It is currently Sat Dec 27, 2025 5:39 am
[ 9 posts ] |
marada
 Clutch plate swap?
Just got a used mud buddy hd sport and the keyway on the clutch appears to be broken off. I saw bps has an electric clutch plate but I don't know how to remove the old one? I've posted pictures of mine and then the replacement one from bps.
| Sun Oct 23, 2016 8:30 pm |
riverrat00
 Re: Clutch plate swap?
Should just pull apart after the bushing in the middle is pressed out. I used and hammer and a punch to push it out.
| Mon Oct 24, 2016 9:58 pm |
marada
| Mon Oct 24, 2016 10:03 pm |
riverrat00
Yeah should just press back in. Obviously don't pound on it with a 2 lb hammer.
| Tue Oct 25, 2016 12:49 am |
MaXXis85
Just replace the entire clutch basket, once the magnet is off the crank slip the old one off and slip the new one on the crank, and then the magnet and retorque the crankshaft bolt.
| Tue Oct 25, 2016 5:25 am |
dwbiggs
Joined: Tue Dec 10, 2013 9:27 pm Posts: 47 Location: Melbourne, FL
Same exact thing happened to my motor...mounting bolt loosened and I guess everything vibrated enough to break plate at the flange/keyway and ruin magnet. Install is what Maxxis85 said.
_________________ _________________________________ Alumacraft 1546 AW/Mudbuddy 27 Mini
| Tue Oct 25, 2016 9:17 am |
marada
| Tue Oct 25, 2016 9:22 am |
dwbiggs
Here is what my magnet and plate looked like...
| Tue Oct 25, 2016 2:56 pm |
MaXXis85
I meant just replace the clutch basket only. As long as the magnet isn't shorted (looks like the above pic) it's fine. the front of the basket is where the armature grabs so it will be rough somewhat.
| Wed Oct 26, 2016 6:04 am |
[ 9 posts ] |
