It is currently Tue Dec 30, 2025 12:08 am
Reply to topic  [ 12 posts ]
 Marine Electronics on a Mud Hull with SD?
Post Marine Electronics on a Mud Hull with SD?
I have a few weeks left until my Uncle J and GT XD are completed.
I have purchased most of the things I need like trolling motor. I have yet to purchase any electronics.
Are there any particulars with mounting fish finders and GPS on aluminum hulls with SD motors?
I will use the boat for fishing more than hunting. Any recommendations for electronics?
Uncle J 18x54
Gator Tail XD 37 EFI -Delta Performance Level 3
Tue May 23, 2017 6:09 pm
Post Re: Marine Electronics on a Mud Hull with SD?
Search. There was a thread not long ago. There were a few options for transducer mounting, and there are a bunch of threads from people long gone from mmt how they mounted different items
Sent from my SAMSUNG-SM-G891A using Tapatalk
Tue May 23, 2017 6:33 pm
Could you use thru hull like we do with our kayaks? Guaranteed that it will not be drug off or damaged. I cut wax paper and wrapped square foam and built a containment "pond" for the epoxy I used. Mix it thin so it will flow in and around the transducer encapsulating completely.
I am going to do the same thing under the floor between it and the hull.
1244 Atchafalaya Outdoor Designs W/ 12hp Copperhead
2017 Atchafalaya Outdoor Designs 1244
2017 Copperhead 12hp
Tue May 23, 2017 7:37 pm
I mounted mine with a adjustable /removable clamp on bracket from Sully. The head unit is on a ram mount. Everything can be removed or put back on in about 10 minutes. I can go out to the garage and snap some pics if ya want
Sent from my SM-G900P using Tapatalk
Wed May 24, 2017 12:53 pm
I would like to see it.
Uncle J 18x54
Wed May 24, 2017 3:44 pm
If you are going to find yourself at Caddo lake in a couple weekends you'll see my setup. It's simple and works well.
-Custom pool noodle
-stage 4 water wings
Wed May 24, 2017 5:54 pm
Not going to be able to make it this time around. I recently took a job with a logistics company and am working weekends. I hope to make some of the other runs and definitely want to do Caddo next year.
Uncle J 18x54
Wed May 24, 2017 7:03 pm
10-4, if you search around a little I know pics of mine have been posted before. Hope to see you around some time!
-Custom pool noodle
Wed May 24, 2017 9:14 pm
Sorry for the delay but here's how I set mine up. Im happy with it. I could've ran the wiring to look pretty but my main concern was making it as easy as possible to remove for hunting and reinstall for fishing.
Sat May 27, 2017 1:26 pm
Prodrive makes one for $125
2016 Prodrive X 1848 37efi
Sat May 27, 2017 4:31 pm
I did this. With two RAM mounts it stays rigid so it reads depth even at 28mph. This way it's still easy to remove.
Sat May 27, 2017 5:48 pm
Sat May 27, 2017 9:15 pm
