an 18' Alumitech Custom
| Thu Feb 04, 2016 10:28 am |
Russ
 Re: Gasket removal question
Razor blade scraper works well
| Thu Feb 04, 2016 11:28 am |
ibfishin
That is what I figured. Didn't know if there was any kind of release agent on the market you guys were using in conjunction with a plastic scraper.
| Thu Feb 04, 2016 12:03 pm |
Russ
After I scrape, I use acetone on a rag to clean any residue.
| Thu Feb 04, 2016 12:49 pm |
schmitt
Joined: Fri Jun 25, 2010 3:33 pm Posts: 1177 Location: WI
90 die grinder with 3m pad
_________________ 1848 DeadFowl pushed by a Stage 4 Delta powered MB HDR (JBP dusting)
| Thu Feb 04, 2016 1:54 pm |
MaXXis85
sharp razor for the thick stuff, a scotch brite pad works good for the little shit. Schmitt got it^^
| Thu Feb 04, 2016 2:03 pm |
Will C
 I like to a papertowel in the pushrod galleys to catch the small stuff. Then vacuum out after scraping. Makes for a nice cleanup. Skip on the grinder
| Thu Feb 04, 2016 2:16 pm |
ibfishin
I put paper towels in the galleys, razor scraped, scotch brite, and acetoned.
| Thu Feb 04, 2016 2:26 pm |
DmaxHunter
Joined: Wed Jan 18, 2012 7:21 pm Posts: 2207 Location: North Alabama
I go get the girl that works the local corner, run a lil of dat crotch rot on the case. Let it set, wipe away and your good to go. No need for tools
_________________ 2014 PRODIGY 1754 (#19) 2014 5500 BAMF HDR RETRO SOLD
| Thu Feb 04, 2016 4:52 pm |
ibfishin
That might work as well.... did not think about the blue waffle ooze.
| Thu Feb 04, 2016 6:48 pm |
richard nagon
Permatex gasket remover. oven cleaner and a plastic scraper or a plastic credit card edge to scrape with. I have never seen a engine builder yet that used a die grinder and rollex discs. There is a ra finish that needs to be maintained on a aluminum head surface. Also disc dust can migrate in to places it shouldn't be in.
_________________ JUST ANOTHER FARMER ON WELFARE
| Thu Feb 04, 2016 9:57 pm |
tylermk5
Loctite makes a paint striper/gasket remover it works well.
| Tue Apr 26, 2016 1:01 pm |
